[mapserver-commits] r13145 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 13 23:53:12 EST 2012
Author: sdlime
Date: 2012-02-13 20:53:12 -0800 (Mon, 13 Feb 2012)
New Revision: 13145
trunk/mapserver/mapagg.cpp
trunk/mapserver/mapkmlrenderer.cpp
Make sure KML support compiles after multi-label changes...
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2012-02-13 21:58:25 UTC (rev 13144)
+++ trunk/mapserver/mapagg.cpp 2012-02-14 04:53:12 UTC (rev 13145)
@@ -794,7 +794,8 @@
pixel_format pf(b);
AGG2Renderer *r = AGG_RENDERER(dest);
mapserver::rect_base<int> src_rect(srcX,srcY,srcX+width,srcY+height);
- r->m_renderer_base.blend_from(pf,&src_rect, dstX-srcX, dstY-srcY, unsigned(opacity * 255));
+ // r->m_renderer_base.blend_from(pf,&src_rect, dstX-srcX, dstY-srcY, unsigned(opacity * 255));
+ r->m_renderer_base.blend_from(pf,&src_rect, dstX, dstY, unsigned(opacity * 255));
return MS_SUCCESS;
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp 2012-02-13 21:58:25 UTC (rev 13144)
+++ trunk/mapserver/mapkmlrenderer.cpp 2012-02-14 04:53:12 UTC (rev 13145)
@@ -233,7 +233,7 @@
/*if there are labels we want the coordinates to
be the center of the element.*/
for(i=0; i<layer->numclasses; i++)
- layer->_class[i]->label.position = MS_XY;
+ if(layer->_class[i]->numlabels > 0) layer->_class[i]->labels[0]->position = MS_XY;
/*we do not want to draw multiple styles.
the new rendering architecture does not allow
More information about the mapserver-commits
