[mapserver-commits] r12667 - trunk/docs/en/mapcache
svn at osgeo.org
svn at osgeo.org
Sun Oct 16 08:32:08 EDT 2011
Author: tbonfort
Date: 2011-10-16 05:32:08 -0700 (Sun, 16 Oct 2011)
New Revision: 12667
trunk/docs/en/mapcache/config.txt
add "photometric" to jpeg format
Modified: trunk/docs/en/mapcache/config.txt
--- trunk/docs/en/mapcache/config.txt 2011-10-16 12:28:43 UTC (rev 12666)
+++ trunk/docs/en/mapcache/config.txt 2011-10-16 12:32:08 UTC (rev 12667)
@@ -212,7 +212,16 @@
values under around 80 produce small images but with visible artifacts.
YMMV
- <quality>75</quality>
+ <quality>75</quality>
+ <!-- photometric
+ photometric interpretation of the bands created in the jpeg image.
+ default is ycbcr and produces the smallest images. can also be "rgb"
+ which ususally results in x2 or x3 image sizes.
+ <photometric>ycbcr</photometric>
</format>
<format name="PNG_BEST" type ="PNG">
<compression>best</compression>
More information about the mapserver-commits
