[mapserver-commits] r13125 - trunk/mapserver/tinyows/src
Wed Feb 8 20:34:49 EST 2012
Author: colivier
Date: 2012-02-08 17:34:49 -0800 (Wed, 08 Feb 2012)
New Revision: 13125
Added:
   trunk/mapserver/tinyows/src/ows_api.h
no more ows_api.h generation
ol | 2008-03-02 21:11:35 +0100 (Sun, 02 Mar 2008)
Added: trunk/mapserver/tinyows/src/ows_api.h
--- trunk/mapserver/tinyows/src/ows_api.h	                        (rev 0)
+++ trunk/mapserver/tinyows/src/ows_api.h	2012-02-09 01:34:49 UTC (rev 13125)
@@ -0,0 +1,193 @@
+/* This file is generated by Makefile, don't edit */
+void array_add (array * a, buffer * key, buffer * value);
+void array_flush (const array * a, FILE * output);
+void array_free (array * a);
+buffer *array_get (const array * a, const char *key);
+array *array_init ();
+bool array_is_key (const array * a, const char *key);
+void buffer_add (buffer * buf, char c);
+void buffer_add_double (buffer * buf, double f);
+void buffer_add_head (buffer * buf, char c);
+void buffer_add_head_str (buffer * buf, char *str);
+void buffer_add_int (buffer * buf, int i);
+void buffer_add_str (buffer * buf, const char *str);
+bool buffer_case_cmp (const buffer * buf, const char *str);
+bool buffer_cmp (const buffer * buf, const char *str);
+void buffer_copy (buffer * dest, const buffer * src);
+void buffer_empty (buffer * buf);
+void buffer_flush (buffer * buf, FILE * output);
+void buffer_free (buffer * buf);
+buffer *buffer_ftoa (double f);
+buffer *buffer_init ();
+buffer *buffer_itoa (int i);
+void buffer_pop (buffer * buf, size_t len);
+buffer *buffer_replace (buffer * buf, char *before, char *after);
+void buffer_shift (buffer * buf, size_t len);
+buffer *cgi_add_xml_into_buffer (buffer * element, xmlNodePtr n);
+char *cgi_getback_query (ows * o);
+bool cgi_method_get ();
+bool cgi_method_post ();
+array *cgi_parse_kvp (ows * o, char *query);
+array *cgi_parse_xml (ows * o, char *query);
+bool check_regexp (const char *str_request, const char *str_regex);
+buffer *fe_comparison_op (ows * o, buffer * typename, filter_encoding * fe, xmlNodePtr n);
+buffer *fe_envelope (ows * o, buffer * typename, filter_encoding * fe, xmlNodePtr n);
+void fe_error (ows * o, filter_encoding * fe);
+buffer *fe_expression (ows * o, buffer * typename, filter_encoding * fe, buffer * sql, xmlNodePtr n);
+buffer *fe_feature_id (ows * o, buffer * typename, filter_encoding * fe, xmlNodePtr n);
+filter_encoding *fe_filter (ows * o, filter_encoding * fe, buffer * typename, buffer * xmlchar);
+void fe_filter_capabilities_100 (const ows * o);
+void fe_filter_capabilities_110 (const ows * o);
+buffer *fe_function (ows * o, buffer * typename, filter_encoding * fe, buffer * sql, xmlNodePtr n);
+bool fe_is_comparison_op (char *name);
+bool fe_is_logical_op (char *name);
+bool fe_is_spatial_op (char *name);
+buffer *fe_kvp_bbox (ows * o, wfs_request * wr, buffer * layer_name, ows_bbox * bbox);
+buffer *fe_kvp_featureid (ows * o, wfs_request * wr, buffer * layer_name, list * fid);
+buffer *fe_logical_op (ows * o, buffer * typename, filter_encoding * fe, xmlNodePtr n);
+void fe_node_flush (xmlNodePtr node, FILE * output);
+buffer *fe_property_name (ows * o, buffer * typename, filter_encoding * fe, buffer * sql, xmlNodePtr n);
+buffer *fe_spatial_op (ows * o, buffer * typename, filter_encoding * fe, xmlNodePtr n);
+buffer *fe_transform_coord_gml3_to_psql (buffer * coord);
+buffer *fe_transform_coord_gml_to_psql (buffer * coord);
+buffer *fe_transform_geometry_gml_to_psql (ows * o, buffer * typename, filter_encoding * fe, xmlNodePtr n);
+buffer *fe_xpath_property_name (ows * o, buffer * typename, buffer * property);
+buffer *fill_fe_error (ows * o, filter_encoding * fe);
+void filter_encoding_flush (ows * o, filter_encoding * fe, FILE * output);
+void filter_encoding_free (filter_encoding * fe);
+filter_encoding *filter_encoding_init ();
+bool in_list (const list * l, const buffer * value);
+void list_add (list * l, buffer * value);
+void list_add_by_copy (list * l, buffer * value);
+void list_add_list (list * l, list * l_to_add);
+void list_add_str (list * l, char *value);
+list *list_explode (char separator, const buffer * value);
+list *list_explode_start_end (char separator_start, char separator_end, buffer * value);
+list *list_explode_str (char separator, const char *value);
+void list_flush (const list * l, FILE * output);
+void list_free (list * l);
+list *list_init ();
+void list_node_free (list * l, list_node * ln);
+list_node *list_node_init ();
+int main (int argc, char *argv[]);
+void mlist_add (mlist * ml, list * value);
+mlist *mlist_explode (char separator_start, char separator_end, buffer * value);
+void mlist_flush (const mlist * ml, FILE * output);
+void mlist_free (mlist * ml);
+mlist *mlist_init ();
+void mlist_node_free (mlist * ml, mlist_node * mln);
+mlist_node *mlist_node_init ();
+ows_bbox *ows_bbox_boundaries (ows * o, list * from, list * where);
+void ows_bbox_flush (const ows_bbox * b, FILE * output);
+void ows_bbox_free (ows_bbox * b);
+ows_bbox *ows_bbox_init ();
+bool ows_bbox_set (ows * o, ows_bbox * b, double xmin, double ymin, double xmax, double ymax, int srid);
+bool ows_bbox_set_from_geobbox (ows * o, ows_bbox * bb, ows_geobbox * geo);
+bool ows_bbox_set_from_str (ows * o, ows_bbox * bb, const char *str, int srid);
+bool ows_bbox_transform (ows * o, ows_bbox * bb, int srid);
+void ows_contact_flush (ows_contact * contact, FILE * output);
+void ows_contact_free (ows_contact * contact);
+ows_contact *ows_contact_init ();
+void ows_error (ows * o, enum ows_error_code code, char *message, char *locator);
+void ows_flush (ows * o, FILE * output);
+void ows_free (ows * o);
+ows_geobbox *ows_geobbox_compute (ows * o, buffer * layer_name);
+void ows_geobbox_flush (const ows_geobbox * g, FILE * output);
+void ows_geobbox_free (ows_geobbox * g);
+ows_geobbox *ows_geobbox_init ();
+bool ows_geobbox_set (ows * o, ows_geobbox * g, double west, double east, double south, double north);
+bool ows_geobbox_set_from_bbox (ows * o, ows_geobbox * g, ows_bbox * bb);
+ows_geobbox *ows_geobbox_set_from_str (ows * o, ows_geobbox * g, char *str);
+void ows_get_capabilities_dcpt (const ows * o);
+void ows_layer_flush (ows_layer * l, FILE * output);
+void ows_layer_free (ows_layer * l);
+bool ows_layer_in_list (const ows_layer_list * ll, buffer * name);
+ows_layer *ows_layer_init ();
+void ows_layer_list_add (ows_layer_list * ll, ows_layer * l);
+list *ows_layer_list_by_prefix (ows_layer_list * ll, list * layer_name, buffer * prefix);
+void ows_layer_list_flush (ows_layer_list * ll, FILE * output);
+void ows_layer_list_free (ows_layer_list * ll);
+bool ows_layer_list_in_list (const ows_layer_list * ll, const list * l);
+ows_layer_list *ows_layer_list_init ();
+array *ows_layer_list_namespaces (ows_layer_list * ll);
+list *ows_layer_list_prefix (ows_layer_list * ll, list * layer_name);
+bool ows_layer_list_retrievable (const ows_layer_list * ll);
+bool ows_layer_list_writable (const ows_layer_list * ll);
+bool ows_layer_match_table (ows * o, buffer * layer_name);
+void ows_layer_node_free (ows_layer_list * ll, ows_layer_node * ln);
+ows_layer_node *ows_layer_node_init ();
+buffer *ows_layer_prefix (ows_layer_list * ll, buffer * layer_name);
+bool ows_layer_retrievable (const ows_layer_list * ll, const buffer * name);
+buffer *ows_layer_server (ows_layer_list * ll, buffer * prefix);
+bool ows_layer_writable (const ows_layer_list * ll, const buffer * name);
+void ows_metadata_fill (ows * o, array * cgi);
+void ows_metadata_flush (ows_meta * metadata, FILE * output);
+void ows_metadata_free (ows_meta * metadata);
+ows_meta *ows_metadata_init ();
+void ows_parse_config (ows * o, const char *filename);
+void ows_parse_config_abstract (ows * o, xmlTextReaderPtr r);
+void ows_parse_config_contact (ows * o, xmlTextReaderPtr r);
+void ows_parse_config_layer (ows * o, xmlTextReaderPtr r);
+ows_layer *ows_parse_config_layer_get_parent (const ows * o, int depth);
+void ows_parse_config_limits (ows * o, xmlTextReaderPtr r);
+void ows_parse_config_metadata (ows * o, xmlTextReaderPtr r);
+void ows_parse_config_pg (ows * o, xmlTextReaderPtr r);
+void ows_parse_config_style (ows * o, xmlTextReaderPtr r);
+buffer *ows_psql_column_name (ows * o, buffer * layer_name, int number);
+array *ows_psql_describe_table (ows * o, buffer * layer_name);
+list *ows_psql_geometry_column (ows * o, buffer * layer_name);
+buffer *ows_psql_id_column (ows * o, buffer * layer_name);
+bool ows_psql_is_geometry_column (ows * o, buffer * layer_name, buffer * column);
+list *ows_psql_not_null_properties (ows * o, buffer * layer_name);
+int ows_psql_num_column (ows * o, buffer * layer_name, buffer * column);
+int ows_psql_number_features (ows * o, list * from, list * where);
+void ows_psql_prepare (ows * o, buffer * request_name, buffer * parameters, buffer * sql);
+buffer *ows_psql_timestamp_to_xml_datetime (char *date);
+char *ows_psql_to_xsd (buffer * type);
+buffer *ows_psql_type (ows * o, buffer * layer_name, buffer * property);
+void ows_request_check (ows * o, ows_request * or, const array * cgi, const char *query);
+void ows_request_flush (ows_request * or, FILE * output);
+void ows_request_free (ows_request * or);
+ows_request *ows_request_init ();
+int ows_schema_validation (char *xml_schema_file, buffer * xmlchar);
+void ows_service_identification (const ows * o);
+void ows_service_metadata (const ows * o);
+void ows_service_provider (const ows * o);
+void ows_srs_flush (ows_srs * c, FILE * output);
+void ows_srs_free (ows_srs * c);
+buffer *ows_srs_get_from_a_srid (ows * o, buffer * srid);
+list *ows_srs_get_from_srid (ows * o, list * l);
+buffer *ows_srs_get_srid_from_layer (ows * o, buffer * layer_name);
+ows_srs *ows_srs_init ();
+bool ows_srs_meter_units (ows * o, buffer * layer_name);
+bool ows_srs_set (ows * o, ows_srs * c, const buffer * auth_name, int auth_srid);
+bool ows_srs_set_from_srid (ows * o, ows_srs * s, int srid);
+void ows_usage (ows * o);
+void ows_version_flush (ows_version * v, FILE * output);
+void ows_version_free (ows_version * v);
+int ows_version_get (ows_version * v);
+ows_version *ows_version_init ();
+void ows_version_set (ows_version * v, int major, int minor, int release);
+void sld_parse_file (ows * o, const char *filename);
+void wfs (ows * o, wfs_request * wf);
+void wfs_delete (ows * o, wfs_request * wr);
+void wfs_describe_feature_type (ows * o, wfs_request * wr);
+void wfs_error (ows * o, wfs_request * wf, enum wfs_error_code code, char *message, char *locator);
+void wfs_get_capabilities (ows * o, wfs_request * wr);
+void wfs_get_feature (ows * o, wfs_request * wr);
+void wfs_gml_bounded_by (ows * o, wfs_request * wr, float xmin, float ymin, float xmax, float ymax, int srid);
+void wfs_gml_feature_member (ows * o, wfs_request * wr, buffer * layer_name, list * properties, PGresult * res);
+void wfs_parse_operation (ows * o, wfs_request * wr, buffer * op);
+void wfs_request_check (ows * o, wfs_request * wr, const array * cgi);
+void wfs_request_flush (wfs_request * wr, FILE * output);
+void wfs_request_free (wfs_request * wr);
+wfs_request *wfs_request_init ();
+buffer *wfs_request_remove_namespaces (ows * o, buffer * b);
+void wms (ows * o, wms_request * wr);
+void wms_error (ows * o, wms_request * wr, enum wms_error_code code, char *message);
+void wms_get_capabilities (ows * o, const wms_request * wr);
+void wms_get_map (ows * o, wms_request * wr);
+void wms_request_check (ows * o, wms_request * wr, const array * cgi);
+void wms_request_flush (wms_request * wr, FILE * output);
+void wms_request_free (wms_request * wr);
+wms_request *wms_request_init ();
