[mapserver-commits] r13098 - in trunk/docs/en: installation tinyows
Wed Feb 8 14:39:40 EST 2012
Author: dmiddlecamp
Date: 2012-02-08 11:39:40 -0800 (Wed, 08 Feb 2012)
New Revision: 13098
   trunk/docs/en/installation/unix.txt
   trunk/docs/en/tinyows/serverinstallation.txt
   trunk/docs/en/tinyows/servertuning.txt
cleanup, expanding performance tips, adding install link warning
Modified: trunk/docs/en/installation/unix.txt
--- trunk/docs/en/installation/unix.txt	2012-02-08 19:25:22 UTC (rev 13097)
+++ trunk/docs/en/installation/unix.txt	2012-02-08 19:39:40 UTC (rev 13098)
@@ -159,9 +159,11 @@
   More details on how to use this feature in MapServer is here :ref:`fastcgi`.
   On Ubuntu, that would be
-  .. installing fastcgi development package::
-      sudo apt-get -y install libfcgi-dev
+        installing fastcgi development package
+        [user at host mapserver]$ sudo apt-get -y install libfcgi-dev
 * `cairo (svg, pdf) support <http://cairographics.org/>`__: This library is required
   when using the "--with-cairo" configure option.  If you're on an ubuntu system, it
   can be installed with "sudo apt-get install -y libcairo2-dev"
@@ -204,7 +206,7 @@
-    gdlib-config --version
+    [user at host mapserver]$ gdlib-config --version
  libiconv
@@ -217,7 +219,7 @@
-    gdlib-config --libs
+    [user at host mapserver]$ gdlib-config --libs
  Pre-packaged/system libraries
@@ -260,8 +262,8 @@
     checking where FreeType is installed...
     checking for FT_Init_FreeType in -lfreetype... yes
-	    using libfreetype -lfreetype from system libs.
+    using libfreetype -lfreetype from system libs.
 Even though you have FreeType installed on your system *and* the
 configure script finds it, does *NOT* mean you will have TrueType
 font support. GD *MUST* be compiled against FreeType either way.
@@ -627,31 +629,33 @@
 The main goal is to get the "mapserv" binary installed in a publicly
 accessible directory that is configured to run CGI programs and scripts.
-1.  Locate your cgi-bin directory.  Under a default configuration,
+1. Locate your cgi-bin directory.  Under a default configuration,
 the CGI directory is "/usr/local/apache/cgi-bin" (RedHat users
 will use "/home/httpd/cgi-bin").   if you're using apache, there should be a
-ScriptAlias directive in your http.conf, or default site, something like:
+ScriptAlias directive in your http.conf, or default site, something like::
+    [user at host mapserver]$ cat /etc/apache2/sites-available/default | grep 'cgi-bin'
+    ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
-      [user at host mapserver]$ cat /etc/apache2/sites-available/default | grep 'cgi-bin'
-      ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
-2.  Locate the installation path of your freshly compiled mapserv executable.
-This is shown when you run "sudo make install", something like this:
+2. Locate the installation path of your freshly compiled mapserv executable.
+This is shown when you run "sudo make install", something like this::
+    libtool: install: /usr/bin/install -c .libs/mapserv /usr/local/bin/mapserv
-      libtool: install: /usr/bin/install -c .libs/mapserv /usr/local/bin/mapserv
-3.  You'll want to setup a symlink to that executable from your cgi-bin directory.
+.. This indent is driving me insane.
+3. You'll want to setup a symlink to that executable from your cgi-bin directory::
-      [user at host mapserver]$ sudo ln -s /usr/local/bin/mapserv /usr/lib/cgi-bin/mapserv
+    [user at host mapserver]$ sudo ln -s /usr/local/bin/mapserv /usr/lib/cgi-bin/mapserv
+    .. warning::
+       Make sure you are linking against the installed mapserv file (after running 'make install')
+       and NOT against where it was compiled in your source tree.
 Testing your new Install
 Placing the mapserv file in this directory makes it accessible by the following URL:
Modified: trunk/docs/en/tinyows/serverinstallation.txt
--- trunk/docs/en/tinyows/serverinstallation.txt	2012-02-08 19:25:22 UTC (rev 13097)
+++ trunk/docs/en/tinyows/serverinstallation.txt	2012-02-08 19:39:40 UTC (rev 13098)
@@ -4,23 +4,17 @@
 TinyOWS Installation
-.. warning:: Fix author block
+.. warning:: Author Block?
-:Author: Howard Butler
-:Contact: hobu.inc at gmail.com
-:Revision: $Revision: 13079 $
-:Date: $Date: 2012-02-07 13:58:04 -0800 (Tue, 07 Feb 2012) $
 Requires
 TinyOWS need following librairies/applications:
-  * LibXML2 (2.6.20 version or later)
-  * PostGIS (1.5.x version or later)
-  * PostgreSQL (with libpq headers)
-  * A working Web Server with cgi-bin support
-  * Fast-CGI is recommended
+ * LibXML2 (2.6.20 version or later)
+ * PostGIS (1.5.x version or later)
+ * PostgreSQL (with libpq headers)
+ * A working Web Server with cgi-bin support
+ * Fast-CGI is recommended
 Installing from a stable source release
@@ -42,8 +36,8 @@
 Installing from SVN
 Build from SVN need also following librairies/applications:
-  * autoconf
-  * SVN client
+ * autoconf
+ * SVN client
@@ -57,8 +51,7 @@
 And then copy tinyows binary in your cgi-bin directory
-Installing on Windows from SVN
+Installing from SVN on Windows
-From SVN with Visual C++ for Win32
-  * [http://gis-lab.info/qa/tinyows-compile-vce-eng.html] (written by Alexander Bruy)
+ * `From SVN with Visual C++ for Win32 <http://gis-lab.info/qa/tinyows-compile-vce-eng.html>`_ (written by Alexander Bruy)
Modified: trunk/docs/en/tinyows/servertuning.txt
--- trunk/docs/en/tinyows/servertuning.txt	2012-02-08 19:25:22 UTC (rev 13097)
+++ trunk/docs/en/tinyows/servertuning.txt	2012-02-08 19:39:40 UTC (rev 13098)
@@ -1,45 +1,76 @@
 .. _tinyows_servertuning:
-= Server Tuning: How to speed up your TinyOWS server ? =
+Server Tuning: How to speed up your TinyOWS server
-== PostgreSQL/PostGIS datas ==
-  * Be sure to have a spatial index on your geometry/geography datas
-  * Put index on each column who could be used frequently as a filter
-== HTTP Gzip compression ==
-  * In Apache, activate mod_deflate
-  * Deflate basic configuration:
-AddOutputFilterByType DEFLATE text/html text/plain text/xml application/xml application/json
+Tips and Tricks for PostgreSQL / PostGIS databases
+ * Index any column that could be used frequently as a filter
+ * Use Spatial Indexes on your geometry/geography columns
+   `PostGIS Spatial Indexes <http://postgis.refractions.net/docs/ch04.html#id2628096>`_.
-== Fast-CGI ==
-  * Check that your TinyOWS is compiled with FastCGI support:
-tinyows --check
-TinyOWS version:   0.9.0 SVN
-FCGI support:      Yes
+ * General `PostGIS Performance tips <http://postgis.refractions.net/docs/ch06.html>`_
+ * General `PostgreSQL Performance tips <http://wiki.postgresql.org/wiki/Performance_Optimization>`_
+ * `Even more tips on Tuning PostgreSQL <http://wiki.postgresql.org/wiki/Tuning_Your_PostgreSQL_Server>`_
-=== Unix Like ===
+Tips and Tricks for Apache
+HTTP Gzip compression
+* In Apache, activate `mod_deflate <http://httpd.apache.org/docs/2.0/mod/mod_deflate.html>`_
+* Deflate basic configuration, (note we're including xml and json):
+        AddOutputFilterByType DEFLATE text/html text/plain text/xml application/xml application/json
+Using Fast-CGI
+* Check that your TinyOWS is compiled with FastCGI support:
+        [user at host mapserver]$ tinyows --check
+        TinyOWS version:   1.0.0 SVN
+        FCGI support:      Yes
+Fast-CGI in Apache
   * In Apache, activate mod_fcgi
+       [user at host mapserver]$ sudo apt-get install -y libapache2-mod-fastcgi
+       [user at host mapserver]$ sudo a2enmod fastcgi
   * Apache fast-cgi configuration:
-  FastCgiServer /usr/lib/cgi-bin/tinyows.fcgi -processes 40
-  FastCgiConfig -initial-env LD_LIBRARY_PATH=/usr/local/lib:/usr/pgsql/lib:/usr/lib:/lib -appConnTimeout 60 -idle-timeout 60 -init-start-delay 1 -minProcesses 3 -maxClassProcesses 30 -startDelay 10
-=== MS4W ===
-  * Please refer to the fastcgi doc in ms4w: [http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#f-fastcgi]
-  * Add the following 2 lines:
-DefaultInitEnv TINYOWS_CONFIG_FILE "/ms4w/apps/tinyows/config.xml"
-DefaultInitEnv TINYOWS_SCHEMA_DIR "/ms4w/apps/tinyows/schema/"
+        #in your CGI-BIN directive, add the following to run all cgi-bin using FastCGI
+        SetHandler fastcgi-script
+        #in your FastCGI config file (typically something like /etc/apache2/mods-enabled/fastcgi.conf)
+        FastCgiServer /usr/lib/cgi-bin/tinyows.fcgi -processes 40
+        FastCgiConfig -initial-env LD_LIBRARY_PATH=/usr/local/lib:/usr/pgsql/lib:/usr/lib:/lib -appConnTimeout 60 -idle-timeout 60 -init-start-delay 1 -minProcesses 3 -maxClassProcesses 30 -startDelay 10
+Fast-CGI in MS4W
+* Please refer to the  `fastcgi doc in ms4w <http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#f-fastcgi>`_
+* Add the following 2 lines:
+        DefaultInitEnv TINYOWS_CONFIG_FILE "/ms4w/apps/tinyows/config.xml"
+        DefaultInitEnv TINYOWS_SCHEMA_DIR "/ms4w/apps/tinyows/schema/"
