[mapserver-commits] r12684 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Oct 21 08:05:47 EDT 2011
Author: tbonfort
Date: 2011-10-21 05:05:47 -0700 (Fri, 21 Oct 2011)
New Revision: 12684
trunk/mapserver/mapcache/src/service_tms.c
allow vertical tile merging for the tms service
Modified: trunk/mapserver/mapcache/src/service_tms.c
--- trunk/mapserver/mapcache/src/service_tms.c 2011-10-21 09:06:44 UTC (rev 12683)
+++ trunk/mapserver/mapcache/src/service_tms.c 2011-10-21 12:05:47 UTC (rev 12684)
@@ -162,6 +162,7 @@
const char *cpathinfo, apr_table_t *params, mapcache_cfg *config) {
int index = 0;
char *last, *key, *endptr;
+ char *sTileset = NULL;
mapcache_tileset *tileset = NULL;
mapcache_grid_link *grid_link = NULL;
char *pathinfo = NULL;
@@ -185,44 +186,7 @@
break;
case 2: /* layer name */
- tileset = mapcache_configuration_get_tileset(config,key);
- if(!tileset) {
- /*tileset not found directly, test if it was given as "name at grid" notation*/
- char *tname = apr_pstrdup(ctx->pool,key);
- char *gname = tname;
- int i;
- while(*gname) {
- if(*gname == '@') {
- *gname = '\0';
- gname++;
- break;
- gname++;
- if(!gname) {
- ctx->set_error(ctx,404, "received tms request with invalid layer %s", key);
- return;
- tileset = mapcache_configuration_get_tileset(config,tname);
- if(!tileset) {
- ctx->set_error(ctx,404, "received tms request with invalid layer %s", tname);
- return;
- for(i=0;i<tileset->grid_links->nelts;i++) {
- mapcache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,i,mapcache_grid_link*);
- if(!strcmp(sgrid->grid->name,gname)) {
- grid_link = sgrid;
- break;
- if(!grid_link) {
- ctx->set_error(ctx,404, "received tms request with invalid grid %s", gname);
- return;
- } else {
- grid_link = APR_ARRAY_IDX(tileset->grid_links,0,mapcache_grid_link*);
+ sTileset = apr_pstrdup(ctx->pool,key);
break;
case 3:
z = (int)strtol(key,&endptr,10);
@@ -254,18 +218,78 @@
if(index == 5) {
mapcache_request_get_tile *req = (mapcache_request_get_tile*)apr_pcalloc(ctx->pool,sizeof(mapcache_request_get_tile));
req->request.type = MAPCACHE_REQUEST_GET_TILE;
- req->ntiles = 1;
- req->tiles = (mapcache_tile**)apr_pcalloc(ctx->pool,sizeof(mapcache_tile*));
- req->tiles[0] = mapcache_tileset_tile_create(ctx->pool, tileset, grid_link);
- req->tiles[0]->x = x;
- if(((mapcache_service_tms*)this)->reverse_y) {
- req->tiles[0]->y = grid_link->grid->levels[z]->maxy - y - 1;
- } else {
- req->tiles[0]->y = y;
+ char *gridname = sTileset; /*hijack the char* pointer while counting the number of commas */
+ while(*gridname) {
+ if(*gridname == ',') req->ntiles++;
+ gridname++;
- req->tiles[0]->z = z;
- mapcache_tileset_tile_validate(ctx,req->tiles[0]);
- GC_CHECK_ERROR(ctx);
+ req->tiles = (mapcache_tile**)apr_pcalloc(ctx->pool,(req->ntiles+1) * sizeof(mapcache_tile*));
+ /* reset the hijacked variables back to default value */
+ gridname = NULL;
+ req->ntiles = 0;
+ for (key = apr_strtok(sTileset, ";", &last); key != NULL;
+ key = apr_strtok(NULL, ";", &last)) {
+ tileset = mapcache_configuration_get_tileset(config,key);
+ if(!tileset) {
+ /*tileset not found directly, test if it was given as "name at grid" notation*/
+ char *tname = apr_pstrdup(ctx->pool,key);
+ char *gname = tname;
+ int i;
+ while(*gname) {
+ if(*gname == '@') {
+ *gname = '\0';
+ gname++;
+ break;
+ gname++;
+ if(!gname) {
+ ctx->set_error(ctx,404, "received tms request with invalid layer %s", key);
+ return;
+ tileset = mapcache_configuration_get_tileset(config,tname);
+ if(!tileset) {
+ ctx->set_error(ctx,404, "received tms request with invalid layer %s", tname);
+ return;
+ for(i=0;i<tileset->grid_links->nelts;i++) {
+ mapcache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,i,mapcache_grid_link*);
+ if(!strcmp(sgrid->grid->name,gname)) {
+ grid_link = sgrid;
+ break;
+ if(!grid_link) {
+ ctx->set_error(ctx,404, "received tms request with invalid grid %s", gname);
+ return;
+ } else {
+ grid_link = APR_ARRAY_IDX(tileset->grid_links,0,mapcache_grid_link*);
+ if(!gridname) {
+ gridname = grid_link->grid->name;
+ } else {
+ if(strcmp(gridname,grid_link->grid->name)) {
+ ctx->set_error(ctx,400,"received tms request with conflicting grids %s and %s",
+ gridname,grid_link->grid->name);
+ return;
+ req->tiles[req->ntiles] = mapcache_tileset_tile_create(ctx->pool, tileset, grid_link);
+ req->tiles[req->ntiles]->x = x;
+ if(((mapcache_service_tms*)this)->reverse_y) {
+ req->tiles[req->ntiles]->y = grid_link->grid->levels[z]->maxy - y - 1;
+ } else {
+ req->tiles[req->ntiles]->y = y;
+ req->tiles[req->ntiles]->z = z;
+ mapcache_tileset_tile_validate(ctx,req->tiles[req->ntiles]);
+ req->ntiles++;
+ GC_CHECK_ERROR(ctx);
*request = (mapcache_request*)req;
return;
} else if(index<3) {
More information about the mapserver-commits
