[mapserver-commits] r12689 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Sun Oct 23 11:54:45 EDT 2011
Author: tamas
Date: 2011-10-23 08:54:45 -0700 (Sun, 23 Oct 2011)
New Revision: 12689
trunk/docs/en/mapfile/union.txt
Document the processing options with the union layer (#3900)
Modified: trunk/docs/en/mapfile/union.txt
--- trunk/docs/en/mapfile/union.txt 2011-10-23 15:45:03 UTC (rev 12688)
+++ trunk/docs/en/mapfile/union.txt 2011-10-23 15:54:45 UTC (rev 12689)
@@ -116,6 +116,29 @@
source layers to the union layer if requested. (for more information
on projections in MapServer refer to :ref:`PROJECTION`)
+Supported Processing Options
+The following processing options can be used with the union layers:
+UNION_STATUS_CHECK (TRUE or FALSE)
+ Controls whether the status of the source layes should be checked and
+ the invisible layers (STATUS=OFF) should be skipped. Default value is FALSE.
+UNION_SCALE_CHECK (TRUE or FALSE)
+ Controls whether the scale range of the source layes should be checked and
+ the invisible layers (falling outside of the scale range and zoom range)
+ should be skipped. Default value is TRUE.
+UNION_SRCLAYER_CLOSE_CONNECTION
+ Override the connection pool setting of the source layers.
+ By introducing this setting we alter the current behaviour which is equivalent to:
+ UNION_SRCLAYER_CLOSE_CONNECTION=ALWAYS
Examples
More information about the mapserver-commits
