[mapserver-commits] r13171 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Feb 23 14:25:10 EST 2012
Author: sdlime
Date: 2012-02-23 11:25:10 -0800 (Thu, 23 Feb 2012)
New Revision: 13171
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapservutil.c
Added classgroup parameter support to the CGI (in msCGILoadMap()). (#4207)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2012-02-23 19:19:17 UTC (rev 13170)
+++ trunk/mapserver/HISTORY.TXT 2012-02-23 19:25:10 UTC (rev 13171)
@@ -15,6 +15,8 @@
Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Added classgroup CGI parameter support (#4207)
- Java mapscript: renamed shared library and completed libtool support (#2595)
- Fixed WCS 2.0 axis order (#4191)
Modified: trunk/mapserver/mapservutil.c
--- trunk/mapserver/mapservutil.c 2012-02-23 19:19:17 UTC (rev 13170)
+++ trunk/mapserver/mapservutil.c 2012-02-23 19:25:10 UTC (rev 13171)
@@ -166,15 +166,27 @@
} while (0)
+static void setClassGroup(layerObj *layer, char *classgroup) {
+ int i;
+ if(!layer || !classgroup) return;
+ for(i=0; i<layer->numclasses; i++) {
+ if(layer->class[i]->group && strcmp(layer->class[i]->group, classgroup) == 0) {
+ msFree(layer->classgroup);
+ layer->classgroup = msStrdup(classgroup);
+ return; /* bail */
** Extract Map File name from params and load it.
** Returns map object or NULL on error.
mapObj *msCGILoadMap(mapservObj *mapserv)
- int i;
+ int i, j;
mapObj *map = NULL;
static mapObj *preloadedmap = NULL;
static time_t preloadedmap_mtime;
@@ -233,8 +245,6 @@
if(!map) return NULL;
if(!msLookupHashTable(&(map->web.validation), "immutable")) {
/* check for any %variable% substitutions here, also do any map_ changes, we do this here so WMS/WFS */
/* services can take advantage of these "vendor specific" extensions */
@@ -247,13 +257,21 @@
if(strncasecmp(mapserv->request->ParamNames[i],"qstring",7) == 0) continue;
- if(strncasecmp(mapserv->request->ParamNames[i],"map_",4) == 0 || strncasecmp(mapserv->request->ParamNames[i],"map.",4) == 0) { /* check to see if there are any additions to the mapfile */
+ /* check to see if there are any additions to the mapfile */
+ if(strncasecmp(mapserv->request->ParamNames[i],"map_",4) == 0 || strncasecmp(mapserv->request->ParamNames[i],"map.",4) == 0) {
if(msUpdateMapFromURL(map, mapserv->request->ParamNames[i], mapserv->request->ParamValues[i]) != MS_SUCCESS) {
msFreeMap(map);
return NULL;
continue;
+ if(strncasecmp(mapserv->request->ParamNames[i],"classgroup",10) == 0) { /* #4207 */
+ for(j=0; j<map->numlayers; j++) {
+ setClassGroup(GET_LAYER(map, j), mapserv->request->ParamValues[i]);
+ continue;
msApplySubstitutions(map, mapserv->request->ParamNames, mapserv->request->ParamValues, mapserv->request->NumParams);
More information about the mapserver-commits
