[mapserver-commits] r13041 - sandbox/sdlime/rfc-77
Sun Feb 5 13:55:12 EST 2012
Author: sdlime
Date: 2012-02-05 10:55:12 -0800 (Sun, 05 Feb 2012)
New Revision: 13041
   sandbox/sdlime/rfc-77/mapdraw.c
   sandbox/sdlime/rfc-77/maplabel.c
   sandbox/sdlime/rfc-77/mapserver.h
Remove text attribute of labelCacheMemberObj. That information is now stored at the labelObj level.
Modified: sandbox/sdlime/rfc-77/mapdraw.c
--- sandbox/sdlime/rfc-77/mapdraw.c	2012-02-05 01:06:25 UTC (rev 13040)
+++ sandbox/sdlime/rfc-77/mapdraw.c	2012-02-05 18:55:12 UTC (rev 13041)
@@ -2334,7 +2334,7 @@
 	    if(!cachePtr->status)
               continue;
-            msDrawTextLine(image, cachePtr->text, labelPtr, cachePtr->labelpath, &(map->fontset), layerPtr->scalefactor); /* Draw the curved label */
+            msDrawTextLine(image, labelPtr->annotext, labelPtr, cachePtr->labelpath, &(map->fontset), layerPtr->scalefactor); /* Draw the curved label */
           } else { /* point-based label */
             int drawLabelText=MS_TRUE; // unused
Modified: sandbox/sdlime/rfc-77/maplabel.c
--- sandbox/sdlime/rfc-77/maplabel.c	2012-02-05 01:06:25 UTC (rev 13040)
+++ sandbox/sdlime/rfc-77/maplabel.c	2012-02-05 18:55:12 UTC (rev 13041)
@@ -634,68 +634,77 @@
                                 labelCacheMemberObj *cachePtr, int current_priority,
                                 int current_label, int mindistance, double label_size)
-    int i, p;
+  int i, p;
+  labelCacheMemberObj *curCachePtr=NULL;
-    cachePtr->status = MS_TRUE; /* by default */
+  cachePtr->status = MS_TRUE; /* by default */
-    /* Check against image bounds first
-    ** Pass mapwidth=-1 to skip this test
-    if(!labelPtr->partials && mapwidth > 0 && mapheight > 0) {
-        if(labelInImage(mapwidth, mapheight, cachePtr->poly, buffer) == MS_FALSE) {
-	    cachePtr->status = MS_FALSE;
-            return;
+  /* Check against image bounds first
+  ** Pass mapwidth=-1 to skip this test
+  if(!labelPtr->partials && mapwidth > 0 && mapheight > 0) {
+    if(labelInImage(mapwidth, mapheight, cachePtr->poly, buffer) == MS_FALSE) {
+      cachePtr->status = MS_FALSE;
+      return;
-    /* Compare against all rendered markers from this priority level and higher.
-    ** Labels can overlap their own marker and markers from lower priority levels
-    for (p=current_priority; p < MS_MAX_LABEL_PRIORITY; p++) {
-        labelCacheSlotObj *markerslot;
-        markerslot = &(labelcache->slots[p]);
+  /* Compare against all rendered markers from this priority level and higher.
+  ** Labels can overlap their own marker and markers from lower priority levels
+  for (p=current_priority; p < MS_MAX_LABEL_PRIORITY; p++) {
+    labelCacheSlotObj *markerslot;
+    markerslot = &(labelcache->slots[p]);
-        for ( i = 0; i < markerslot->nummarkers; i++ ) {
-            if ( !(p == current_priority && current_label == markerslot->markers[i].id) ) {  /* labels can overlap their own marker */
-                if ( intersectLabelPolygons(markerslot->markers[i].poly, cachePtr->poly ) == MS_TRUE ) {
-                    cachePtr->status = MS_FALSE;  /* polys intersect */
-                    return;
+    for ( i = 0; i < markerslot->nummarkers; i++ ) {
+      if ( !(p == current_priority && current_label == markerslot->markers[i].id) ) {  /* labels can overlap their own marker */
+        if ( intersectLabelPolygons(markerslot->markers[i].poly, cachePtr->poly ) == MS_TRUE ) {
+          cachePtr->status = MS_FALSE;  /* polys intersect */
+          return;
-    /* compare against rendered labels */
-    i = current_label+1;
+  /* compare against rendered labels */
+  i = current_label+1;
-    for(p=current_priority; p<MS_MAX_LABEL_PRIORITY; p++) {
-        labelCacheSlotObj *cacheslot;
-        cacheslot = &(labelcache->slots[p]);
+  for(p=current_priority; p<MS_MAX_LABEL_PRIORITY; p++) {
+    labelCacheSlotObj *cacheslot;
+    cacheslot = &(labelcache->slots[p]);
-        for(  ; i < cacheslot->numlabels; i++) {
-            if(cacheslot->labels[i].status == MS_TRUE) { /* compare bounding polygons and check for duplicates */
-                /* We add the label_size to the mindistance value when comparing because we do want the mindistance
-                   value between the labels and not only from point to point. */
-                if(label_size > 0 && (mindistance != -1) &&
-                   (cachePtr->layerindex == cacheslot->labels[i].layerindex) && (cachePtr->classindex == cacheslot->labels[i].classindex) &&
-                   (strcmp(cachePtr->text,cacheslot->labels[i].text) == 0) &&
-                   (msDistancePointToPoint(&(cachePtr->point), &(cacheslot->labels[i].point)) <= (mindistance + label_size))) { /* label is a duplicate */
-                    return;
+    for(  ; i < cacheslot->numlabels; i++) {
+      curCachePtr = &(cacheslot->labels[i]);
-                if(intersectLabelPolygons(cacheslot->labels[i].poly, cachePtr->poly) == MS_TRUE) { /* polys intersect */
-                    return;
-        } /* i */
+      if(curCachePtr->status == MS_TRUE) { /* compare bounding polygons and check for duplicates */
-        i = 0; /* Start over with 1st label of next slot */
-    } /* p */
+	** Note 1: We add the label_size to the mindistance value when comparing because we do want the mindistance
+        ** value between the labels and not only from point to point.
+        ** Note 2: We only check the first label (could be multiples (RFC 77)) since that is *by far* the most common
+        ** use case. Could change in the future but it's not worth the overhead at this point.
+        if(label_size > 0 && (mindistance != -1) &&
+          (cachePtr->layerindex == curCachePtr->layerindex) &&
+          (cachePtr->classindex == curCachePtr->classindex) &&
+          (strcmp(cachePtr->labels[0].annotext, curCachePtr->labels[0].annotext) == 0) &&
+          (msDistancePointToPoint(&(cachePtr->point), &(curCachePtr->point)) <= (mindistance + label_size))) { /* label is a duplicate */
+          return;
+        if(intersectLabelPolygons(cacheslot->labels[i].poly, cachePtr->poly) == MS_TRUE) { /* polys intersect */
+          return;
+    } /* i */
+    i = 0; /* Start over with 1st label of next slot */
+  } /* p */
 /* msGetLabelCacheMember()
 ** Returns label cache members by index, making all members of the cache
Modified: sandbox/sdlime/rfc-77/mapserver.h
--- sandbox/sdlime/rfc-77/mapserver.h	2012-02-05 01:06:25 UTC (rev 13040)
+++ sandbox/sdlime/rfc-77/mapserver.h	2012-02-05 18:55:12 UTC (rev 13041)
@@ -1064,7 +1064,6 @@
 %immutable;
 #endif /* SWIG */
 typedef struct {
-  char *text; /* RFC 77: remove */
   double featuresize;
   styleObj *styles; /* copied from the classObj, only present if there is a marker to be drawn */
