[mapserver-commits] r13107 - trunk/mapserver
Wed Feb 8 18:39:26 EST 2012
Author: tbonfort
Date: 2012-02-08 15:39:26 -0800 (Wed, 08 Feb 2012)
New Revision: 13107
   trunk/mapserver/mapservutil.c
don't do cgi url replacements and substitutions if mapfile was marked as immutable
Modified: trunk/mapserver/mapservutil.c
--- trunk/mapserver/mapservutil.c	2012-02-08 23:31:59 UTC (rev 13106)
+++ trunk/mapserver/mapservutil.c	2012-02-08 23:39:26 UTC (rev 13107)
@@ -233,43 +233,48 @@
   if(!map) return NULL;
-  /* check for any %variable% substitutions here, also do any map_ changes, we do this here so WMS/WFS  */
-  /* services can take advantage of these "vendor specific" extensions */
-  for(i=0;i<mapserv->request->NumParams;i++) {
-    ** a few CGI variables should be skipped altogether
-    ** qstring: there is separate per layer validation for attribute queries and the substitution checks
-    **          below conflict with that so we avoid it here
-    if(strncasecmp(mapserv->request->ParamNames[i],"qstring",7) == 0) continue;
-    if(strncasecmp(mapserv->request->ParamNames[i],"map_",4) == 0 || strncasecmp(mapserv->request->ParamNames[i],"map.",4) == 0) { /* check to see if there are any additions to the mapfile */
-      if(msUpdateMapFromURL(map, mapserv->request->ParamNames[i], mapserv->request->ParamValues[i]) != MS_SUCCESS) {
-         msFreeMap(map);
-         return NULL;
-      continue;
-  msApplySubstitutions(map, mapserv->request->ParamNames, mapserv->request->ParamValues, mapserv->request->NumParams);
-  msApplyDefaultSubstitutions(map);
+  if(!msLookupHashTable(&(map->web.validation), "immutable")) {
+     /* check for any %variable% substitutions here, also do any map_ changes, we do this here so WMS/WFS  */
+     /* services can take advantage of these "vendor specific" extensions */
+     for(i=0;i<mapserv->request->NumParams;i++) {
+         ** a few CGI variables should be skipped altogether
+         ** qstring: there is separate per layer validation for attribute queries and the substitution checks
+         **          below conflict with that so we avoid it here
+        if(strncasecmp(mapserv->request->ParamNames[i],"qstring",7) == 0) continue;
-  /* check to see if a ogc map context is passed as argument. if there */
-  /* is one load it */
+        if(strncasecmp(mapserv->request->ParamNames[i],"map_",4) == 0 || strncasecmp(mapserv->request->ParamNames[i],"map.",4) == 0) { /* check to see if there are any additions to the mapfile */
+           if(msUpdateMapFromURL(map, mapserv->request->ParamNames[i], mapserv->request->ParamValues[i]) != MS_SUCCESS) {
+              msFreeMap(map);
+              return NULL;
+           continue;
-    if(strcasecmp(mapserv->request->ParamNames[i],"context") == 0) {
-      if(mapserv->request->ParamValues[i] && strlen(mapserv->request->ParamValues[i]) > 0) {
-        if(strncasecmp(mapserv->request->ParamValues[i],"http",4) == 0) {
-          if(msGetConfigOption(map, "CGI_CONTEXT_URL"))
-            msLoadMapContextURL(map, mapserv->request->ParamValues[i], MS_FALSE);
-        } else
-            msLoadMapContext(map, mapserv->request->ParamValues[i], MS_FALSE);
+     msApplySubstitutions(map, mapserv->request->ParamNames, mapserv->request->ParamValues, mapserv->request->NumParams);
+     msApplyDefaultSubstitutions(map);
+     /* check to see if a ogc map context is passed as argument. if there */
+     /* is one load it */
+        if(strcasecmp(mapserv->request->ParamNames[i],"context") == 0) {
+           if(mapserv->request->ParamValues[i] && strlen(mapserv->request->ParamValues[i]) > 0) {
+              if(strncasecmp(mapserv->request->ParamValues[i],"http",4) == 0) {
+                 if(msGetConfigOption(map, "CGI_CONTEXT_URL"))
+                    msLoadMapContextURL(map, mapserv->request->ParamValues[i], MS_FALSE);
+              } else
+                 msLoadMapContext(map, mapserv->request->ParamValues[i], MS_FALSE);
    * RFC-42 HTTP Cookie Forwarding
    * Here we set the http_cookie_data metadata to handle the
