[mapserver-commits] r13058 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 6 12:52:45 EST 2012
Author: tbonfort
Date: 2012-02-06 09:52:45 -0800 (Mon, 06 Feb 2012)
New Revision: 13058
trunk/mapserver/mapprimitive.c
keep at least 4 vertices when doing polygon simplification (#4143)
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c 2012-02-06 17:43:11 UTC (rev 13057)
+++ trunk/mapserver/mapprimitive.c 2012-02-06 17:52:45 UTC (rev 13058)
@@ -887,7 +887,7 @@
* least its first, second and last point
for(i=0; i<shape->numlines; i++) { /* for each part */
- if(shape->line[i].numpoints<3) {
+ if(shape->line[i].numpoints<4) {
shape->line[i].numpoints=0;
continue; /*skip degenerate lines*/
@@ -897,8 +897,8 @@
point[0].y = MS_MAP2IMAGE_Y_IC_DBL(point[0].y, extent.maxy, inv_cs);
point[1].x = MS_MAP2IMAGE_X_IC_DBL(point[1].x, extent.minx, inv_cs);
point[1].y = MS_MAP2IMAGE_Y_IC_DBL(point[1].y, extent.maxy, inv_cs);
- beforelast=shape->line[i].numpoints-1;
- for(j=2,k=2; j < beforelast; j++ ) { /*loop from second point to first-before-last point*/
+ beforelast=shape->line[i].numpoints-2;
+ for(j=2,k=2; j < beforelast; j++ ) { /*loop from second point to second-before-last point*/
point[k].x = MS_MAP2IMAGE_X_IC_DBL(point[j].x, extent.minx, inv_cs);
point[k].y = MS_MAP2IMAGE_Y_IC_DBL(point[j].y, extent.maxy, inv_cs);
dx=(point[k].x-point[k-1].x);
@@ -906,10 +906,13 @@
if(dx*dx+dy*dy>1)
k++;
- /*always keep last point*/
+ /*always keep last two points (the last point is the repetition of the
+ * first one */
- shape->line[i].numpoints=k+1;
+ point[k+1].x = MS_MAP2IMAGE_X_IC_DBL(point[j+1].x, extent.minx, inv_cs);
+ point[k+1].y = MS_MAP2IMAGE_Y_IC_DBL(point[j+1].y, extent.maxy, inv_cs);
+ shape->line[i].numpoints = k+2;
ok = 1;
More information about the mapserver-commits
