[mapserver-commits] r12650 - in trunk/docs/en: include mapcache optimization
Sat Oct 8 13:24:05 EDT 2011
Author: tbonfort
Date: 2011-10-08 10:24:04 -0700 (Sat, 08 Oct 2011)
New Revision: 12650
   trunk/docs/en/include/labels.inc
   trunk/docs/en/mapcache/mapcache_install.txt
   trunk/docs/en/optimization/fastcgi.txt
add mod_fcgid config info
Modified: trunk/docs/en/include/labels.inc
--- trunk/docs/en/include/labels.inc	2011-10-08 17:04:39 UTC (rev 12649)
+++ trunk/docs/en/include/labels.inc	2011-10-08 17:24:04 UTC (rev 12650)
@@ -77,6 +77,10 @@
 	management                     :ref:`File Management <management>`
 	map                            :ref:`MAP <map>`
 	map_context                    :ref:`Map Context <map_context>`
+	mapcache_cache_sqlite          :ref:`MapCache Sqlite Caches <mapcache_cache_sqlite>`
+	mapcache_cache_disk            :ref:`MapCache Disk Caches <mapcache_cache_disk>`
+	mapcache_cache_memcache        :ref:`MapCache Memcache Caches <mapcache_cache_memcache>`
+	mapcache_cache_tiff            :ref:`MapCache TIFF Caches <mapcache_cache_tiff>`
 	mapcontext_cgi                 :ref:`Map Context Files <mapcontext_cgi>`
 	mapfile                        :ref:`Mapfile <mapfile>`
 	mapfile_tuning                 :ref:`Mapfile <mapfile_tuning>`
Modified: trunk/docs/en/mapcache/mapcache_install.txt
--- trunk/docs/en/mapcache/mapcache_install.txt	2011-10-08 17:04:39 UTC (rev 12649)
+++ trunk/docs/en/mapcache/mapcache_install.txt	2011-10-08 17:24:04 UTC (rev 12650)
@@ -228,6 +228,8 @@
 Sqlite is used to enable the sqlite and mbtiles cache backend. version 3.5.0 or
 newer is required.
+.. seealso:: :ref:`mapcache_cache_sqlite`
@@ -294,6 +296,8 @@
 .. code-block:: bash
    --with-tiff=/path/to/libtiff-prefix
+.. seealso:: :ref:`mapcache_cache_tiff`
 Debug Mode
@@ -319,6 +323,8 @@
    --disable-memcache
+.. seealso:: :ref:`mapcache_cache_memcache`
 Apache Module Options
@@ -356,8 +362,12 @@
    --enable-tiff-write-support
+.. seealso::
+   :ref:`mapcache_cache_tiff`
 Native MapServer Mode
Modified: trunk/docs/en/optimization/fastcgi.txt
--- trunk/docs/en/optimization/fastcgi.txt	2011-10-08 17:04:39 UTC (rev 12649)
+++ trunk/docs/en/optimization/fastcgi.txt	2011-10-08 17:24:04 UTC (rev 12650)
@@ -36,10 +36,16 @@
     *configure* command a --prefix=/usr to put it in a location that is
     already visible to ldconfig.
-2.  Assuming you are running `Apache <http://httpd.apache.org>`__, the next
-    piece you need is mod_fcgi.  Mod_fcgi depends on the version of Apache
-    you are running, so make sure to download the correct fork
-    (Apache 1.3 vs. Apache 2).
+2.  Assuming you are running `Apache <http://httpd.apache.org>`__, the next
+    piece you need is the fastcgi module. There are two fastcgi implementations
+    for apache:
+    - *mod_fcgid*: mod_fcgid is the newer and recommended way to run fastcgi
+      programs under recent apache versions. It can be downloaded from the
+      `Apache fcgid homepage <http://httpd.apache.org/mod_fcgid/>`__
+    - **deprecated** *mod_fcgi*:  Mod_fcgi depends on the version of Apache
+      you are running, so make sure to download the correct fork (Apache 1.3
+      vs. Apache 2).
 3.  The third and final piece is to compile MapServer with FastCGI support.
     This is pretty straightforward, and all you need to do is tell
@@ -48,26 +54,55 @@
-  ./configure [other options] --with-fastcgi=/usr
+  ./configure [other options] --with-fastcgi=/usr/local
 With those pieces in place, the MapServer CGI (mapserv) should now be
 FastCGI-enabled.  You can verify this by testing it on with the command line:
-  [hobu at kenyon mapserver-4.4.2]# ./mapserv -v
-  MapServer version 4.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
+  [hobu at kenyon mapserver-6.2.0]# ./mapserv -v
+  MapServer version 6.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
   SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
   SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI INPUT=EPPL7
   INPUT=SDE INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL
   INPUT=SHAPEFILE DEBUG=MSDEBUG
- Configuration
+ mod_fcgid Configuration
 1.  Modify http.conf to load the FastCGI module.
+.. code-block:: apache
+      LoadModule fcgid_module modules/mod_fcgid.so
+2.  Add an Apache handler for FastCGI applications.
+      AddHandler fcgid-script fcgi
+3.  Set FastCGI processing information
+   <IfModule mod_fcgid.c>
+      FcgidMaxProcessesPerClass 30
+      FcgidInitialEnv PROJ_LIB /usr/local/share/proj
+      FcgidInitialEnv LD_LIBRARY_PATH "/usr/local/lib:/usr/local/pgsql/lib:/usr3/pkg3/oracle9/lib"
+   </IfModule>
+ Deprecated mod_fcgi Configuration
+This section is left for reference. The recommended way to run fastcgi programs
+under apache is to use mod_fcgid, as detailed above.
+1.  Modify http.conf to load the FastCGI module.
       LoadModule fastcgi_module /usr/lib/apache/1.3/mod_fastcgi.so
@@ -87,7 +122,11 @@
       -appConnTimeout 60 -idle-timeout 60 -init-start-delay 1
       -minProcesses 2 -maxClassProcesses 20 -startDelay 5
-4.  Install a copy of the mapserv executable (originally **mapserv**
+ Common mod_fcgid/mod_fcgi Configuration
+1.  Install a copy of the mapserv executable (originally **mapserv**
     or **mapserv.exe**) into the cgi-bin directory with the extension
     **.fcgi** (ie. **mapserv.fcgi**).  Use this executable when you
     want to utilize fastcgi support.
@@ -119,7 +158,7 @@
       http://your.domain.name/cgi-bin/mapserv.fcgi?MAP=/path/to/mapfile.map
-5.  In your mapfile, set a PROCESSING directive to tell FastCGI to cache
+2.  In your mapfile, set a PROCESSING directive to tell FastCGI to cache
     the connections and layer information on all layers for which connection
     caching is desired - ie. all slow layers.
