[mapserver-commits] r13162 - trunk/docs/en/development/rfc
svn at osgeo.org
svn at osgeo.org
Wed Feb 22 08:29:03 EST 2012
Author: sdlime
Date: 2012-02-22 05:29:03 -0800 (Wed, 22 Feb 2012)
New Revision: 13162
trunk/docs/en/development/rfc/ms-rfc-77.txt
Added voting history and a configuration example (more to come).
Modified: trunk/docs/en/development/rfc/ms-rfc-77.txt
--- trunk/docs/en/development/rfc/ms-rfc-77.txt 2012-02-22 09:14:09 UTC (rev 13161)
+++ trunk/docs/en/development/rfc/ms-rfc-77.txt 2012-02-22 13:29:03 UTC (rev 13162)
@@ -125,12 +125,35 @@
#4127. Work is underway in a sandbox (http://svn.osgeo.org/mapserver/sandbox/sdlime/rfc-77/).
-4. Backwards Compatibility
+4 Configuration Examples
+Adding optional text below other text:
+ LABELITEM 'item1'
+ CLASS
+ LABEL # always displayed using LAYER:LABELITEM as a source for text
+ FONT 'arial'
+ END
+ LABEL # conditionally displayed using LABEL:TEXT as a source for text
+ EXPRESSION ('[item2]' ~ '.') # item2 has something in it
+ FONT 'arial-italic'
+ TEXT '[item2]'
+ OFFSET 0 15
+ END
+ END
+5. Backwards Compatibility
At the mapfile level there are no issues, existing mapfiles should run without any change. It is possible that this could
introduce regressions within MapScript although the scope is not fully known.
-4.1 Relationship to Other Outstanding Label Bugs
+5.1 Relationship to Other Outstanding Label Bugs
* #1355 - None, test is valid w/grouped labels too.
@@ -141,12 +164,12 @@
* #3335 - Styles are supported for each additional label.
* #3675 - This will be adressed by this RFC. Label content will be defined by the new TEXT attribute.
-5. Enhancements
+6. Enhancements
Although beyond the scope of this work it seems that some interesting work related to the relative placement of grouped
labels might be possible. For example, it could be useful to define positions relative to the previous label instead of
relative to a label point.
-6. Voting history
+7. Voting history
-None
+Adopted on 12-15-2011 with +1 from SteveL, DanM, JeffM, ThomasB, SteveW, HowardW.
More information about the mapserver-commits
