[mapserver-commits] r12618 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Oct 4 11:02:29 EDT 2011
Author: dmorissette
Date: 2011-10-04 08:02:28 -0700 (Tue, 04 Oct 2011)
New Revision: 12618
branches/branch-5-4/mapserver/HISTORY.TXT
branches/branch-5-4/mapserver/configure
branches/branch-5-4/mapserver/configure.in
Fix Linux build vs strlcpy (#4008)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT 2011-10-04 15:01:41 UTC (rev 12617)
+++ branches/branch-5-4/mapserver/HISTORY.TXT 2011-10-04 15:02:28 UTC (rev 12618)
@@ -81,6 +81,8 @@
- Fixed build issue with PHP_REGEX_INC in mapscript/php3/Makefile.in (#3078)
+- Fixes to support latest PROJ versions (#4008)
Version 5.4.2 (2009-07-23):
Modified: branches/branch-5-4/mapserver/configure
--- branches/branch-5-4/mapserver/configure 2011-10-04 15:01:41 UTC (rev 12617)
+++ branches/branch-5-4/mapserver/configure 2011-10-04 15:02:28 UTC (rev 12618)
@@ -4435,6 +4435,102 @@
STRINGS="-DNEED_STRLCAT $STRINGS"
fi
+echo "$as_me:$LINENO: checking for strlcpy" >&5
+echo $ECHO_N "checking for strlcpy... $ECHO_C" >&6
+if test "${ac_cv_func_strlcpy+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
+/* Define strlcpy to an innocuous variant, in case <limits.h> declares strlcpy.
+ For example, HP-UX 11i <limits.h> declares gettimeofday. */
+#define strlcpy innocuous_strlcpy
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char strlcpy (); below.
+ Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ <limits.h> exists even on freestanding compilers. */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef strlcpy
+/* Override any gcc2 internal prototype to avoid an error. */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char strlcpy ();
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined (__stub_strlcpy) || defined (__stub___strlcpy)
+choke me
+#else
+char (*f) () = strlcpy;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != strlcpy;
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } &&
+ { ac_try='test -z "$ac_c_werror_flag"
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ ac_cv_func_strlcpy=yes
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_func_strlcpy=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_strlcpy" >&5
+echo "${ECHO_T}$ac_cv_func_strlcpy" >&6
+if test $ac_cv_func_strlcpy = yes; then
+else
+ STRINGS="-DNEED_STRLCPY $STRINGS"
+fi
echo "$as_me:$LINENO: checking for vsnprintf" >&5
echo $ECHO_N "checking for vsnprintf... $ECHO_C" >&6
if test "${ac_cv_func_vsnprintf+set}" = set; then
Modified: branches/branch-5-4/mapserver/configure.in
--- branches/branch-5-4/mapserver/configure.in 2011-10-04 15:01:41 UTC (rev 12617)
+++ branches/branch-5-4/mapserver/configure.in 2011-10-04 15:02:28 UTC (rev 12618)
@@ -70,6 +70,7 @@
AC_CHECK_FUNC(strrstr, , STRINGS="-DNEED_STRRSTR $STRINGS")
AC_CHECK_FUNC(strcasestr, , STRINGS="-DNEED_STRCASESTR $STRINGS")
AC_CHECK_FUNC(strlcat, , STRINGS="-DNEED_STRLCAT $STRINGS")
+AC_CHECK_FUNC(strlcpy, , STRINGS="-DNEED_STRLCPY $STRINGS")
AC_CHECK_FUNC(vsnprintf, STRINGS="-DHAVE_VSNPRINTF $STRINGS", )
AC_SUBST(STRINGS, $STRINGS)
More information about the mapserver-commits
