[mapserver-commits] r12975 - in trunk/mapserver/mapcache: apache
lib util
svn at osgeo.org
svn at osgeo.org
Thu Jan 5 08:35:37 EST 2012
Author: tbonfort
Date: 2012-01-05 05:35:37 -0800 (Thu, 05 Jan 2012)
New Revision: 12975
trunk/mapserver/mapcache/apache/mod_mapcache.c
trunk/mapserver/mapcache/lib/dimension.c
trunk/mapserver/mapcache/lib/image.c
trunk/mapserver/mapcache/lib/service_wms.c
trunk/mapserver/mapcache/util/mapcache_seed.c
fix compilation warnings
Modified: trunk/mapserver/mapcache/apache/mod_mapcache.c
--- trunk/mapserver/mapcache/apache/mod_mapcache.c 2012-01-05 13:20:56 UTC (rev 12974)
+++ trunk/mapserver/mapcache/apache/mod_mapcache.c 2012-01-05 13:35:37 UTC (rev 12975)
@@ -301,8 +301,8 @@
return write_http_response(apache_ctx,http_response);
static int mod_mapcache_post_config(apr_pool_t *p, apr_pool_t *plog, apr_pool_t *ptemp, server_rec *s) {
- apr_status_t rc;
mapcache_server_cfg* cfg = ap_get_module_config(s->module_config, &mapcache_module);
server_rec *sconf;
Modified: trunk/mapserver/mapcache/lib/dimension.c
--- trunk/mapserver/mapcache/lib/dimension.c 2012-01-05 13:20:56 UTC (rev 12974)
+++ trunk/mapserver/mapcache/lib/dimension.c 2012-01-05 13:35:37 UTC (rev 12975)
@@ -145,8 +145,7 @@
static void _mapcache_dimension_regex_parse_xml(mapcache_context *ctx, mapcache_dimension *dim,
ezxml_t node) {
- mapcache_dimension_regex *dimension;
- int rc;
+ mapcache_dimension_regex *dimension;
const char *entry = node->txt;
if(!entry || !*entry) {
ctx->set_error(ctx,400,"failed to parse dimension regex: none supplied");
Modified: trunk/mapserver/mapcache/lib/image.c
--- trunk/mapserver/mapcache/lib/image.c 2012-01-05 13:20:56 UTC (rev 12974)
+++ trunk/mapserver/mapcache/lib/image.c 2012-01-05 13:35:37 UTC (rev 12975)
@@ -58,8 +58,10 @@
void mapcache_image_merge(mapcache_context *ctx, mapcache_image *base, mapcache_image *overlay) {
int starti,startj;
+#ifndef USE_PIXMAN
int i,j;
unsigned char *browptr, *orowptr, *bptr, *optr;
+#endif
if(base->w < overlay->w || base->h < overlay->h) {
ctx->set_error(ctx, 500, "attempting to merge an larger image onto another");
Modified: trunk/mapserver/mapcache/lib/service_wms.c
--- trunk/mapserver/mapcache/lib/service_wms.c 2012-01-05 13:20:56 UTC (rev 12974)
+++ trunk/mapserver/mapcache/lib/service_wms.c 2012-01-05 13:35:37 UTC (rev 12975)
@@ -501,7 +501,7 @@
if(config->mode != MAPCACHE_MODE_NORMAL) {
main_tileset = mapcache_tileset_clone(ctx,main_tileset);
- main_tileset->name = key;
+ main_tileset->name = (char*)key;
for(i=0;i<main_tileset->grid_links->nelts;i++){
@@ -578,7 +578,7 @@
tileset = mapcache_tileset_clone(ctx,tileset);
- tileset->name = key;
+ tileset->name = (char*)key;
grid_link = NULL;
for(i=0;i<tileset->grid_links->nelts;i++){
Modified: trunk/mapserver/mapcache/util/mapcache_seed.c
--- trunk/mapserver/mapcache/util/mapcache_seed.c 2012-01-05 13:20:56 UTC (rev 12974)
+++ trunk/mapserver/mapcache/util/mapcache_seed.c 2012-01-05 13:35:37 UTC (rev 12975)
@@ -334,7 +334,6 @@
void cmd_recurse(mapcache_context *cmd_ctx, mapcache_tile *tile) {
cmd action;
- int i,j;
int curx, cury, curz;
int minchildx,maxchildx,minchildy,maxchildy;
double bboxbl[4],bboxtr[4];
More information about the mapserver-commits
