[mapserver-commits] r13072 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Mon Feb 6 17:05:39 EST 2012
Author: tbonfort
Date: 2012-02-06 14:05:38 -0800 (Mon, 06 Feb 2012)
New Revision: 13072
trunk/mapserver/mapcache/configure
trunk/mapserver/mapcache/configure.in
fix help message
Modified: trunk/mapserver/mapcache/configure
--- trunk/mapserver/mapcache/configure 2012-02-06 21:01:36 UTC (rev 13071)
+++ trunk/mapserver/mapcache/configure 2012-02-06 22:05:38 UTC (rev 13072)
@@ -1423,22 +1423,24 @@
--with-gnu-ld assume the C compiler uses GNU ld [default=no]
--with-sysroot=DIR Search for dependent libraries within DIR
(or the compiler's sysroot if not specified).
- --with-apxs=/path/to/apxs Apache 2 apxs tool location
- --with-fastcgi=DIR Specify where FASTCGI is installed
+ --with-apxs[=PATH] Apache 2 apxs tool location
+ --with-fastcgi[=DIR] Specify where FASTCGI is installed
--with-apr-config path to apr-config program
--with-apu-config path to apu-config program
--with-sqlite path to sqlite-config program
- --with-pkg-config=PATH path to pkg-config)
- --with-pixman=ARG Include Pixman Support (ARG=yes/no/path to
+ --with-pkg-config[=PATH]
+ path to pkg-config)
+ --with-pixman[=ARG] Include Pixman Support (ARG=yes/no/path to
pixman.pc)
- --with-png=DIR Specify where PNG is installed
- --with-jpeg=DIR Specify where JPEG is installed
- --with-tiff=DIR Specify where TIFF is installed
- --with-geotiff=ARG Libgeotiff library to use (ARG=yes or path)
+ --with-png[=DIR] Specify where PNG is installed
+ --with-jpeg[=DIR] Specify where JPEG is installed
+ --with-tiff[=DIR] Specify where TIFF is installed
+ --with-geotiff[=ARG] Libgeotiff library to use (ARG=yes or path)
--with-pcre[=prefix] use pcre instead of posix regular expressions
--with-gdal path to gdal-config program
--with-geos path to geos-config program
- --enable-mapserver Enable mapserver sources (experimental)
+ --with-mapserver[=/path/to/mapserver-prefix]
+ Enable mapserver sources (experimental)
--with-curl-config path to curl-config program
Some influential environment variables:
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2012-02-06 21:01:36 UTC (rev 13071)
+++ trunk/mapserver/mapcache/configure.in 2012-02-06 22:05:38 UTC (rev 13072)
@@ -31,8 +31,8 @@
AC_SUBST(APXS)
AC_ARG_WITH(
- apxs,
- [ --with-apxs[=/path/to/apxs] Apache 2 apxs tool location],
+ apxs,
+ AC_HELP_STRING([--with-apxs@<:@=PATH@:>@],[Apache 2 apxs tool location]),
[with_apxs="yes"]
@@ -124,7 +124,7 @@
AC_DEFUN([PKGCONFIG_CHECK],[
AC_SUBST(PKGCONFIG)
AC_ARG_WITH(pkg-config,
- AC_HELP_STRING([--with-pkg-config[=PATH]],[path to pkg-config)]),
+ AC_HELP_STRING([--with-pkg-config@<:@=PATH@:>@],[path to pkg-config)]),
[with_pkg_config=yes])
if test "$with_pkg_config" = "no"; then
@@ -151,7 +151,7 @@
AC_DEFUN([CAIRO_CHECK],[
AC_ARG_WITH(cairo,
- AC_HELP_STRING([--with-cairo[[=ARG]]],[Include Cairo Support (ARG=yes/no/path to cairo.pc)]),
+ AC_HELP_STRING([--with-cairo@<:@=ARG@:>@],[Include Cairo Support (ARG=yes/no/path to cairo.pc)]),
[with_cairo=yes])
@@ -194,7 +194,7 @@
AC_DEFUN([PIXMAN_CHECK],[
AC_ARG_WITH(pixman,
- AC_HELP_STRING([--with-pixman[[=ARG]]],[Include Pixman Support (ARG=yes/no/path to pixman.pc)]),
+ AC_HELP_STRING([--with-pixman@<:@=ARG@:>@],[Include Pixman Support (ARG=yes/no/path to pixman.pc)]),
[with_pixman=yes])
@@ -467,7 +467,7 @@
AC_DEFUN([MAPSERVER_CHECK],[
AC_ARG_WITH(mapserver,
- AC_HELP_STRING([--enable-mapserver],[Enable mapserver sources (experimental)]),
+ AC_HELP_STRING([--with-mapserver@<:@=/path/to/mapserver-prefix@:>@ ],[Enable mapserver sources (experimental)]),
[enable_mapserver=no]
@@ -588,7 +588,7 @@
AC_DEFUN([FASTCGI_CHECK],[
AC_ARG_WITH(fastcgi,
- AC_HELP_STRING([--with-fastcgi=DIR],[Specify where FASTCGI is installed]),
+ AC_HELP_STRING([--with-fastcgi@<:@=DIR@:>@],[Specify where FASTCGI is installed]),
,[with_fastcgi=no])
AC_MSG_CHECKING(whether to enable FASTCGI)
@@ -640,7 +640,7 @@
GEOTIFF_ENABLED=""
AC_DEFUN([GEOTIFF_CHECK],[
AC_ARG_WITH(geotiff,
- [ --with-geotiff=ARG Libgeotiff library to use (ARG=yes or path)],
+ AC_HELP_STRING([--with-geotiff@<:@=ARG@:>@],[Libgeotiff library to use (ARG=yes or path)]),
,[with_geotiff=no])
if test "$with_geotiff" = "yes" -o "$with_geotiff" = "" ; then
@@ -697,7 +697,7 @@
AC_DEFUN([TIFF_CHECK],[
AC_ARG_WITH(tiff,
- AC_HELP_STRING([--with-tiff=DIR],[Specify where TIFF is installed]),
+ AC_HELP_STRING([--with-tiff@<:@=DIR@:>@],[Specify where TIFF is installed]),
TIFF_DIR=$withval,TIFF_DIR='')
AC_EXPAND_PATH($TIFF_DIR, TIFF_DIR)
@@ -778,7 +778,7 @@
AC_DEFUN([PNG_CHECK],[
AC_ARG_WITH(png,
- AC_HELP_STRING([--with-png=DIR],[Specify where PNG is installed]),
+ AC_HELP_STRING([--with-png@<:@=DIR@:>@],[Specify where PNG is installed]),
PNG_DIR=$withval,PNG_DIR='')
AC_EXPAND_PATH($PNG_DIR, PNG_DIR)
@@ -901,7 +901,7 @@
AC_DEFUN([JPEG_CHECK],[
AC_ARG_WITH(jpeg,
- AC_HELP_STRING([--with-jpeg=DIR],[Specify where JPEG is installed]),
+ AC_HELP_STRING([--with-jpeg@<:@=DIR@:>@],[Specify where JPEG is installed]),
JPEG_DIR=$withval,JPEG_DIR='')
AC_EXPAND_PATH($JPEG_DIR, JPEG_DIR)
More information about the mapserver-commits
