[mapserver-commits] r12832 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Wed Nov 30 18:04:00 EST 2011
Author: havatv
Date: 2011-11-30 15:04:00 -0800 (Wed, 30 Nov 2011)
New Revision: 12832
branches/branch-6-0/docs/en/mapfile/label.txt
trunk/docs/en/mapfile/label.txt
Did some fixes to the LABEL document - changing depretation notices to removed for backgroundcolor and friends, and fixed some formatting.
Modified: branches/branch-6-0/docs/en/mapfile/label.txt
--- branches/branch-6-0/docs/en/mapfile/label.txt 2011-11-30 17:28:49 UTC (rev 12831)
+++ branches/branch-6-0/docs/en/mapfile/label.txt 2011-11-30 23:04:00 UTC (rev 12832)
@@ -11,11 +11,13 @@
pair: LABEL; ALIGN
ALIGN [left|center|right]
- Since version 5.4 . Specifies text alignment for multiline labels
- (see WRAP_) Note that the alignment algorithm is far from precise,
- so don't expect fabulous results (especially for *right*
- alignment) if you're not using a fixed width font.
+ Specifies text alignment for multiline labels (see WRAP_) Note
+ that the alignment algorithm is far from precise, so don't expect
+ fabulous results (especially for *right* alignment) if you're not
+ using a fixed width font.
+ .. versionadded:: 5.4
.. index::
pair: LABEL; ANGLE
@@ -60,18 +62,24 @@
BACKGROUNDCOLOR [r] [g] [b]
Color to draw a background rectangle (i.e. billboard). Off by default.
- .. deprecated:: 6.0 Use STYLE object and `GEOMTRANSFORM labelpoly`.
+ .. note::
+ Removed in 6.0. Use a `LABEL STYLE`_ object with
+ `GEOMTRANSFORM labelpoly` and `COLOR`.
BACKGROUNDSHADOWCOLOR [r] [g] [b]
Color to draw a background rectangle (i.e. billboard) shadow. Off by
default.
+ .. note::
+ `GEOMTRANSFORM labelpoly`, `COLOR` and `OFFSET`.
BACKGROUNDSHADOWSIZE [x][y]
How far should the background rectangle be offset? Default is 1.
+ .. note::
.. index::
pair: LABEL; BUFFER
@@ -144,9 +152,8 @@
.. _MAXLENGTH:
MAXLENGTH [integer]
- Introduced in mapserver 5.4, this keyword interacts with the WRAP_
- keyword so that line breaks only occur after the defined number of
- characters.
+ This keyword interacts with the WRAP_ keyword so that line breaks
+ only occur after the defined number of characters.
.. csv-table:: Interaction with WRAP_ keyword
@@ -156,6 +163,8 @@
The associated RFC document for this feature is :ref:`RFC40`.
.. index::
pair: LABEL; MAXOVERLAPANGLE
@@ -282,37 +291,40 @@
pair: LABEL; PRIORITY
PRIORITY [integer]|[item_name]|[attribute]
- The priority parameter (added in v5.0) takes an integer value
- between 1 (lowest) and 10 (highest). The default value is 1. It
- is also possible to bind the priority to an attribute (item_name)
- using square brackets around the [item_name]. e.g. "PRIORITY
- [someattribute]"
+ The priority parameter takes an integer value between 1 (lowest)
+ and 10 (highest). The default value is 1. It is also possible to
+ bind the priority to an attribute (item_name) using square
+ brackets around the [item_name]. e.g. "PRIORITY [someattribute]"
- Labels are stored in the label cache and rendered in order of
- priority, with the highest priority levels rendered first.
- Specifying an out of range PRIORITY value inside a map file will
- result in a parsing error. An out of range value set via
- MapScript or coming from a shape attribute will be clamped to the
- min/max values at rendering time. There is no expected impact on
- performance for using label priorities.
+ Labels are stored in the label cache and rendered in order of
+ priority, with the highest priority levels rendered first.
+ Specifying an out of range PRIORITY value inside a map file will
+ result in a parsing error. An out of range value set via
+ MapScript or coming from a shape attribute will be clamped to the
+ min/max values at rendering time. There is no expected impact on
+ performance for using label priorities.
- [*Attribute*] was introduced in version 5.6.
+ [*Attribute*] was introduced in version 5.6.
+ .. versionadded:: 5.0
.. index::
pair: LABEL; REPEATDISTANCE
REPEATDISTANCE [integer]
- - Introduced in version 5.6. The label will be repeated on every
- line of a multiline shape and will be repeated multiple times
- along a given line at an interval of REPEATDISTANCE pixels.
+ The label will be repeated on every line of a multiline shape and
+ will be repeated multiple times along a given line at an interval
+ of REPEATDISTANCE pixels.
- The associated RFC document for this feature is :ref:`RFC57`.
+ The associated RFC document for this feature is :ref:`RFC57`.
+ .. versionadded:: 5.6
.. index::
pair: LABEL; SHADOWCOLOR
- Color of drop shadow. An label with the same text will be rendered
+ Color of drop shadow. A label with the same text will be rendered
in this color before the main label is drawn, resulting in a
shadow effect on the the label characters. The offset of the
renderered shadow is set with SHADOWSIZE.
@@ -321,11 +333,11 @@
pair: LABEL; SHADOWSIZE
SHADOWSIZE [x][y]|[attribute][attribute]|[x][attribute]|[attribute][y]
- Shadow offset in pixels, see SHADOWCOLOR.
+ Shadow offset in pixels, see SHADOWCOLOR.
- [*Attribute*] was introduced in version 6.0, and can be used like:
+ [*Attribute*] was introduced in version 6.0, and can be used like:
- .. code-block:: mapfile
+ .. code-block:: mapfile
SHADOWSIZE 2 2
SHADOWSIZE [shadowsizeX] 2
@@ -345,10 +357,8 @@
<symbolscaledenom>` is specified for the :ref:`LAYER`), `SIZE`
gives the size of the font to be used at the map scale
1:`SYMBOLSCALEDENOM`.
- Starting from version 5.4, the value can also be a fractional
value (and not only integer).
- [*Attribute*] was introduced in version 5.0, to specify the item
name in the attribute table to use for size values. The hard
brackets [] are required. For example, if your shapefile's DBF
@@ -372,14 +382,16 @@
.. index::
pair: LABEL; STYLE
+.. _`LABEL STYLE`:
:ref:`STYLE`
- The start of a `STYLE` object.
+ The start of a :ref:`STYLE` object.
- Label specific mechanisms of the STYLE object are the
+ Label specific mechanisms of the :ref:`STYLE` object are the
GEOMTRANSFORM options:
GEOMTRANSFORM [labelpnt|labelpoly]
- Creates geometries that can be used for styling the label.
+ Creates a geometry that can be used for styling the label.
- labelpnt generates a point with its center at the middle of
the bounding rectangle of the text.
@@ -390,9 +402,23 @@
The resulting geometries can be styled using the mechanisms
available in the `STYLE` object.
+ Example - draw a red background rectangle for the labels
+ (i.e. billboard) with a "shadow" in gray:
+ STYLE
+ GEOMTRANSFORM 'labelpoly'
+ COLOR 153 153 153
+ OFFSET 3 2
+ END # STYLE
+ STYLE
+ COLOR 255 0 0
+ END # STYLE
.. versionadded:: 6.0
.. index::
pair: LABEL; TYPE
Modified: trunk/docs/en/mapfile/label.txt
--- trunk/docs/en/mapfile/label.txt 2011-11-30 17:28:49 UTC (rev 12831)
+++ trunk/docs/en/mapfile/label.txt 2011-11-30 23:04:00 UTC (rev 12832)
@@ -11,11 +11,13 @@
pair: LABEL; ALIGN
.. index::
pair: LABEL; ANGLE
@@ -60,18 +62,24 @@
+ .. note::
default.
+ .. note::
+ .. note::
.. index::
pair: LABEL; BUFFER
@@ -144,9 +152,8 @@
.. _MAXLENGTH:
MAXLENGTH [integer]
- characters.
@@ -156,6 +163,8 @@
.. index::
- [someattribute]"
.. index::
.. index::
SHADOWSIZE 2 2
.. index::
pair: LABEL; STYLE
+.. _`LABEL STYLE`:
:ref:`STYLE`
+ STYLE
+ COLOR 153 153 153
+ OFFSET 3 2
+ END # STYLE
+ STYLE
+ COLOR 255 0 0
+ END # STYLE
.. index::
pair: LABEL; TYPE
More information about the mapserver-commits
