[mapserver-commits] r12636 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Oct 7 00:01:47 EDT 2011
Author: dmorissette
Date: 2011-10-06 21:01:46 -0700 (Thu, 06 Oct 2011)
New Revision: 12636
trunk/mapserver/configure
trunk/mapserver/configure.in
Fix configure to work without explicit --with-exempi or --without-exempi
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2011-10-07 03:38:53 UTC (rev 12635)
+++ trunk/mapserver/configure 2011-10-07 04:01:46 UTC (rev 12636)
@@ -923,6 +923,7 @@
OGR required).
--with-curl-config=PATH Specify path to curl-config.
--with-kml= KML output Support (ARG=yes/no).
--with-exempi=DIR Specify path to exempi.
--with-xml2-config=PATH Specify path to xml2-config.
--with-xml-mapfile= Include xml-mapfile Support (ARG=yes/no).
@@ -12617,6 +12618,8 @@
fi
+echo "$as_me:$LINENO: checking if exempi support requested" >&5
+echo $ECHO_N "checking if exempi support requested... $ECHO_C" >&6
# Check whether --with-exempi or --without-exempi was given.
if test "${with_exempi+set}" = set; then
@@ -12624,7 +12627,7 @@
fi;
-if test "$with_exempi" != "no" ; then
+if test -n "$with_exempi" -a "$with_exempi" != "no" ; then
if test "$with_exempi" = "yes" ; then
if test "${ac_cv_header_xmp_h+set}" = set; then
@@ -13004,6 +13007,9 @@
fi
+else
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
fi
EXEMPI_ENABLED=$EXEMPI_ENABLED
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2011-10-07 03:38:53 UTC (rev 12635)
+++ trunk/mapserver/configure.in 2011-10-07 04:01:46 UTC (rev 12636)
@@ -1945,10 +1945,11 @@
dnl Exempi support
dnl ---------------------------------------------------------------------
-AC_ARG_WITH(exempi,
+AC_MSG_CHECKING(if exempi support requested)
+AC_ARG_WITH(exempi,\
[ --with-exempi=DIR Specify path to exempi.],,)
AC_CHECK_HEADER([xmp.h],,[AC_MSG_ERROR([cannot find xmp.h])])
@@ -1972,6 +1973,8 @@
AC_CHECK_LIB(exempi,xmp_init,EXEMPI_ENABLED=-DUSE_EXEMPI,,$EXEMPI_LIB)
+else
+ AC_MSG_RESULT(no)
fi
AC_SUBST(EXEMPI_ENABLED,$EXEMPI_ENABLED)
More information about the mapserver-commits
