[mapserver-commits] r13131 - trunk/mapserver
Thu Feb 9 13:13:33 EST 2012
Author: tbonfort
Date: 2012-02-09 10:13:32 -0800 (Thu, 09 Feb 2012)
New Revision: 13131
   trunk/mapserver/mapservutil.c
fix file stat member usage
Modified: trunk/mapserver/mapservutil.c
--- trunk/mapserver/mapservutil.c	2012-02-09 09:43:14 UTC (rev 13130)
+++ trunk/mapserver/mapservutil.c	2012-02-09 18:13:32 UTC (rev 13131)
@@ -177,7 +177,7 @@
   int i;
   mapObj *map = NULL;
   static mapObj *preloadedmap = NULL;
-  static struct timespec preloadedmap_mtime;
+  static time_t preloadedmap_mtime;
   static char *ms_mapfile = NULL;
   struct stat mapfile_stat;
@@ -187,7 +187,7 @@
      if(preloadedmap) {
         /* we already have a preloaded mapfile, check if the mapfile itself hasn't changed */
         stat(ms_mapfile,&mapfile_stat);
-        if(mapfile_stat.st_mtimespec.tv_sec > preloadedmap_mtime.tv_sec) {
+        if(mapfile_stat.st_mtime > preloadedmap_mtime) {
            /* the mapfile has been updated on disk, discard the cached mapObj */
            msFreeMap(preloadedmap);
@@ -199,7 +199,7 @@
         preloadedmap = msLoadMap(ms_mapfile,NULL);
         if(!preloadedmap) return NULL;
-        preloadedmap_mtime = mapfile_stat.st_mtimespec;
+        preloadedmap_mtime = mapfile_stat.st_mtime;
      map = msNewMapObj();
      msCopyMap(map,preloadedmap);
