[mapserver-commits] r13218 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Thu Mar 8 13:29:50 EST 2012
Author: havatv
Date: 2012-03-08 10:29:50 -0800 (Thu, 08 Mar 2012)
New Revision: 13218
branches/branch-6-0/docs/en/mapfile/join.txt
trunk/docs/en/mapfile/join.txt
Updated the join document - csv example (#3843)
Modified: branches/branch-6-0/docs/en/mapfile/join.txt
--- branches/branch-6-0/docs/en/mapfile/join.txt 2012-03-08 17:52:31 UTC (rev 13217)
+++ branches/branch-6-0/docs/en/mapfile/join.txt 2012-03-08 18:29:50 UTC (rev 13218)
@@ -287,7 +287,8 @@
CONNECTIONTYPE CSV
TABLE "../data/lookup.csv"
FROM "ID"
- TO "IDENT"
+ #TO "IDENT" # see note below
+ TO "1" # see note below
TYPE ONE-TO-ONE
END
END # layer
@@ -316,7 +317,7 @@
row. It just uses indexes (1, 2, ... n) to reference the
columns. It's ok to leave column names as the first row since they
likely won't match anything but they aren't used. Typically you'd
- see something like "TO '1'" in the JOIN block. Then in the template
+ see something like TO "1" in the JOIN block. Then in the template
you'd use [name_1], [name_2], etc...
Ogrinfo
@@ -336,16 +337,26 @@
IDENT: String (0.0)
VAL: String (0.0)
-Template
+Template (prov.html)
+Ideally this the template should look like this::
+ <!-- MapServer Template -->
<tr bgcolor="#EFEFEF">
<td align="left">[NAME]</td>
<td align="left">[test_VAL]</td>
</tr>
+But since attribute names are not supported for CSV files (see note
+above), the following will have to be used::
+ <tr bgcolor="#EFEFEF">
+ <td align="left">[NAME]</td>
+ <td align="left">[test_2]</td>
+ </tr>
Example 4: Join from Shape dataset to MySQL
Modified: trunk/docs/en/mapfile/join.txt
--- trunk/docs/en/mapfile/join.txt 2012-03-08 17:52:31 UTC (rev 13217)
+++ trunk/docs/en/mapfile/join.txt 2012-03-08 18:29:50 UTC (rev 13218)
@@ -287,7 +287,8 @@
CONNECTIONTYPE CSV
FROM "ID"
- TO "IDENT"
TYPE ONE-TO-ONE
END
END # layer
@@ -316,7 +317,7 @@
Ogrinfo
IDENT: String (0.0)
VAL: String (0.0)
-Template
</tr>
+ </tr>
More information about the mapserver-commits
