[mapserver-commits] r13077 - branches/branch-6-0/docs/en/ogc
trunk/docs/en/ogc
svn at osgeo.org
svn at osgeo.org
Tue Feb 7 06:38:25 EST 2012
Author: havatv
Date: 2012-02-07 03:38:25 -0800 (Tue, 07 Feb 2012)
New Revision: 13077
branches/branch-6-0/docs/en/ogc/filter_encoding.txt
trunk/docs/en/ogc/filter_encoding.txt
Changed Intersect to Intersects in the wfs filter encoding documentation (#4112). Also fixed some overfull lines in the PDF (#3947)
Modified: branches/branch-6-0/docs/en/ogc/filter_encoding.txt
--- branches/branch-6-0/docs/en/ogc/filter_encoding.txt 2012-02-06 23:43:15 UTC (rev 13076)
+++ branches/branch-6-0/docs/en/ogc/filter_encoding.txt 2012-02-07 11:38:25 UTC (rev 13077)
@@ -12,6 +12,7 @@
:Author: Yewondwossen Assefa
:Contact: assefa at dmsolutions.ca
:Last Updated: 2010-10-07
+:Date: $Date$
.. contents:: Table of Contents
:depth: 2
@@ -170,73 +171,85 @@
Server Side
-To be able to use Filter Encoding, you need to create a valid WFS server using
-MapServer. Please refer to the :ref:`WFS Server HOWTO <wfs_server>` for specifics.
+To be able to use Filter Encoding, you need to create a valid WFS
+server using MapServer. Please refer to the :ref:`WFS Server HOWTO
+<wfs_server>` for specifics.
-There is nothing special that should be added to a WFS server for Filter
-Encoding, but you should note that, when requesting the capabilities of
-your WFS server, the document returned should contain the supported filters.
-Here is part of a Capabilities document (note the "Filter_Capabilities" section):
+There is nothing special that should be added to a WFS server for
+Filter Encoding, but you should note that, when requesting the
+capabilities of your WFS server, the document returned should contain
+the supported filters. Here is part of a Capabilities document (note
+the "Filter_Capabilities" section):
.. code-block:: guess
- :linenos:
+ :linenos:
- <?xml version="1.0" encoding="ISO-8859-1"?>
- <WFS_Capabilities version="1.0.0" updateSequence="0" xmlns="http://www.opengis.net/wfs" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
+ <?xml version="1.0" encoding="ISO-8859-1"?>
+ <WFS_Capabilities version="1.0.0" updateSequence="0"
+ xmlns="http://www.opengis.net/wfs" xmlns:ogc="http://www.opengis.net/ogc"
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+ xsi:schemaLocation="http://www.opengis.net/wfs
+ http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
- <!-- MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
+ <!-- MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
+ OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
+ SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
+ SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
+ SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
+ INPUT=GDAL INPUT=SHAPEFILE -->
- <Service>
- <Name>MapServer WFS</Name>
- <Title>WMS Demo Server for MapServer</Title>
- <Abstract>This demonstration server showcases MapServer (www.mapserver.org) and its OGC support</Abstract>
- <OnlineResource>http://demo.mapserver.org/cgi-bin/wfs?</OnlineResource>
- </Service>
+ <Service>
+ <Name>MapServer WFS</Name>
+ <Title>WMS Demo Server for MapServer</Title>
+ <Abstract>This demonstration server showcases MapServer (www.mapserver.org)
+ and its OGC support</Abstract>
+ <OnlineResource>http://demo.mapserver.org/cgi-bin/wfs?</OnlineResource>
+ </Service>
- <Capability>
- <Request>
- <GetCapabilities>
- <DCPType>
- <HTTP>
- <Get onlineResource="http://demo.mapserver.org/cgi-bin/wfs?"/>
- </HTTP>
- </DCPType>
- <DCPType>
- <HTTP>
- <Post onlineResource="http://demo.mapserver.org/cgi-bin/wfs?"/>
- </HTTP>
- </DCPType>
- </GetCapabilities>
- </Request>
- </Capability>
- <ogc:Filter_Capabilities>
- <ogc:Spatial_Capabilities>
- <ogc:Spatial_Operators>
- <ogc:Equals/>
- <ogc:Disjoint/>
- <ogc:Touches/>
- <ogc:Within/>
- <ogc:Overlaps/>
- <ogc:Crosses/>
- <ogc:Intersect/>
- <ogc:Contains/>
- <ogc:DWithin/>
- <ogc:BBOX/>
- </ogc:Spatial_Operators>
- </ogc:Spatial_Capabilities>
- <ogc:Scalar_Capabilities>
- <ogc:Logical_Operators/>
- <ogc:Comparison_Operators>
- <ogc:Simple_Comparisons/>
- <ogc:Like/>
- <ogc:Between/>
- </ogc:Comparison_Operators>
- </ogc:Scalar_Capabilities>
- </ogc:Filter_Capabilities>
+ <Capability>
+ <Request>
+ <GetCapabilities>
+ <DCPType>
+ <HTTP>
+ <Get onlineResource="http://demo.mapserver.org/cgi-bin/wfs?"/>
+ </HTTP>
+ </DCPType>
+ <DCPType>
+ <HTTP>
+ <Post onlineResource="http://demo.mapserver.org/cgi-bin/wfs?"/>
+ </HTTP>
+ </DCPType>
+ </GetCapabilities>
+ </Request>
+ </Capability>
+ <ogc:Filter_Capabilities>
+ <ogc:Spatial_Capabilities>
+ <ogc:Spatial_Operators>
+ <ogc:Equals/>
+ <ogc:Disjoint/>
+ <ogc:Touches/>
+ <ogc:Within/>
+ <ogc:Overlaps/>
+ <ogc:Crosses/>
+ <ogc:Intersects/>
+ <ogc:Contains/>
+ <ogc:DWithin/>
+ <ogc:BBOX/>
+ </ogc:Spatial_Operators>
+ </ogc:Spatial_Capabilities>
+ <ogc:Scalar_Capabilities>
+ <ogc:Logical_Operators/>
+ <ogc:Comparison_Operators>
+ <ogc:Simple_Comparisons/>
+ <ogc:Like/>
+ <ogc:Between/>
+ </ogc:Comparison_Operators>
+ </ogc:Scalar_Capabilities>
+ </ogc:Filter_Capabilities>
- </WFS_Capabilities>
+ </WFS_Capabilities>
Client Side
@@ -247,43 +260,43 @@
.. code-block:: mapfile
- LAYER
- NAME "cities"
- TYPE POINT
- STATUS ON
- CONNECTION "http://demo.mapserver.org/cgi-bin/wfs?"
- CONNECTIONTYPE WFS
- METADATA
- "wfs_typename" "cities"
- "wfs_version" "1.0.0"
- "wfs_connectiontimeout" "60"
- "wfs_maxfeatures" "100"
- "wfs_filter" "<PropertyIsGreaterThan><PropertyName>POPULATION</PropertyName>
- <Literal>10000000</Literal></PropertyIsGreaterThan>"
- END
- PROJECTION
- "init=epsg:4326"
- END
- LABELITEM 'NAME'
- CLASS
- NAME 'World Cities'
- STYLE
- COLOR 255 128 128
- OUTLINECOLOR 128 0 0
- SYMBOL 'circle'
- SIZE 9
- END
- LABEL
- COLOR 0 0 0
- OUTLINECOLOR 255 255 255
- TYPE TRUETYPE
- FONT sans
- SIZE 7
- POSITION UC
- PARTIALS FALSE
- END
- END
- END
+ LAYER
+ NAME "cities"
+ TYPE POINT
+ STATUS ON
+ CONNECTION "http://demo.mapserver.org/cgi-bin/wfs?"
+ CONNECTIONTYPE WFS
+ METADATA
+ "wfs_typename" "cities"
+ "wfs_version" "1.0.0"
+ "wfs_connectiontimeout" "60"
+ "wfs_maxfeatures" "100"
+ "wfs_filter" "<PropertyIsGreaterThan><PropertyName>POPULATION</PropertyName>
+ <Literal>10000000</Literal></PropertyIsGreaterThan>"
+ END
+ PROJECTION
+ "init=epsg:4326"
+ END
+ LABELITEM 'NAME'
+ CLASS
+ NAME 'World Cities'
+ STYLE
+ COLOR 255 128 128
+ OUTLINECOLOR 128 0 0
+ SYMBOL 'circle'
+ SIZE 9
+ END
+ LABEL
+ COLOR 0 0 0
+ OUTLINECOLOR 255 255 255
+ TYPE TRUETYPE
+ FONT sans
+ SIZE 7
+ POSITION UC
+ PARTIALS FALSE
+ END
+ END
+ END
*Note:*
@@ -312,117 +325,140 @@
- http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&
- TYPENAME=cities&Filter=<Filter><PropertyIsEqualTo><PropertyName>NAME</PropertyName>
- <Literal>Halifax</Literal></PropertyIsEqualTo></Filter>
+ http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS
+ &REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter>
+ <PropertyIsEqualTo><PropertyName>NAME</PropertyName>
+ <Literal>Halifax</Literal></PropertyIsEqualTo></Filter>
- `PropertyIsNotEqualTo`_
- TYPENAME=cities&Filter=<Filter><PropertyIsNotEqualTo><PropertyName>NAME</PropertyName>
- <Literal>Halifax</Literal></PropertyIsNotEqualTo></Filter>
+ <PropertyIsNotEqualTo><PropertyName>NAME</PropertyName>
+ <Literal>Halifax</Literal></PropertyIsNotEqualTo></Filter>
- `PropertyIsLessThan`_
- TYPENAME=cities&Filter=<Filter><PropertyIsLessThan><PropertyName>POPULATION</PropertyName>
- <Literal>1000</Literal></PropertyIsLessThan></Filter>
+ <PropertyIsLessThan><PropertyName>POPULATION</PropertyName>
+ <Literal>1000</Literal></PropertyIsLessThan></Filter>
- `PropertyIsGreaterThan`_
- TYPENAME=cities&Filter=<Filter><PropertyIsGreaterThan><PropertyName>POPULATION</PropertyName>
- <Literal>10000000</Literal></PropertyIsGreaterThan></Filter>
+ <PropertyIsGreaterThan><PropertyName>POPULATION</PropertyName>
+ <Literal>10000000</Literal></PropertyIsGreaterThan></Filter>
- `PropertyIsLessThanOrEqualTo`_
- TYPENAME=cities&Filter=<Filter><PropertyIsLessThanOrEqualTo><PropertyName>POPULATION</PropertyName>
- <Literal>499</Literal></PropertyIsLessThanOrEqualTo></Filter>
+ <PropertyIsLessThanOrEqualTo><PropertyName>POPULATION</PropertyName>
+ <Literal>499</Literal></PropertyIsLessThanOrEqualTo></Filter>
- `PropertyIsGreaterThanOrEqualTo`_
- TYPENAME=cities&Filter=<Filter><PropertyIsGreaterThanOrEqualTo><PropertyName>POPULATION</PropertyName>
- <Literal>10194978</Literal></PropertyIsGreaterThanOrEqualTo></Filter>
+ <PropertyIsGreaterThanOrEqualTo><PropertyName>POPULATION</PropertyName>
+ <Literal>10194978</Literal></PropertyIsGreaterThanOrEqualTo></Filter>
- `PropertyIsBetween`_
- TYPENAME=cities&Filter=<Filter><PropertyIsBetween><PropertyName>POPULATION</PropertyName>
- <LowerBoundary>10194978</LowerBoundary><UpperBoundary>12116379</UpperBoundary></PropertyIsBetween></Filter>
+ <PropertyIsBetween><PropertyName>POPULATION</PropertyName>
+ <LowerBoundary>10194978</LowerBoundary>
+ <UpperBoundary>12116379</UpperBoundary></PropertyIsBetween></Filter>
- `PropertyIsLike`_
- TYPENAME=cities&Filter=<Filter><PropertyIsLike wildcard='*' singleChar='.' escape='!'>
- <PropertyName>NAME</PropertyName><Literal>Syd*</Literal></PropertyIsLike></Filter>
+ <PropertyIsLike wildcard='*' singleChar='.' escape='!'>
+ <PropertyName>NAME</PropertyName><Literal>Syd*</Literal></PropertyIsLike>
+ </Filter>
- `Logical operator OR`_
- TYPENAME=cities&Filter=<Filter><OR><PropertyIsEqualTo><PropertyName>NAME</PropertyName>
- <Literal>Sydney</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>NAME</PropertyName>
- <Literal>Halifax</Literal></PropertyIsEqualTo></OR></Filter>
+ <OR><PropertyIsEqualTo><PropertyName>NAME</PropertyName>
+ <Literal>Sydney</Literal></PropertyIsEqualTo><PropertyIsEqualTo>
+ <PropertyName>NAME</PropertyName><Literal>Halifax</Literal>
+ </PropertyIsEqualTo></OR></Filter>
- `Logical operator AND`_
- TYPENAME=cities&Filter=<Filter><AND><PropertyIsLike wildcard='*' singleChar='.' escape='!'>
- <PropertyName>NAME</PropertyName><Literal>Syd*</Literal></PropertyIsLike><PropertyIsEqualTo>
- <PropertyName>POPULATION</PropertyName><Literal>4250065</Literal></PropertyIsEqualTo></AND></Filter>
+ <AND><PropertyIsLike wildcard='*' singleChar='.' escape='!'>
+ <PropertyIsEqualTo><PropertyName>POPULATION</PropertyName>
+ <Literal>4250065</Literal></PropertyIsEqualTo></AND></Filter>
- `Logical operator NOT`_
- TYPENAME=cities&Filter=<Filter><AND><NOT><PropertyIsEqualTo><PropertyName>POPULATION</PropertyName>
- <Literal>0</Literal></PropertyIsEqualTo></NOT><NOT><PropertyIsEqualTo><PropertyName>POPULATION</PropertyName>
- <Literal>12116379</Literal></PropertyIsEqualTo></NOT></AND></Filter>
+ <AND><NOT><PropertyIsEqualTo><PropertyName>POPULATION</PropertyName>
+ <Literal>0</Literal></PropertyIsEqualTo></NOT><NOT><PropertyIsEqualTo>
+ <PropertyName>POPULATION</PropertyName><Literal>12116379</Literal>
+ </PropertyIsEqualTo></NOT></AND></Filter>
- `Spatial operator BBOX`_
- http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&
- Filter=<Filter><BBOX><PropertyName>Name>NAME</PropertyName><Box%20srsName='EPSG:42304'>
- <coordinates>135.2239,34.4879 135.8578,34.8471</coordinates></Box></BBOX></Filter>
+ <BBOX><PropertyName>Name>NAME</PropertyName><Box%20srsName='EPSG:42304'>
+ <coordinates>135.2239,34.4879 135.8578,34.8471</coordinates></Box></BBOX>
+ </Filter>
- `Spatial operator Dwithin`_
- http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=
- <Filter><DWithin><PropertyName>Geometry</PropertyName><gml:Point><gml:coordinates>135.500000,34.666667</gml:coordinates>
- </gml:Point><Distance units='m'>10000</Distance></DWithin></Filter>
+ <DWithin><PropertyName>Geometry</PropertyName><gml:Point>
+ <gml:coordinates>135.500000,34.666667</gml:coordinates>
+ </gml:Point><Distance units='m'>10000</Distance></DWithin></Filter>
- `Spatial operator Intersects`_
- http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter>
- <Intersect><PropertyName>Geometry</PropertyName><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing>
- <gml:coordinates>135.5329,34.6624 135.4921,34.8153 135.3673,34.7815 135.3800,34.6216 135.5361,34.6210 135.5329,34.6624</gml:coordinates>
- </gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersect></Filter>
+ <Intersects><PropertyName>Geometry</PropertyName>
+ <gml:Polygon><gml:outerBoundaryIs><gml:LinearRing>
+ <gml:coordinates>135.5329,34.6624 135.4921,34.8153 135.3673,34.7815
+ 135.3800,34.6216 135.5361,34.6210 135.5329,34.6624</gml:coordinates>
+ </gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></Filter>
.. _`PropertyIsEqualTo`: http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter><PropertyIsEqualTo><PropertyName>NAME</PropertyName><Literal>Halifax</Literal></PropertyIsEqualTo></Filter>
.. _`PropertyIsNotEqualTo`: http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter><PropertyIsNotEqualTo><PropertyName>NAME</PropertyName><Literal>Halifax</Literal></PropertyIsNotEqualTo></Filter>
@@ -437,7 +473,7 @@
.. _`Logical operator NOT`: http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter><AND><NOT><PropertyIsEqualTo><PropertyName>POPULATION</PropertyName><Literal>0</Literal></PropertyIsEqualTo></NOT><NOT><PropertyIsEqualTo><PropertyName>POPULATION</PropertyName><Literal>12116379</Literal></PropertyIsEqualTo></NOT></AND></Filter>
.. _`Spatial operator BBOX`: http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter><BBOX><PropertyName>Name>NAME</PropertyName><Box%20srsName='EPSG:4326'><coordinates>135.2239,34.4879%20135.8578,34.8471</coordinates></Box></BBOX></Filter>
.. _`Spatial operator Dwithin`: http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter><DWithin><PropertyName>Geometry</PropertyName><gml:Point><gml:coordinates>135.500000,34.666667</gml:coordinates></gml:Point><Distance%20units='m'>10000</Distance></DWithin></Filter>
-.. _`Spatial operator Intersects`: http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter><Intersect><PropertyName>Geometry</PropertyName><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>135.5329,34.6624%20135.4921,34.8153%20135.3673,34.7815%20135.3800,34.6216%20135.5361,34.6210%20135.5329,34.6624</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersect></Filter>
+.. _`Spatial operator Intersects`: http://demo.mapserver.org/cgi-bin/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&Filter=<Filter><Intersects><PropertyName>Geometry</PropertyName><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>135.5329,34.6624%20135.4921,34.8153%20135.3673,34.7815%20135.3800,34.6216%20135.5361,34.6210%20135.5329,34.6624</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></Filter>
.. index::
triple: WFS; Filter encoding; OGC conformance tests
Modified: trunk/docs/en/ogc/filter_encoding.txt
--- trunk/docs/en/ogc/filter_encoding.txt 2012-02-06 23:43:15 UTC (rev 13076)
+++ trunk/docs/en/ogc/filter_encoding.txt 2012-02-07 11:38:25 UTC (rev 13077)
@@ -12,6 +12,7 @@
+:Date: $Date$
:depth: 2
Server Side
- :linenos:
+ :linenos:
- <Service>
- </Service>
+ <Service>
+ </Service>
- <Capability>
- <Request>
- <GetCapabilities>
- <DCPType>
- <HTTP>
- </HTTP>
- </DCPType>
- <DCPType>
- <HTTP>
- </HTTP>
- </DCPType>
- </Request>
- </Capability>
- <ogc:Equals/>
- <ogc:Disjoint/>
- <ogc:Touches/>
- <ogc:Within/>
- <ogc:Overlaps/>
- <ogc:Crosses/>
- <ogc:Intersect/>
- <ogc:Contains/>
- <ogc:DWithin/>
- <ogc:BBOX/>
- <ogc:Like/>
- <ogc:Between/>
+ <Capability>
+ <Request>
+ <GetCapabilities>
+ <DCPType>
+ <HTTP>
+ </HTTP>
+ </DCPType>
+ <DCPType>
+ <HTTP>
+ </HTTP>
+ </DCPType>
+ </Request>
+ </Capability>
+ <ogc:Equals/>
+ <ogc:Disjoint/>
+ <ogc:Touches/>
+ <ogc:Within/>
+ <ogc:Overlaps/>
+ <ogc:Crosses/>
+ <ogc:Intersects/>
+ <ogc:Contains/>
+ <ogc:DWithin/>
+ <ogc:BBOX/>
+ <ogc:Like/>
+ <ogc:Between/>
Client Side
- LAYER
- NAME "cities"
- TYPE POINT
- STATUS ON
- METADATA
- END
- PROJECTION
- "init=epsg:4326"
- END
- LABELITEM 'NAME'
- CLASS
- STYLE
- COLOR 255 128 128
- SYMBOL 'circle'
- SIZE 9
- END
- LABEL
- COLOR 0 0 0
- TYPE TRUETYPE
- FONT sans
- SIZE 7
- POSITION UC
- PARTIALS FALSE
- END
- END
- END
+ LAYER
+ NAME "cities"
+ TYPE POINT
+ STATUS ON
+ METADATA
+ END
+ PROJECTION
+ "init=epsg:4326"
+ END
+ LABELITEM 'NAME'
+ CLASS
+ STYLE
+ COLOR 255 128 128
+ SYMBOL 'circle'
+ SIZE 9
+ END
+ LABEL
+ COLOR 0 0 0
+ TYPE TRUETYPE
+ FONT sans
+ SIZE 7
+ POSITION UC
+ PARTIALS FALSE
+ END
+ END
+ END
*Note:*
- `PropertyIsLike`_
+ </Filter>
+ </Filter>
@@ -437,7 +473,7 @@
.. index::
More information about the mapserver-commits
