[mapserver-commits] r13055 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Mon Feb 6 12:26:26 EST 2012
Author: tbonfort
Date: 2012-02-06 09:26:25 -0800 (Mon, 06 Feb 2012)
New Revision: 13055
trunk/mapserver/mapcache/configure
trunk/mapserver/mapcache/configure.in
fix stray -ltiff in lib checks
Modified: trunk/mapserver/mapcache/configure
--- trunk/mapserver/mapcache/configure 2012-02-06 17:21:15 UTC (rev 13054)
+++ trunk/mapserver/mapcache/configure 2012-02-06 17:26:25 UTC (rev 13055)
@@ -13003,14 +13003,13 @@
test -f $TIFF_DIR/tiffio.h && TIFF_INCLUDE="$TIFF_DIR"
if test -n "$TIFF_LIBDIR" ; then
- TIFF_LIB="-L$TIFF_LIBDIR -ltiff"
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for TIFFReadScanline in -ltiff" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for TIFFReadScanline in -ltiff" >&5
$as_echo_n "checking for TIFFReadScanline in -ltiff... " >&6; }
if ${ac_cv_lib_tiff_TIFFReadScanline+:} false; then :
$as_echo_n "(cached) " >&6
else
ac_check_lib_save_LIBS=$LIBS
-LIBS="-ltiff "$TIFF_LIB" $LIBS"
+LIBS="-ltiff -L$TIFF_LIBDIR -ltiff $LIBS"
cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h. */
@@ -13041,12 +13040,7 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_tiff_TIFFReadScanline" >&5
$as_echo "$ac_cv_lib_tiff_TIFFReadScanline" >&6; }
if test "x$ac_cv_lib_tiff_TIFFReadScanline" = xyes; then :
- cat >>confdefs.h <<_ACEOF
-#define HAVE_LIBTIFF 1
-_ACEOF
- LIBS="-ltiff $LIBS"
+ TIFF_LIB=-L$TIFF_LIBDIR -ltiff
else
as_fn_error $? "failed to link against libtiff" "$LINENO" 5
fi
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2012-02-06 17:21:15 UTC (rev 13054)
+++ trunk/mapserver/mapcache/configure.in 2012-02-06 17:26:25 UTC (rev 13055)
@@ -716,10 +716,9 @@
- AC_CHECK_LIB(tiff, TIFFReadScanline,,
+ AC_CHECK_LIB(tiff, TIFFReadScanline,[TIFF_LIB=[-L$TIFF_LIBDIR -ltiff]],
AC_MSG_ERROR([failed to link against libtiff]),
- "$TIFF_LIB")
+ [-L$TIFF_LIBDIR -ltiff])
AC_MSG_RESULT([ using libtiff from $TIFF_LIB])
else
AC_MSG_WARN([cannot find tiff lib in $TIFF_DIR])
More information about the mapserver-commits
