[mapserver-commits] r13021 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Jan 31 12:49:09 EST 2012
Author: assefa
Date: 2012-01-31 09:49:09 -0800 (Tue, 31 Jan 2012)
New Revision: 13021
trunk/mapserver/mapogcsld.c
Correct problem with sld using multiple rules (#3929)
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c 2012-01-28 12:29:44 UTC (rev 13020)
+++ trunk/mapserver/mapogcsld.c 2012-01-31 17:49:09 UTC (rev 13021)
@@ -887,6 +887,10 @@
if (psNode)
+ char *pszExpression = NULL;
+ char *pszEscapedExpression = NULL;
+ int i;
/*preparse the filter for possible gml aliases set on the layer's metada:
"gml_NA3DESC_alias" "alias_name" and filter could be
<ogc:PropertyName>alias_name</ogc:PropertyName> #3079*/
@@ -920,40 +924,28 @@
FLTPreParseFilterForAlias(psNode, psLayer->map, j, "G");
-/* If the filter has a spatial filter or is a simple, we keep */
-/* the node. This node will be parsed when applying the SLD and */
-/* be used to do queries on the layer. Simple filers */
-/* (Comparision operators (PropertyIsEqualTo, */
-/* PropertyNotEqualTo, ... combined or not with logical */
-/* operators such as AND/OR/NOT) will be used to set the FILTER */
-/* element of the layer. */
- psLayer->layerinfo = (void *)psNode;
- szExpression = FLTGetCommonExpression(psNode, psLayer);
- if (FLTHasSpatialFilter(psNode))
- else
+ pszExpression = FLTGetCommonExpression(psNode, psLayer);
FLTFreeFilterEncodingNode(psNode);
- psNode = NULL;
+ psNode = NULL;
- if (szExpression)
+ if (pszExpression)
+ pszEscapedExpression = msStringEscape(pszExpression);
nNewClasses =
nClassAfterFilter - nClassBeforeFilter;
for (i=0; i<nNewClasses; i++)
msLoadExpressionString(&psLayer->
class[psLayer->numclasses-1-i]->
- expression, szExpression);
+ expression, pszEscapedExpression);
- msFree(szExpression);
- szExpression = NULL;
+ msFree(pszExpression);
+ pszExpression = NULL;
+ msFree(pszEscapedExpression);
+ pszEscapedExpression = NULL;
nClassAfterRule = psLayer->numclasses;
More information about the mapserver-commits
