[mapserver-commits] r13066 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 6 15:14:56 EST 2012
Author: aboudreault
Date: 2012-02-06 12:14:55 -0800 (Mon, 06 Feb 2012)
New Revision: 13066
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maplexer.c
trunk/mapserver/maplexer.l
Fixed lexer buffer size issue with single quotes in a string (#4175)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2012-02-06 19:49:21 UTC (rev 13065)
+++ trunk/mapserver/HISTORY.TXT 2012-02-06 20:14:55 UTC (rev 13066)
@@ -15,6 +15,8 @@
Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Fixed lexer buffer size issue with single quotes in a string (#4175)
- WFS Quote Escape issue (#4087)
- Raster layer fails to be drawn if the window is less than half a pixel (#4172)
Modified: trunk/mapserver/maplexer.c
--- trunk/mapserver/maplexer.c 2012-02-06 19:49:21 UTC (rev 13065)
+++ trunk/mapserver/maplexer.c 2012-02-06 20:14:55 UTC (rev 13066)
@@ -4130,6 +4130,8 @@
++msyystring_size;
*msyystring_buffer_ptr++ = *msyytext;
if (strlen(msyytext)==2) {
+ MS_LEXER_STRING_REALLOC(msyystring_buffer, msyystring_size,
+ msyystring_buffer_size, msyystring_buffer_ptr);
++msyystring_size;
*msyystring_buffer_ptr++ = msyytext[1];
@@ -4138,7 +4140,7 @@
YY_BREAK
case 311:
YY_RULE_SETUP
-#line 613 "maplexer.l"
+#line 615 "maplexer.l"
@@ -4153,7 +4155,7 @@
case 312:
/* rule 312 can match eol */
YY_RULE_SETUP
-#line 624 "maplexer.l"
+#line 626 "maplexer.l"
char *yptr = msyytext;
while ( *yptr ) {
@@ -4167,7 +4169,7 @@
case 313:
/* rule 313 can match eol */
YY_RULE_SETUP
-#line 634 "maplexer.l"
+#line 636 "maplexer.l"
msyytext++;
msyytext[strlen(msyytext)-1] = '\0';
@@ -4195,7 +4197,7 @@
YY_BREAK
case 314:
YY_RULE_SETUP
-#line 659 "maplexer.l"
+#line 661 "maplexer.l"
msyystring_return_state = MS_TOKEN_LITERAL_STRING;
msyystring_begin = msyytext[0];
@@ -4206,7 +4208,7 @@
YY_BREAK
case 315:
YY_RULE_SETUP
-#line 667 "maplexer.l"
+#line 669 "maplexer.l"
MS_LEXER_STRING_REALLOC(msyystring_buffer, strlen(msyytext),
@@ -4217,11 +4219,11 @@
case 316:
/* rule 316 can match eol */
YY_RULE_SETUP
-#line 674 "maplexer.l"
+#line 676 "maplexer.l"
{ msyylineno++; }
YY_BREAK
case YY_STATE_EOF(INITIAL):
-#line 676 "maplexer.l"
+#line 678 "maplexer.l"
if( --include_stack_ptr < 0 )
return(EOF); /* end of main file */
@@ -4236,14 +4238,14 @@
case 317:
/* rule 317 can match eol */
YY_RULE_SETUP
-#line 687 "maplexer.l"
+#line 689 "maplexer.l"
return(0);
YY_BREAK
case 318:
YY_RULE_SETUP
-#line 691 "maplexer.l"
+#line 693 "maplexer.l"
@@ -4253,15 +4255,15 @@
YY_BREAK
case 319:
YY_RULE_SETUP
-#line 697 "maplexer.l"
+#line 699 "maplexer.l"
{ return(msyytext[0]); }
YY_BREAK
case 320:
YY_RULE_SETUP
-#line 698 "maplexer.l"
+#line 700 "maplexer.l"
ECHO;
YY_BREAK
-#line 4265 "maplexer.c"
+#line 4267 "maplexer.c"
case YY_STATE_EOF(URL_VARIABLE):
case YY_STATE_EOF(URL_STRING):
case YY_STATE_EOF(EXPRESSION_STRING):
@@ -5263,7 +5265,7 @@
#define YYTABLES_NAME "yytables"
Modified: trunk/mapserver/maplexer.l
--- trunk/mapserver/maplexer.l 2012-02-06 19:49:21 UTC (rev 13065)
+++ trunk/mapserver/maplexer.l 2012-02-06 20:14:55 UTC (rev 13066)
@@ -604,6 +604,8 @@
++msyystring_size;
++msyystring_size;
More information about the mapserver-commits
