[mapserver-commits] r13064 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 6 14:39:02 EST 2012
Author: tbonfort
Date: 2012-02-06 11:39:02 -0800 (Mon, 06 Feb 2012)
New Revision: 13064
trunk/mapserver/maplabel.c
trunk/mapserver/mapserver.h
fix const char* warnings (#4114)
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2012-02-06 19:29:48 UTC (rev 13063)
+++ trunk/mapserver/maplabel.c 2012-02-06 19:39:02 UTC (rev 13064)
@@ -700,7 +700,7 @@
int msGetTruetypeTextBBox(rendererVTableObj *renderer, char* fontstring, fontSetObj *fontset, double size, char *string, rectObj *rect, double **advances) {
- const char *lookedUpFonts[MS_MAX_LABEL_FONTS];
+ char *lookedUpFonts[MS_MAX_LABEL_FONTS];
int numfonts;
if(MS_FAILURE == msFontsetLookupFonts(fontstring, &numfonts, fontset, lookedUpFonts))
return MS_FAILURE;
@@ -813,7 +813,7 @@
return font;
-int msFontsetLookupFonts(char* fontstring, int *numfonts, fontSetObj *fontset, const char **lookedUpFonts) {
+int msFontsetLookupFonts(char* fontstring, int *numfonts, fontSetObj *fontset, char **lookedUpFonts) {
char *start,*ptr;
*numfonts = 0;
start = ptr = fontstring;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2012-02-06 19:29:48 UTC (rev 13063)
+++ trunk/mapserver/mapserver.h 2012-02-06 19:39:02 UTC (rev 13064)
@@ -1988,7 +1988,7 @@
MS_DLL_EXPORT int msInitFontSet(fontSetObj *fontset);
MS_DLL_EXPORT int msFreeFontSet(fontSetObj *fontset);
MS_DLL_EXPORT char *msFontsetLookupFont(fontSetObj *fontset, char *fontKey);
-MS_DLL_EXPORT int msFontsetLookupFonts(char* fontstring, int *numfonts, fontSetObj *fontset, const char **lookedUpFonts);
+MS_DLL_EXPORT int msFontsetLookupFonts(char* fontstring, int *numfonts, fontSetObj *fontset, char **lookedUpFonts);
MS_DLL_EXPORT char *msTransformLabelText(mapObj *map, imageObj* image, labelObj *label, char *text);
MS_DLL_EXPORT int msGetTruetypeTextBBox(rendererVTableObj *renderer, char* fontstring, fontSetObj *fontset, double size, char *string, rectObj *rect, double **advances);
@@ -2613,8 +2613,8 @@
* labelStyleObj
typedef struct {
- /* full path to truetype font file */
- const char* fonts[MS_MAX_LABEL_FONTS];
+ /* full paths to truetype font file */
+ char* fonts[MS_MAX_LABEL_FONTS];
int numfonts;
double size;
double rotation;
More information about the mapserver-commits
