[mapserver-commits] r13199 - trunk/docs/en/mapfile
Sun Mar 4 15:30:24 EST 2012
Author: havatv
Date: 2012-03-04 12:30:24 -0800 (Sun, 04 Mar 2012)
New Revision: 13199
   trunk/docs/en/mapfile/outputformat.txt
Added documentation of geospatial PDF to outputformat (#4218).  Also adjusted som overlong lines.
Modified: trunk/docs/en/mapfile/outputformat.txt
--- trunk/docs/en/mapfile/outputformat.txt	2012-03-03 11:45:58 UTC (rev 13198)
+++ trunk/docs/en/mapfile/outputformat.txt	2012-03-04 20:30:24 UTC (rev 13199)
@@ -131,6 +131,117 @@
       jpeg produced (value from 0-100).
     .. index::
+       triple: OUTPUTFORMAT; FORMATOPTION; GAMMA
+    - AGG/\*: "GAMMA=n" is used to specify the gamma correction to
+      apply to polygon rendering. Allowed values are ]0.0,1.0] ,
+      default is 0.75. This value is used to prevent artifacts from
+      appearing on the border of contiguous polygons. Set to 1.0 to
+      disable gamma correction.
+    .. index::
+       triple: OUTPUTFORMAT; FORMATOPTION; COMPRESSION
+    - AGG/PNG: "COMPRESSION=n" is used to determine the ZLIB
+      compression applied to the png creation. n is expected to be an
+      integer value from 0 to 9, with 0 meaning *no* compression (not
+      recommended), 1 meaning fastest compression, and 9 meaning best
+      compression. The compression levels come at a cost (be it in
+      terms of cpu processing or file size, chose the setting that
+      suits you most). The default is COMPRESSION=6.
+    - AGG/PNG supports quantizing from 24/32 bits to 8bits, in order
+      to reduce the final image size (and therefore save bandwidth)
+      (see also http://trac.osgeo.org/mapserver/ticket/2436#comment:4
+      for strategies when applying these options):
+      .. index::
+         triple: OUTPUTFORMAT; FORMATOPTION; QUANTIZE_FORCE
+      - "QUANTIZE_FORCE=on" used to reduce an RGB or RGBA image into
+        an 8bit (or less) paletted images. The colors used in the
+        palette are selected to best fit the actual colors in the RGB
+        or RGBA image.
+      .. index::
+         triple: OUTPUTFORMAT; FORMATOPTION; QUANTIZE_COLORS
+      - "QUANTIZE_COLORS=256" used to specify the number of colors to
+        be used when applying quantization. Maximum value is
+        256. Specifying anything between 17 and 255 is probably a
+        waste of quality as each pixel is still encoded with a full
+        byte. Specifying a value under 16 will produce tiny images,
+        but severly degraded.
+      .. index::
+         triple: OUTPUTFORMAT; FORMATOPTION; PALETTE
+      - "PALETTE=/path/to/palette.txt" is used to define the absolute
+        path where palette colors can be found. This file must contain
+        256 entries of r,g,b triplets for RGB imagemodes, or r,g,b,a
+        quadruplets for RGBA imagemodes. The expected format is one
+        triplet (or quadruplet) per line, each value separated by
+        commas, and each triplet/quadruplet on a single line. If you
+        want to use transparency with a palette, it is important to
+        have these two colors in the palette file: 0,0,0,0 and
+        255,255,255,255.
+        .. NOTE::
+	   0,0,0,0 is important if you have fully transparent areas.
+	   255,255,255,255 is opaque white.
+           The important colors to have in your palette really depend
+	   on your actual map, although 0,0,0,0 , 0,0,0,255 , and
+	   255,255,255,255 are very likely to show up most of the
+	   time.
+      .. index::
+         triple: OUTPUTFORMAT; FORMATOPTION; PALETTE_FORCE
+      - "PALETTE_FORCE=on" is used to reduce image depth with a
+        predefined palette.  This option is incompatible with the
+        previous quantization options.
+    .. index::
+       pair: PDF; Geospatial
+    - CAIRO/PDF:
+      .. index::
+         triple: OUTPUTFORMAT; FORMATOPTION; GEO_ENCODING
+      - "GEO_ENCODING=ISO32000" or "GEO_ENCODING=OGC_BP": Geospatial
+        PDF will be generated.  Requires GDAL 2.0 with PDF driver.
+        See the `GDAL Geospatial PDF`_ documentation for requirements.
+        .. versionadded:: 6.2
+      .. index::
+         triple: OUTPUTFORMAT; FORMATOPTION; METADATA_ITEM
+      - "METADATA_ITEM:option=value": Additional PDF options can be
+        provided using the METADATA_ITEM prefix.  The following
+        options are available: `AUTHOR`, `CREATOR`, `CREATION_DATE`,
+        `KEYWORDS`, `PRODUCER`, `SUBJECT`, `TITLE`.
+      Example:
+      .. code-block:: mapfile
+        OUTPUTFORMAT
+          NAME pdf
+          DRIVER "CAIRO/PDF"
+          MIMETYPE "application/x-pdf"
+          IMAGEMODE RGB
+          EXTENSION "pdf"
+          FORMATOPTION "GEO_ENCODING=ISO32000"
+          FORMATOPTION "METADATA_ITEM:CREATOR=MapServer, with GDAL trunk"
+          FORMATOPTION "METADATA_ITEM:PRODUCER=MapServer, with GDAL trunk"
+        END
+    .. index::
        triple: OUTPUTFORMAT; FORMATOPTION; INTERLACE
     - GD/PNG: The "INTERLACE=[ON/OFF]" option may be used to turn
@@ -154,87 +265,26 @@
     .. index::
-    - GDAL/GTiff: Supports the TILED=YES, BLOCKXSIZE=n, BLOCKYSIZE=n,
-      INTERLEAVE=[PIXEL/BAND] and COMPRESS=[NONE,PACKBITS,JPEG,LZW,DEFLATE]
-      format specific options.
+    - GDAL/GTiff: Supports the "TILED=YES", "BLOCKXSIZE=n",
+      "BLOCKYSIZE=n", "INTERLEAVE=[PIXEL/BAND]" and
+      "COMPRESS=[NONE,PACKBITS,JPEG,LZW,DEFLATE]" format specific
+      options.
     - GDAL/\*: All FORMATOPTIONs are passed onto the GDAL create function.
       Options supported by GDAL are described in the detailed documentation
-      for each GDAL format
+      for each GDAL format.
     .. index::
        triple: OUTPUTFORMAT; FORMATOPTION; NULLVALUE
-    - GDAL/\*: NULLVALUE=n is used in raw image modes (IMAGEMODE
+    - GDAL/\*: "NULLVALUE=n" is used in raw image modes (IMAGEMODE
       BYTE/INT16/FLOAT) to pre-initialize the raster and an attempt is made
       to record this in the resulting file as the nodata value. This is
       automatically set in WCS mode if rangeset_nullvalue is set.
-    - OGR/\*: See OGR Output document for details of OGR format options.
+    - OGR/\*: See the :ref:`ogr_output` document for details of OGR
+      format options.
-    .. index::
-       triple: OUTPUTFORMAT; FORMATOPTION; GAMMA
-    - AGG/\*: GAMMA=n is used to specify the gamma correction to apply to polygon
-      rendering. Allowed values are ]0.0,1.0] , default is 0.75. This value is
-      used to prevent artifacts from appearing on the border of contiguous
-      polygons. Set to 1.0 to disable gamma correction.
-    .. index::
-       triple: OUTPUTFORMAT; FORMATOPTION; COMPRESSION
-    - AGG/PNG: COMPRESSION=n is used to determine the ZLIB compression applied to
-      the png creation. n is expected to be an integer value from 0 to 9, with 0
-      meaning *no* compression (not recommended), 1 meaning fastest compression,
-      and 9 meaning best compression. The compression levels come at a cost (be it
-      in terms of cpu processing or file size, chose the setting that suits you
-      most). The default is COMPRESSION=6.
-    - AGG/PNG supports quantizing from 24/32 bits to 8bits,
-      in order to reduce the final image size (and therefore save bandwidth) (see
-      also http://trac.osgeo.org/mapserver/ticket/2436#comment:4 for strategies
-      when applying these options):
-      .. index::
-         triple: OUTPUTFORMAT; FORMATOPTION; QUANTIZE_FORCE
-      - "QUANTIZE_FORCE=on" used to reduce an RGB or RGBA image into an 8bit
-          (or less) paletted images. The colors used in the palette are selected
-          to best fit the actual colors in the RGB or RGBA image.
-      .. index::
-         triple: OUTPUTFORMAT; FORMATOPTION; QUANTIZE_COLORS
-      - "QUANTIZE_COLORS=256" used to specify the number of colors to be used
-        when applying quantization. Maximum value is 256. Specifying anything
-        between 17 and 255 is probably a waste of quality as each pixel is still
-        encoded with a full byte. Specifying a value under 16 will produce tiny
-        images, but severly degraded.
-      .. index::
-         triple: OUTPUTFORMAT; FORMATOPTION; PALETTE
-      - "PALETTE=/path/to/palette.txt" is used to define the absolute path where
-        palette colors can be found. This file must contain 256 entries of r,g,b
-        triplets for RGB imagemodes, or r,g,b,a quadruplets for
-        RGBA imagemodes. The expected format is one triplet (or quadruplet) per
-        line, each value separated by commas, and each triplet/quadruplet on a
-        single line. If you want to use transparency with a palette, it is
-        important to have these two colors in the palette file:
-        0,0,0,0 and 255,255,255,255.
-        .. NOTE::
-	   0,0,0,0 is important if you have fully transparent areas.
-	   255,255,255,255 is opaque white.
-           The important colors to have in your palette really depend on your
-	   actual map, although 0,0,0,0 , 0,0,0,255 , and 255,255,255,255 are
-	   very likely to show up most of the time.
-      .. index::
-         triple: OUTPUTFORMAT; FORMATOPTION; PALETTE_FORCE
-      - "PALETTE_FORCE=on" is used to reduce image depth with a predefined palette.
-        This option is incompatible with the previous quantization options.
 .. index::
    pair: OUTPUTFORMAT; IMAGEMODE
@@ -316,3 +366,5 @@
     components drawn in this color will also be transparent, so for map
     generation with transparency it is best to use an otherwise unused color
     as the background color.
+.. _`GDAL Geospatial PDF`: http://www.gdal.org/frmt_pdf.html
