[mapserver-commits] r13168 - in trunk/mapserver: . mapscript/java
svn at osgeo.org
svn at osgeo.org
Thu Feb 23 08:58:25 EST 2012
Author: unicoletti
Date: 2012-02-23 05:58:25 -0800 (Thu, 23 Feb 2012)
New Revision: 13168
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscript/java/README
Improved readme as per tbonfort suggestion
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2012-02-23 13:46:19 UTC (rev 13167)
+++ trunk/mapserver/HISTORY.TXT 2012-02-23 13:58:25 UTC (rev 13168)
@@ -15,6 +15,8 @@
Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Java mapscript: renamed shared library and completed libtool support (#2595)
- Fixed WCS 2.0 axis order (#4191)
- Added MS_CJC_* constants in PHP/MapScript (#4183)
Modified: trunk/mapserver/mapscript/java/README
--- trunk/mapserver/mapscript/java/README 2012-02-23 13:46:19 UTC (rev 13167)
+++ trunk/mapserver/mapscript/java/README 2012-02-23 13:58:25 UTC (rev 13168)
@@ -40,11 +40,8 @@
$ make
$ make test (recommended)
$ make threadtests (optional)
- $ make install (recommended)
+ $ make install (required as of 6.1)
-Copy .libs/libmapscript.so and mapscript.jar to the appropriate location or
-use let make install install them in the configured location (defaults to
-/urs/local/lib).
Remember to set the appropriate variable (LD_LIBRARY_PATH, java.library.path
or edit /etc/ld.so.conf) to make sure Java can locate and load the libraries.
More information about the mapserver-commits
