[mapserver-commits] r13068 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 6 15:20:46 EST 2012
Author: tbonfort
Date: 2012-02-06 12:20:46 -0800 (Mon, 06 Feb 2012)
New Revision: 13068
trunk/mapserver/configure
trunk/mapserver/configure.in
trunk/mapserver/mapimageio.c
allow to disable GIF symbol support with --without-gif
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2012-02-06 20:20:12 UTC (rev 13067)
+++ trunk/mapserver/configure 2012-02-06 20:20:46 UTC (rev 13068)
@@ -16503,18 +16503,18 @@
GIF_INC=''
GIF_ENABLED=''
+if test "$withval" != "no" ; then
+ if test -n "$GIF_DIR" -a "GIF_DIR" != "yes" ; then
+ test -f $GIF_DIR/lib/libgif.a -o -f $GIF_DIR/lib/libgif.so -o -f $GIF_DIR/lib/libgif.sl -o -f $GIF_DIR/lib/libgif.dylib && GIF_LIBDIR="$GIF_DIR/lib"
+ test -f $GIF_DIR/lib64/libgif.a -o -f $GIF_DIR/lib64/libgif.so -o -f $GIF_DIR/lib64/libgif.sl -o -f $GIF_DIR/libgif.dylib && GIF_LIBDIR="$GIF_DIR/lib64"
+ test -f $GIF_DIR/libgif.a -o -f $GIF_DIR/libgif.so -o -f $GIF_DIR/libgif.sl -o -f $GIF_DIR/libgif.dylib && GIF_LIBDIR="$GIF_DIR"
+ test -f $GIF_DIR/include/gif_lib.h && GIF_INCLUDE="$GIF_DIR/include"
+ test -f $GIF_DIR/lib/gif_lib.h && GIF_INCLUDE="$GIF_DIR/lib"
+ test -f $GIF_DIR/gif_lib.h && GIF_INCLUDE="$GIF_DIR"
-if test -n "$GIF_DIR" -a "GIF_DIR" != "yes" ; then
- test -f $GIF_DIR/lib/libgif.a -o -f $GIF_DIR/lib/libgif.so -o -f $GIF_DIR/lib/libgif.sl -o -f $GIF_DIR/lib/libgif.dylib && GIF_LIBDIR="$GIF_DIR/lib"
- test -f $GIF_DIR/lib64/libgif.a -o -f $GIF_DIR/lib64/libgif.so -o -f $GIF_DIR/lib64/libgif.sl -o -f $GIF_DIR/libgif.dylib && GIF_LIBDIR="$GIF_DIR/lib64"
- test -f $GIF_DIR/libgif.a -o -f $GIF_DIR/libgif.so -o -f $GIF_DIR/libgif.sl -o -f $GIF_DIR/libgif.dylib && GIF_LIBDIR="$GIF_DIR"
- test -f $GIF_DIR/include/gif_lib.h && GIF_INCLUDE="$GIF_DIR/include"
- test -f $GIF_DIR/lib/gif_lib.h && GIF_INCLUDE="$GIF_DIR/lib"
- test -f $GIF_DIR/gif_lib.h && GIF_INCLUDE="$GIF_DIR"
- if test -n "$GIF_LIBDIR" ; then
- GIF_LIB="-L$GIF_LIBDIR -lgif"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: using libgif from $GIF_LIB" >&5
+ if test -n "$GIF_LIBDIR" ; then
+ GIF_LIB="-L$GIF_LIBDIR -lgif"
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: using libgif from $GIF_LIB" >&5
$as_echo " using libgif from $GIF_LIB" >&6; }
if test ""$GIF_LIBDIR"" != "/usr/lib"; then
@@ -16538,29 +16538,29 @@
fi
- else
- as_fn_error $? "cannot find gif lib in $GIF_DIR" "$LINENO" 5
- fi
+ else
+ as_fn_error $? "cannot find gif lib in $GIF_DIR. To disable gif support run with --without-gif." "$LINENO" 5
+ fi
- if test -n "$GIF_INCLUDE" ; then
- as_ac_Header=`$as_echo "ac_cv_header_$GIF_INCLUDE/gif_lib.h" | $as_tr_sh`
+ if test -n "$GIF_INCLUDE" ; then
+ as_ac_Header=`$as_echo "ac_cv_header_$GIF_INCLUDE/gif_lib.h" | $as_tr_sh`
ac_fn_c_check_header_mongrel "$LINENO" "$GIF_INCLUDE/gif_lib.h" "$as_ac_Header" "$ac_includes_default"
if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
GIF_INC=-I$GIF_INCLUDE
else
- as_fn_error $? "cannot find gif headers" "$LINENO" 5
+ as_fn_error $? "cannot find gif headers. To disable gif support run with --without-gif." "$LINENO" 5
fi
- ALL_INC="$GIF_INC $ALL_INC"
- else
- as_fn_error $? "cannot find gif headers in $GIF_DIR" "$LINENO" 5
- fi
- GIF_ENABLED="-DUSE_GIF"
-else
+ ALL_INC="$GIF_INC $ALL_INC"
+ else
+ as_fn_error $? "cannot find gif headers in $GIF_DIR. To disable gif support run with --without-gif." "$LINENO" 5
+ fi
+ GIF_ENABLED="-DUSE_GIF"
+ else
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for DGifOpenFileHandle in -lgif" >&5
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking for DGifOpenFileHandle in -lgif" >&5
$as_echo_n "checking for DGifOpenFileHandle in -lgif... " >&6; }
if ${ac_cv_lib_gif_DGifOpenFileHandle+:} false; then :
$as_echo_n "(cached) " >&6
@@ -16600,21 +16600,22 @@
GIF_LIB="-lgif"
fi
- ac_fn_c_check_header_mongrel "$LINENO" "gif_lib.h" "ac_cv_header_gif_lib_h" "$ac_includes_default"
+ ac_fn_c_check_header_mongrel "$LINENO" "gif_lib.h" "ac_cv_header_gif_lib_h" "$ac_includes_default"
if test "x$ac_cv_header_gif_lib_h" = xyes; then :
else
- as_fn_error $? "cannot find gif headers in system path" "$LINENO" 5
+ as_fn_error $? "cannot find gif headers in system path. To disable gif support run with --without-gif." "$LINENO" 5
fi
- if test -n "$GIF_LIB" ; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: using libgif from system libs." >&5
+ if test -n "$GIF_LIB" ; then
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: using libgif from system libs." >&5
$as_echo " using libgif from system libs." >&6; }
- else
- as_fn_error $? "GIF (libgif) library cannot be found. install or reconfigure with --with-gif=DIR" "$LINENO" 5
- fi
+ else
+ as_fn_error $? "GIF (libgif) library cannot be found. install or reconfigure with --with-gif=DIR. To disable gif support run with --without-gif." "$LINENO" 5
+ fi
+ fi
fi
ALL_ENABLED="$GIF_ENABLED $ALL_ENABLED"
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2012-02-06 20:20:12 UTC (rev 13067)
+++ trunk/mapserver/configure.in 2012-02-06 20:20:46 UTC (rev 13068)
@@ -358,44 +358,45 @@
GIF_INC=''
GIF_ENABLED=''
- AC_MSG_RESULT([ using libgif from $GIF_LIB])
- AC_ADD_RUNPATH("$GIF_LIBDIR")
- else
- AC_MSG_ERROR([cannot find gif lib in $GIF_DIR])
- fi
- AC_CHECK_HEADER([$GIF_INCLUDE/gif_lib.h],GIF_INC=-I$GIF_INCLUDE,
- [AC_MSG_ERROR([cannot find gif headers])])
- else
- AC_MSG_ERROR([cannot find gif headers in $GIF_DIR])
- fi
-else
- dnl check for gif in system locations
- AC_CHECK_LIB(gif, DGifOpenFileHandle, GIF_LIB="-lgif",,)
- AC_CHECK_HEADER([gif_lib.h],,
- [AC_MSG_ERROR([cannot find gif headers in system path])])
- AC_MSG_RESULT([ using libgif from system libs.])
- else
- AC_MSG_ERROR([GIF (libgif) library cannot be found. install or reconfigure with --with-gif=DIR])
- fi
+ AC_MSG_RESULT([ using libgif from $GIF_LIB])
+ AC_ADD_RUNPATH("$GIF_LIBDIR")
+ else
+ AC_MSG_ERROR([cannot find gif lib in $GIF_DIR. To disable gif support run with --without-gif.])
+ fi
+ AC_CHECK_HEADER([$GIF_INCLUDE/gif_lib.h],GIF_INC=-I$GIF_INCLUDE,
+ [AC_MSG_ERROR([cannot find gif headers. To disable gif support run with --without-gif.])])
+ else
+ AC_MSG_ERROR([cannot find gif headers in $GIF_DIR. To disable gif support run with --without-gif.])
+ fi
+ else
+ dnl check for gif in system locations
+ AC_CHECK_LIB(gif, DGifOpenFileHandle, GIF_LIB="-lgif",,)
+ AC_CHECK_HEADER([gif_lib.h],,
+ [AC_MSG_ERROR([cannot find gif headers in system path. To disable gif support run with --without-gif.])])
+ AC_MSG_RESULT([ using libgif from system libs.])
+ else
+ AC_MSG_ERROR([GIF (libgif) library cannot be found. install or reconfigure with --with-gif=DIR]. To disable gif support run with --without-gif.)
+ fi
+ fi
fi
Modified: trunk/mapserver/mapimageio.c
--- trunk/mapserver/mapimageio.c 2012-02-06 20:20:12 UTC (rev 13067)
+++ trunk/mapserver/mapimageio.c 2012-02-06 20:20:46 UTC (rev 13068)
@@ -1241,12 +1241,14 @@
if(png_sig_cmp(signature,0,8) == 0) {
ret = readPNG(path,rb);
+ else if (!strncmp((char*)signature,"GIF",3)) {
#ifdef USE_GIF
- else if (!strncmp((char*)signature,"GIF",3)) {
ret = readGIF(path,rb);
+#else
+ msSetError(MS_MISCERR,"pixmap %s seems to be GIF formatted, but this server is compiled without GIF support","readImage()",path);
+ return MS_FAILURE;
+#endif
-#endif
else {
msSetError(MS_MISCERR,"unsupported pixmap format","readImage()");
return MS_FAILURE;
More information about the mapserver-commits
