[mapserver-commits] r13048 - sandbox/sdlime/rfc-77
svn at osgeo.org
svn at osgeo.org
Sun Feb 5 23:43:29 EST 2012
Author: sdlime
Date: 2012-02-05 20:43:29 -0800 (Sun, 05 Feb 2012)
New Revision: 13048
sandbox/sdlime/rfc-77/mapfile.c
sandbox/sdlime/rfc-77/maputil.c
Created static evalTextExpression() function for use in a couple of places in msShapeGetAnnotation().
Modified: sandbox/sdlime/rfc-77/mapfile.c
--- sandbox/sdlime/rfc-77/mapfile.c 2012-02-05 22:21:13 UTC (rev 13047)
+++ sandbox/sdlime/rfc-77/mapfile.c 2012-02-06 04:43:29 UTC (rev 13048)
@@ -1683,9 +1683,9 @@
msFree(label->bindings[i].item);
freeExpression(&(label->expression));
- freeExpression(&(label->text)); // NEXT! writeLabel()
+ freeExpression(&(label->text)); // RFC TODO: writeLabel()
- /* RFC 77 TODO: free book keeping vars */
+ /* free book keeping vars associated with the label cache */
msFree(label->annotext);
if(label->annopoly) {
msFreeShape(label->annopoly);
Modified: sandbox/sdlime/rfc-77/maputil.c
--- sandbox/sdlime/rfc-77/maputil.c 2012-02-05 22:21:13 UTC (rev 13047)
+++ sandbox/sdlime/rfc-77/maputil.c 2012-02-06 04:43:29 UTC (rev 13048)
@@ -579,8 +579,63 @@
return(-1); /* no match */
+static char *evalTextExpression(expressionObj *expr, shapeObj *shape) {
+ char *result=NULL;
+ if(!expr->string) return result; /* nothing to do */
+ switch(expr->type) {
+ case(MS_STRING):
+ char *target=NULL;
+ tokenListNodeObjPtr node=NULL;
+ tokenListNodeObjPtr nextNode=NULL;
+ result = msStrdup(expr->string);
+ node = expr->tokens;
+ if(node) {
+ while(node != NULL) {
+ nextNode = node->next;
+ if(node->token == MS_TOKEN_BINDING_DOUBLE || node->token == MS_TOKEN_BINDING_INTEGER || node->token == MS_TOKEN_BINDING_STRING || node->token == MS_TOKEN_BINDING_TIME) {
+ target = (char *) msSmallMalloc(strlen(node->tokenval.bindval.item) + 3);
+ sprintf(target, "[%s]", node->tokenval.bindval.item);
+ result = msReplaceSubstring(result, target, shape->values[node->tokenval.bindval.index]);
+ msFree(target);
+ node = nextNode;
+ break;
+ case(MS_EXPRESSION):
+ int status;
+ parseObj p;
+ p.shape = shape;
+ p.expr = expr;
+ p.expr->curtoken = p.expr->tokens; /* reset */
+ p.type = MS_PARSE_TYPE_STRING;
+ status = yyparse(&p);
+ if (status != 0) {
+ msSetError(MS_PARSEERR, "Failed to process text expression: %s", "evalTextExpression", expr->string);
+ return NULL;
+ result = p.result.strval;
+ break;
+ default:
+ break;
+ return result;
int msShapeGetAnnotation(layerObj *layer, shapeObj *shape) {
- char *tmpstr;
int i, j;
/* RFC 77 TODO: check and throw some errors here... */
@@ -592,64 +647,19 @@
/* RFC 77 TODO: will evaluate label scale limits here... */
/* RFC 77 TODO: will evaluate label expressions here... */
- tmpstr = NULL; /* initialize */
- if(layer->class[i]->text.string) { /* RFC 77 TODO: will check for a label text value first, then class text and finally try labelitem */
- switch(layer->class[i]->text.type) {
- case(MS_STRING):
- char *target=NULL;
- tokenListNodeObjPtr node=NULL;
- tokenListNodeObjPtr nextNode=NULL;
+ msFree(layer->class[i]->labels[j]->annotext);
+ layer->class[i]->labels[j]->annotext = NULL;
- tmpstr = msStrdup(layer->class[i]->text.string);
- node = layer->class[i]->text.tokens;
- if(node) {
- while(node != NULL) {
- nextNode = node->next;
- if(node->token == MS_TOKEN_BINDING_DOUBLE || node->token == MS_TOKEN_BINDING_INTEGER || node->token == MS_TOKEN_BINDING_STRING || node->token == MS_TOKEN_BINDING_TIME) {
- target = (char *) msSmallMalloc(strlen(node->tokenval.bindval.item) + 3);
- sprintf(target, "[%s]", node->tokenval.bindval.item);
- tmpstr = msReplaceSubstring(tmpstr, target, shape->values[node->tokenval.bindval.index]);
- msFree(target);
- node = nextNode;
- break;
- case(MS_EXPRESSION):
- int status;
- parseObj p;
- p.shape = shape;
- p.expr = &(layer->class[i]->text);
- p.expr->curtoken = p.expr->tokens; /* reset */
- p.type = MS_PARSE_TYPE_STRING;
- status = yyparse(&p);
- if (status != 0) {
- msSetError(MS_PARSEERR, "Failed to process text expression: %s", "msShapeGetAnnotation", layer->class[j]->text.string);
- return MS_FAILURE;
- tmpstr = p.result.strval;
- break;
- default:
- break;
+ if(layer->class[i]->labels[j]->text.string) { /* RFC 77 TODO: will check for a label text value first, then class text and finally try labelitem */
+ layer->class[i]->labels[j]->annotext = evalTextExpression(&(layer->class[i]->labels[j]->text), shape);
+ } if(layer->class[i]->text.string) {
+ layer->class[i]->labels[j]->annotext = evalTextExpression(&(layer->class[i]->text), shape);
} else {
if (shape->values && layer->labelitemindex >= 0)
- tmpstr = msStrdup(shape->values[layer->labelitemindex]);
+ layer->class[i]->labels[j]->annotext = msStrdup(shape->values[layer->labelitemindex]);
else
- tmpstr = msStrdup(shape->text); /* last resort but common with iniline features */
+ layer->class[i]->labels[j]->annotext = msStrdup(shape->text); /* last resort but common with iniline features */
- msFree(layer->class[i]->labels[j]->annotext);
- layer->class[i]->labels[j]->annotext = tmpstr;
return MS_SUCCESS;
More information about the mapserver-commits
