[mapserver-commits] r13109 - trunk/docs/en
svn at osgeo.org
svn at osgeo.org
Wed Feb 8 20:08:56 EST 2012
Author: halmueller
Date: 2012-02-08 17:08:56 -0800 (Wed, 08 Feb 2012)
New Revision: 13109
trunk/docs/en/introduction.txt
typo
Modified: trunk/docs/en/introduction.txt
--- trunk/docs/en/introduction.txt 2012-02-09 00:35:18 UTC (rev 13108)
+++ trunk/docs/en/introduction.txt 2012-02-09 01:08:56 UTC (rev 13109)
@@ -676,7 +676,7 @@
If you add geographic data layers with different geographical
reference systems, you will need to modify your Map File to add a
:ref:`PROJECTION` block to the :ref:`map` (defines the output
-projection / geograpical reference system) and each of the
+projection / geographical reference system) and each of the
:ref:`layer`\s (defines the geographical reference system of the layer
dataset).
More information about the mapserver-commits
