[mapserver-commits] r12628 - trunk/docs/en/ogc
Thu Oct 6 12:15:03 EDT 2011
Author: aboudreault
Date: 2011-10-06 09:15:03 -0700 (Thu, 06 Oct 2011)
New Revision: 12628
   trunk/docs/en/ogc/wms_server.txt
Added a section about wms cascading
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt	2011-10-06 15:01:47 UTC (rev 12627)
+++ trunk/docs/en/ogc/wms_server.txt	2011-10-06 16:15:03 UTC (rev 12628)
@@ -1475,6 +1475,44 @@
    The angle value is in degrees clockwise.
+Cascading WMS Requests
+Currently, there are 3 requests that support wms cascading:
+- GetMap
+- GetFeatureInfo
+- GetLegendGraphic
+  Before MapServer 6.2, a GetLegendGraphic request was not cascaded. A
+  legend was returned using the layer classes. To preserve that behavior, a
+  GetLegendGraphic request will be cascaded only **if**:
+  1. The request is enabled via the *_enable_request metadatas.
+  2. The layer does not contain any class with the name property. ie:
+  .. code-block:: mapfile
+     CLASS
+       NAME "near white"
+       EXPRESSION ([red] > 200 AND [green] > 200 AND [blue] > 200)
+       STYLE
+         COLOR 0 255 0
+       END
+     END
+  This layer won't be cascaded because it contains at least a class with the property NAME set.
+.. note::
+   If you know that the external WMS server *do not* support a wms request,
+   you should disable it manually for your layer using the
+   (ows/wms)_enable_request metadata. Otherwise, you will simply get the
+   XML exception from the cascaded server.
 Sample WMS Server Mapfile
