[mapserver-commits] r12681 - branches/branch-6-0/docs/en/output
trunk/docs/en/output
svn at osgeo.org
svn at osgeo.org
Fri Oct 21 03:47:04 EDT 2011
Author: havatv
Date: 2011-10-21 00:47:04 -0700 (Fri, 21 Oct 2011)
New Revision: 12681
branches/branch-6-0/docs/en/output/template_output.txt
trunk/docs/en/output/template_output.txt
Fixed some overfull lines in the PDF documentation (#3947) - template driven output.
Modified: branches/branch-6-0/docs/en/output/template_output.txt
--- branches/branch-6-0/docs/en/output/template_output.txt 2011-10-20 16:09:08 UTC (rev 12680)
+++ branches/branch-6-0/docs/en/output/template_output.txt 2011-10-21 07:47:04 UTC (rev 12681)
@@ -28,9 +28,10 @@
.. note::
- There are other, simpler, ways to output some of these formats using MapServer.
- However, template-driven output provides maximal flexibility and customization
- of the output, at the cost of additional complexity and configuration.
+ There are other, simpler, ways to output some of these formats
+ using MapServer. However, template-driven output provides maximal
+ flexibility and customization of the output, at the cost of
+ additional complexity and configuration.
.. index::
pair: Template-driven output; OUTPUTFORMAT
@@ -38,9 +39,9 @@
OUTPUTFORMAT Declarations
-Details of template-driven output formats are controlled by an :ref:`OUTPUTFORMAT`
-declaration. The declarations define the template file to be used, as well as
-other standard OUTPUTFORMAT options.
+Details of template-driven output formats are controlled by an
+:ref:`OUTPUTFORMAT` declaration. The declarations define the template
+file to be used, as well as other standard OUTPUTFORMAT options.
Examples:
@@ -131,7 +132,8 @@
<!-- mapserver template -->
[include src="templates/header.html"]
[resultset layer=lakes]
- ... old layer HEADER stuff goes here, if a layer has no results this block disappears...
+ ... old layer HEADER stuff goes here, if a layer has no results
+ this block disappears...
[feature]
...repeat this block for each feature in the result set...
[join name=join1]
@@ -141,7 +143,8 @@
...old layer FOOTER stuff goes here...
[/resultset]
[resulset layer=streams]
[feature]
[/feature]
@@ -156,8 +159,12 @@
<?xml version="1.0" encoding="ISO-8859-1"?>
[resultset layer=mums]
- <MapServerUserMeetings xmlns="http://localhost/ms_ogc_workshop" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://localhost/ms_ogc_workshop ./mums.xsd">
- <gml:description>This is a GML document which provides locations of all MapServer User Meeting that have taken place</gml:description>
+ <MapServerUserMeetings xmlns="http://localhost/ms_ogc_workshop"
+ xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml"
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+ xsi:schemaLocation="http://localhost/ms_ogc_workshop ./mums.xsd">
+ <gml:description>This is a GML document which provides locations of
+ all MapServer User Meeting that have taken place</gml:description>
<gml:name>MapServer User Meetings</gml:name>
<gml:boundedBy>
<gml:Envelope>
@@ -223,95 +230,104 @@
- <!--MapServer Template-->
- <?xml version="1.0" encoding="UTF-8"?>
- <kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom">
- <Document>
- <Style id="parks_highlight">
- <IconStyle>
- <scale>1.4</scale>
- <Icon>
- <href>http://maps.google.com/mapfiles/kml/shapes/parks.png</href>
- </Icon>
- <hotSpot x="0.5" y="0" xunits="fraction" yunits="fraction"/>
- </IconStyle>
- <LineStyle>
- <color>ffff5500</color>
- <width>4.2</width>
- </LineStyle>
- <PolyStyle>
- <color>aaaaaaaa</color>
- </PolyStyle>
- <BalloonStyle>
- <text>
- <![CDATA[
- <p ALIGN="center"><b>$[name]</b></p>
- $[description]
- </text>
- </BalloonStyle>
- </Style>
- <Style id="parks_normal">
- <IconStyle>
- <scale>1.2</scale>
- <Icon>
- </Icon>
- </IconStyle>
- <LineStyle>
- </LineStyle>
- <PolyStyle>
- <color>ff7fff55</color>
- </PolyStyle>
- <BalloonStyle>
- <text>
- <![CDATA[
- $[description]
- </text>
- </BalloonStyle>
- </Style>
- <StyleMap id="parks_map">
- <Pair>
- <key>normal</key>
- <styleUrl>#parks_normal</styleUrl>
- </Pair>
- <Pair>
- <key>highlight</key>
- <styleUrl>#parks_highlight</styleUrl>
- </Pair>
- </StyleMap>
- [resultset layer=parks]
- <Folder>
- <name>Parks</name>
- [feature trimlast=',' limit=1]
- <Placemark>
- <name>[NAME]</name>
- <Snippet/>
- <description>
- <![CDATA[
- <p>Year Established: [YEAR_ESTABLISHED]</p>
- <p>Area: [AREA_KILOMETERS_SQUARED] sq km</p>
- </description>
- <styleUrl>#parks_map</styleUrl>
- <ExtendedData>
- <Data name="Year Established">[YEAR_ESTABLISHED]</Data>
- <Data name="Area">[AREA_KILOMETERS_SQUARED]</Data>
- </ExtendedData>
- <MultiGeometry>
- <Point>
- <coordinates>[shplabel proj=epsg:4326 precision=10],0</coordinates>
- </Point>
- [shpxy ph="<Polygon><tessellate>1</tessellate>" pf="</Polygon>" xf="," xh=" " yh=" " yf=",0 " orh="<outerBoundaryIs><LinearRing><coordinates>" orf="</coordinates></LinearRing></outerBoundaryIs>" irh="<innerBoundaryIs><LinearRing><coordinates>" irf="</coordinates></LinearRing></innerBoundaryIs>" proj=epsg:4326 precision=10]
- </MultiGeometry>
- </Placemark>
- [/feature]
- </Folder>
- [/resultset]
- </Document>
- </kml>
+ <!--MapServer Template-->
+ <?xml version="1.0" encoding="UTF-8"?>
+ <kml xmlns="http://www.opengis.net/kml/2.2"
+ xmlns:gx="http://www.google.com/kml/ext/2.2"
+ xmlns:kml="http://www.opengis.net/kml/2.2"
+ xmlns:atom="http://www.w3.org/2005/Atom">
+ <Document>
+ <Style id="parks_highlight">
+ <IconStyle>
+ <scale>1.4</scale>
+ <Icon>
+ <href>http://maps.google.com/mapfiles/kml/shapes/parks.png</href>
+ </Icon>
+ <hotSpot x="0.5" y="0" xunits="fraction" yunits="fraction"/>
+ </IconStyle>
+ <LineStyle>
+ <color>ffff5500</color>
+ <width>4.2</width>
+ </LineStyle>
+ <PolyStyle>
+ <color>aaaaaaaa</color>
+ </PolyStyle>
+ <BalloonStyle>
+ <text>
+ <![CDATA[
+ <p ALIGN="center"><b>$[name]</b></p>
+ $[description]
+ </text>
+ </BalloonStyle>
+ </Style>
+ <Style id="parks_normal">
+ <IconStyle>
+ <scale>1.2</scale>
+ <Icon>
+ </Icon>
+ </IconStyle>
+ <LineStyle>
+ </LineStyle>
+ <PolyStyle>
+ <color>ff7fff55</color>
+ </PolyStyle>
+ <BalloonStyle>
+ <text>
+ <![CDATA[
+ $[description]
+ </text>
+ </BalloonStyle>
+ </Style>
+ <StyleMap id="parks_map">
+ <Pair>
+ <key>normal</key>
+ <styleUrl>#parks_normal</styleUrl>
+ </Pair>
+ <Pair>
+ <key>highlight</key>
+ <styleUrl>#parks_highlight</styleUrl>
+ </Pair>
+ </StyleMap>
+ [resultset layer=parks]
+ <Folder>
+ <name>Parks</name>
+ [feature trimlast=',' limit=1]
+ <Placemark>
+ <name>[NAME]</name>
+ <Snippet/>
+ <description>
+ <![CDATA[
+ <p>Year Established: [YEAR_ESTABLISHED]</p>
+ <p>Area: [AREA_KILOMETERS_SQUARED] sq km</p>
+ </description>
+ <styleUrl>#parks_map</styleUrl>
+ <ExtendedData>
+ <Data name="Year Established">[YEAR_ESTABLISHED]</Data>
+ <Data name="Area">[AREA_KILOMETERS_SQUARED]</Data>
+ </ExtendedData>
+ <MultiGeometry>
+ <Point>
+ <coordinates>[shplabel proj=epsg:4326 precision=10],0</coordinates>
+ </Point>
+ [shpxy ph="<Polygon><tessellate>1</tessellate>" pf="</Polygon>"
+ xf="," xh=" " yh=" " yf=",0 "
+ orh="<outerBoundaryIs><LinearRing><coordinates>"
+ orf="</coordinates></LinearRing></outerBoundaryIs>"
+ irh="<innerBoundaryIs><LinearRing><coordinates>"
+ irf="</coordinates></LinearRing></innerBoundaryIs>"
+ proj=epsg:4326 precision=10]
+ </MultiGeometry>
+ </Placemark>
+ [/feature]
+ </Folder>
+ [/resultset]
+ </Document>
+ </kml>
Modified: trunk/docs/en/output/template_output.txt
--- trunk/docs/en/output/template_output.txt 2011-10-20 16:09:08 UTC (rev 12680)
+++ trunk/docs/en/output/template_output.txt 2011-10-21 07:47:04 UTC (rev 12681)
@@ -28,9 +28,10 @@
.. note::
.. index::
@@ -38,9 +39,9 @@
Examples:
@@ -131,7 +132,8 @@
[feature]
[join name=join1]
@@ -141,7 +143,8 @@
[/resultset]
[feature]
[/feature]
<gml:boundedBy>
<gml:Envelope>
- <Document>
- <IconStyle>
- <Icon>
- </Icon>
- </IconStyle>
- <LineStyle>
- </LineStyle>
- <PolyStyle>
- </PolyStyle>
- <BalloonStyle>
- <text>
- <![CDATA[
- $[description]
- </text>
- </BalloonStyle>
- </Style>
- <IconStyle>
- <Icon>
- </Icon>
- </IconStyle>
- <LineStyle>
- </LineStyle>
- <PolyStyle>
- </PolyStyle>
- <BalloonStyle>
- <text>
- <![CDATA[
- $[description]
- </text>
- </BalloonStyle>
- </Style>
- <Pair>
- <key>normal</key>
- </Pair>
- <Pair>
- </Pair>
- </StyleMap>
- <Folder>
- <Placemark>
- <Snippet/>
- <description>
- <![CDATA[
- </description>
- <ExtendedData>
- </ExtendedData>
- <MultiGeometry>
- <Point>
- </Point>
- </MultiGeometry>
- </Placemark>
- [/feature]
- </Folder>
- [/resultset]
- </Document>
- </kml>
+ <Document>
+ <IconStyle>
+ <Icon>
+ </Icon>
+ </IconStyle>
+ <LineStyle>
+ </LineStyle>
+ <PolyStyle>
+ </PolyStyle>
+ <BalloonStyle>
+ <text>
+ <![CDATA[
+ $[description]
+ </text>
+ </BalloonStyle>
+ </Style>
+ <IconStyle>
+ <Icon>
+ </Icon>
+ </IconStyle>
+ <LineStyle>
+ </LineStyle>
+ <PolyStyle>
+ </PolyStyle>
+ <BalloonStyle>
+ <text>
+ <![CDATA[
+ $[description]
+ </text>
+ </BalloonStyle>
+ </Style>
+ <Pair>
+ <key>normal</key>
+ </Pair>
+ <Pair>
+ </Pair>
+ </StyleMap>
+ <Folder>
+ <Placemark>
+ <Snippet/>
+ <description>
+ <![CDATA[
+ </description>
+ <ExtendedData>
+ </ExtendedData>
+ <MultiGeometry>
+ <Point>
+ </Point>
+ </MultiGeometry>
+ </Placemark>
+ [/feature]
+ </Folder>
+ [/resultset]
+ </Document>
+ </kml>
More information about the mapserver-commits
