[mapserver-commits] r12614 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Oct 4 06:49:59 EDT 2011
Author: tamas
Date: 2011-10-04 03:49:59 -0700 (Tue, 04 Oct 2011)
New Revision: 12614
branches/branch-5-4/mapserver/mapserver.h
branches/branch-5-4/mapserver/mapstring.c
branches/branch-5-4/mapserver/nmake.opt
Add missing strlcpy definition (#4008)
Modified: branches/branch-5-4/mapserver/mapserver.h
--- branches/branch-5-4/mapserver/mapserver.h 2011-10-03 15:59:22 UTC (rev 12613)
+++ branches/branch-5-4/mapserver/mapserver.h 2011-10-04 10:49:59 UTC (rev 12614)
@@ -1712,6 +1712,10 @@
MS_DLL_EXPORT size_t strlcat(char *dst, const char *src, size_t siz);
#endif /* NEED_STRLCAT */
+#ifdef NEED_STRLCPY
+MS_DLL_EXPORT size_t strlcpy(char *dst, const char *src, size_t siz);
+#endif /* NEED_STRLCPY */
/* in mapsymbol.c */
/* Use this function *only* with mapfile loading phase */
MS_DLL_EXPORT int loadSymbolSet(symbolSetObj *symbolset, mapObj *map);
Modified: branches/branch-5-4/mapserver/mapstring.c
--- branches/branch-5-4/mapserver/mapstring.c 2011-10-03 15:59:22 UTC (rev 12613)
+++ branches/branch-5-4/mapserver/mapstring.c 2011-10-04 10:49:59 UTC (rev 12614)
@@ -165,6 +165,66 @@
#endif
+ * Copyright (c) 1998 Todd C. Miller <Todd.Miller at courtesan.com>
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. The name of the author may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
+ * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
+ * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL
+ * THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Copy src to string dst of size siz. At most siz-1 characters
+ * will be copied. Always NUL terminates (unless siz == 0).
+ * Returns strlen(src); if retval >= siz, truncation occurred.
+size_t
+strlcpy(char *dst, const char *src, size_t siz)
+ register char *d = dst;
+ register const char *s = src;
+ register size_t n = siz;
+ /* Copy as many bytes as will fit */
+ if (n != 0 && --n != 0) {
+ do {
+ if ((*d++ = *s++) == 0)
+ break;
+ } while (--n != 0);
+ /* Not enough room in dst, add NUL and traverse rest of src */
+ if (n == 0) {
+ if (siz != 0)
+ *d = '\0'; /* NUL-terminate dst */
+ while (*s++)
+ return(s - src - 1); /* count does not include NUL */
+#endif
#ifdef NEED_STRCASESTR
* Copyright (c) 1990, 1993
Modified: branches/branch-5-4/mapserver/nmake.opt
--- branches/branch-5-4/mapserver/nmake.opt 2011-10-03 15:59:22 UTC (rev 12613)
+++ branches/branch-5-4/mapserver/nmake.opt 2011-10-04 10:49:59 UTC (rev 12614)
@@ -136,7 +136,7 @@
# following line to reflect the missing functions on your platform.
#STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
-STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT -DNEED_STRRSTR -DNEED_STRCASESTR
+STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT -DNEED_STRRSTR -DNEED_STRCASESTR -DNEED_STRLCPY
# Threading
More information about the mapserver-commits
