[mapserver-commits] r12692 - trunk/docs/en/mapcache
svn at osgeo.org
svn at osgeo.org
Mon Oct 24 09:02:03 EDT 2011
Author: tbonfort
Date: 2011-10-24 06:02:03 -0700 (Mon, 24 Oct 2011)
New Revision: 12692
trunk/docs/en/mapcache/config.txt
document <lock_retry>
Modified: trunk/docs/en/mapcache/config.txt
--- trunk/docs/en/mapcache/config.txt 2011-10-24 11:35:13 UTC (rev 12691)
+++ trunk/docs/en/mapcache/config.txt 2011-10-24 13:02:03 UTC (rev 12692)
@@ -513,6 +513,12 @@
this location should be writable by the apache user
<lock_dir>/tmp</lock_dir>
+ interval in microseconds to sleep before checking that a lockfile is still present.
+ default is 1/100th of a second (i.e. 10000 microseconds)
+ <lock_retry>10000</lock_retry>
<!-- log_level
For CGI/FastCGI only - For the apache module use the httpd.conf
More information about the mapserver-commits
