[mapserver-commits] r13083 - in trunk/docs/en: images tinyows
Tue Feb 7 19:43:41 EST 2012
Author: halmueller
Date: 2012-02-07 16:43:41 -0800 (Tue, 07 Feb 2012)
New Revision: 13083
Added:
   trunk/docs/en/images/tinyOWS-WFS-T.png
   trunk/docs/en/images/tinyOWS-WFS.png
   trunk/docs/en/tinyows/openlayershowtobasic.txt
   trunk/docs/en/tinyows/openlayershowtotransactional.txt
cleaned up TinyOWS/OpenLayers how-to's for WFS and WFS-T
Added: trunk/docs/en/images/tinyOWS-WFS-T.png
(Binary files differ)
Property changes on: trunk/docs/en/images/tinyOWS-WFS-T.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/docs/en/images/tinyOWS-WFS.png
Property changes on: trunk/docs/en/images/tinyOWS-WFS.png
Modified: trunk/docs/en/tinyows/openlayershowtobasic.txt
--- trunk/docs/en/tinyows/openlayershowtobasic.txt	2012-02-07 23:41:28 UTC (rev 13082)
+++ trunk/docs/en/tinyows/openlayershowtobasic.txt	2012-02-08 00:43:41 UTC (rev 13083)
@@ -6,10 +6,10 @@
-0) Install PostGIS and TinyOWS.
+0) Install PostGIS and TinyOWS (:ref:`tinyows_serverinstallation`)
-1) Create a spatial Database called 'france'
+1) Within PostGIS, create a spatial database called 'france'
 .. code-block:: bash
@@ -20,9 +20,10 @@
-2) Import france data
+2) Import France data into your PostGIS database
   wget tinyows.org/tracdocs/release/france_data.tar.gz
   tar xvzf france_data.tar.gz
   cd world
@@ -30,7 +31,7 @@
-3) Configure TinyOWS (/usr/local/tinyows/config.xml)
+3) Configure TinyOWS by editing /usr/local/tinyows/config.xml
 .. code-block:: xml
@@ -51,42 +52,47 @@
-4) Check everything is fine with TinyOWS and PostGIS
+4) Test your installations of TinyOWS and PostGIS
-./YOUR_CGI-BIN_PATH/tinyows --check
-Config File:	 OK
-PG Connection:	 OK
-Available layers:
- - public.france  -> 27572 R
+.. code-block:: bash
+  ./YOUR_CGI-BIN_PATH/tinyows --check
+  Config File:	 OK
+  PG Connection:	 OK
+  Available layers:
+   - public.france  -> 27572 R
-5) Deploy OpenLayers
+5) Install OpenLayers
-wget http://openlayers.org/download/OpenLayers-2.9.tar.gz
-tar xvzf OpenLayers-2.9.tar.gz
-mv OpenLayers-2.9  /YOUR/SERVER/HTDOCS/
+  wget http://openlayers.org/download/OpenLayers-2.9.tar.gz
+  tar xvzf OpenLayers-2.9.tar.gz
+  mv OpenLayers-2.9  /YOUR/SERVER/HTDOCS/
-6) Install OpenLayers proxy (you need Python interpreter to make it works)
+6) Install the OpenLayers proxy (you need the Python interpreter to make it work)
-cp OpenLayers-2.9/examples/proxy.cgi  /YOUR/SERVER/CGI-BIN/
+  cp OpenLayers-2.9/examples/proxy.cgi  /YOUR/SERVER/CGI-BIN/
 7) Add localhost (or your server IP) to proxy allowedHosts (/YOUR/SERVER/CGI-BIN/proxy.cgi)
-allowedHosts = ['127.0.0.1', 'www.openlayers.org', 'openlayers.org', ... ]
+  allowedHosts = ['127.0.0.1', 'www.openlayers.org', 'openlayers.org', ... ]
-8) Create a new file in OpenLayers-2.9/examples/tinyows.html :
+8) Create a new file at OpenLayers-2.9/examples/tinyows.html :
 .. code-block:: html
   <html>
     <head>
         <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
@@ -119,10 +125,11 @@
-9) Create a new file in OpenLayers-2.9/examples/tinyows.js
+9) Create a new file at OpenLayers-2.9/examples/tinyows.js
 .. code-block:: javascript
   var map;
   OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
   function init() {
@@ -164,5 +171,8 @@
-10) Just test and play with !
-    You should obtain this kind of result: http://tinyows.org/tracdocs/demo/OpenLayers-2.9/examples/tinyows.html
+10) You should obtain an image similar to the one below. Live version is at
+    http://tinyows.org/tracdocs/demo/OpenLayers-2.9/examples/tinyows.html
+.. image:: ../images/tinyOWS-WFS.png
Modified: trunk/docs/en/tinyows/openlayershowtotransactional.txt
--- trunk/docs/en/tinyows/openlayershowtotransactional.txt	2012-02-07 23:41:28 UTC (rev 13082)
+++ trunk/docs/en/tinyows/openlayershowtotransactional.txt	2012-02-08 00:43:41 UTC (rev 13083)
@@ -7,91 +7,98 @@
+1) Within PostGIS, create a spatial database called 'tinyows'
-createdb -U postgres tinyows
-createlang -U postgres plpgsql tinyows
-psql -U postgres -d tinyows < `pg_config --sharedir`/contrib/postgis-1.5/postgis.sql
-psql -U postgres -d tinyows < `pg_config --sharedir`/contrib/postgis-1.5/spatial_ref_sys.sql
+  createdb -U postgres tinyows
+  createlang -U postgres plpgsql tinyows
+  psql -U postgres -d tinyows < `pg_config --sharedir`/contrib/postgis-1.5/postgis.sql
+  psql -U postgres -d tinyows < `pg_config --sharedir`/contrib/postgis-1.5/spatial_ref_sys.sql
-2) Import Frida data (we will use the parks layer)
-wget ftp://ftp.intevation.de/freegis/frida/frida-1.0.1-shp.tar.gz
-tar xvzf frida-1.0.1-shp.tar.gz
-cd frida-1.0.1-shp
-shp2pgsql -s 31467 -W LATIN1 -I gruenflaechen.shp frida | psql -U postgres -d tinyows
+2) Import Frida data (we will use the parks layer) into your PostGIS database
-<tinyows online_resource="http://127.0.0.1/cgi-bin/tinyows"
-         schema_dir="/usr/local/tinyows/schema/">
-  <pg host="127.0.0.1" user="postgres" password="postgres" dbname="tinyows" port="5432"/>
+  wget ftp://ftp.intevation.de/freegis/frida/frida-1.0.1-shp.tar.gz
+  tar xvzf frida-1.0.1-shp.tar.gz
+  cd frida-1.0.1-shp
+  shp2pgsql -s 31467 -W LATIN1 -I gruenflaechen.shp frida | psql -U postgres -d tinyows
+.. code-block:: xml
+  <tinyows online_resource="http://127.0.0.1/cgi-bin/tinyows"
+         schema_dir="/usr/local/tinyows/schema/">
+  <pg host="127.0.0.1" user="postgres" password="postgres" dbname="tinyows" port="5432"/>
   <metadata name="TinyOWS Server"
             title="TinyOWS Server - WFS-T Frida Service" />
   <contact name="TinyOWS Server"
            site="http://www.tinyows.org/"
            email="tinyows-users at lists.maptools.org" />
   <layer retrievable="1"
          writable="1"
          ns_prefix="tows"
          ns_uri="http://www.tinyows.org/"
          name="frida"
          title="Frida Parks" />
+  </tinyows>
-</tinyows>
-4) Check PostGIS ans Tinyows config:
-Config File:	 OK
-PG Connection:	 OK
-Available layers:
- - public.frida  -> 31467 RW
-5) Install !OpenLayers
+  Config File:	 OK
+  PG Connection:	 OK
+  Available layers:
+   - public.frida  -> 31467 RW
-6) Deploy !OpenLayers proxy
-8) Create a new file named !OpenLayers-2.9/examples/tinyows_wfs-t.html :
-<html>
+8) Create a new file at OpenLayers-2.9/examples/tinyows_wfs-t.html
+.. code-block:: html
+  <html>
   <head>
     <link rel="stylesheet" href="style.css" type="text/css" />
     <script src="../lib/OpenLayers.js"></script>
     <style>
 	#map {
     	    width: 800px;
    	    height: 500px;
@@ -160,7 +167,6 @@
     </style>
     <script src="tinyows_wfs-t.js"></script>
     </head>
     <body onload="init()">
         <h1 id="title">WFS Transaction Example, (TinyOWS ans OpenLayers)</h1>
         <div id="tags"></div>
@@ -186,22 +192,20 @@
             </p>
             <p>
                 See the <a href="tinyows_wfs-t.js" target="_blank">
                 wfs-protocol-transactions.js source</a> to see how this is done.
             </p>
         </div>
     </body>
-</html>
+  </html>
-9) Create a new file named !OpenLayers-2.9/examples/tinyows_wfs-t.js:
+9) Create a new file at OpenLayers-2.9/examples/tinyows_wfs-t.js
-var map, wfs;
-OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
+.. code-block:: javascript
-var DeleteFeature = OpenLayers.Class(OpenLayers.Control, {
+  var map, wfs;
+  OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
+  var DeleteFeature = OpenLayers.Class(OpenLayers.Control, {
     initialize: function(layer, options) {
         OpenLayers.Control.prototype.initialize.apply(this, [options]);
         this.layer = layer;
@@ -226,26 +230,19 @@
         OpenLayers.Control.prototype.setMap.apply(this, arguments);
     CLASS_NAME: "OpenLayers.Control.DeleteFeature"
-function showMsg(szMessage) {
+  function showMsg(szMessage) {
     document.getElementById("message").innerHTML = szMessage;
     setTimeout(
         "document.getElementById('message').innerHTML = ''",2000);
-function showSuccessMsg(){
+  function showSuccessMsg(){
     showMsg("Transaction successfully completed");
-function showFailureMsg(){
+  function showFailureMsg(){
     showMsg("An error occured while operating the transaction");
-function init() {
+  function init() {
     map = new OpenLayers.Map('map', {
         projection: new OpenLayers.Projection("EPSG:31467"),
         units: "m",
@@ -255,18 +252,15 @@
             new OpenLayers.Control.PanZoom()
     var osm = new OpenLayers.Layer.WMS(
         "OSM by Omniscale WMS",
 	"http://osm.omniscale.net/proxy/service",
         {layers: 'osm', format: 'image/jpeg'},
 	{projection:"EPSG:31467",  units: "m", maxResolution: "auto", maxExtent: new OpenLayers.Bounds(3427000,5788000,3444000,5800000)}
     var saveStrategy = new OpenLayers.Strategy.Save();
     saveStrategy.events.register("success", '', showSuccessMsg);
     saveStrategy.events.register("fail", '', showFailureMsg);
     wfs = new OpenLayers.Layer.Vector("Editable Features", {
         strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
@@ -280,17 +274,13 @@
             schema: "http://127.0.0.1/cgi-bin/tinyows?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=tows:frida"
     map.addLayers([osm, wfs]);
     var panel = new OpenLayers.Control.Panel(
         {'displayClass': 'customEditingToolbar'}
     var navigate = new OpenLayers.Control.Navigation({
         title: "Pan Map"
     var draw = new OpenLayers.Control.DrawFeature(
         wfs, OpenLayers.Handler.Polygon,
@@ -299,14 +289,11 @@
             multi: true
     var edit = new OpenLayers.Control.ModifyFeature(wfs, {
         title: "Modify Feature",
         displayClass: "olControlModifyFeature"
     var del = new DeleteFeature(wfs, {title: "Delete Feature"});
     var save = new OpenLayers.Control.Button({
         title: "Save Changes",
         trigger: function() {
@@ -317,19 +304,17 @@
         displayClass: "olControlSaveFeatures"
     panel.addControls([navigate, save, del, edit, draw]);
     panel.defaultControl = navigate;
     map.addControl(panel);
     map.zoomToMaxExtent();
+10) You should obtain an image similar to the one below. Note the
+    editor icons in the upper right corner. These icons allow you to
+    add and edit features in the database from your web browser. Live version is at
+    http://tinyows.org/tracdocs/demo/OpenLayers-2.9/examples/tinyows_wfs-t.html
-    You should obtain something like: http://tinyows.org/tracdocs/demo/OpenLayers-2.9/examples/tinyows_wfs-t.html
+.. image:: ../images/tinyOWS-WFS-T.png
-11) Think about Optimization
-   - !OpenLayers build: http://trac.openlayers.org/wiki/Profiles
-   - TinyOWS Tuning: http://tinyows.org/trac/wiki/ServerTuning
