[mapserver-commits] r13228 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Mar 10 08:05:55 EST 2012
Author: tamas
Date: 2012-03-10 05:05:55 -0800 (Sat, 10 Mar 2012)
New Revision: 13228
trunk/mapserver/mapdraw.c
trunk/mapserver/maplabel.c
Fix for the build issues with MSVC compilers
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2012-03-09 17:27:31 UTC (rev 13227)
+++ trunk/mapserver/mapdraw.c 2012-03-10 13:05:55 UTC (rev 13228)
@@ -1559,8 +1559,10 @@
int annotationLayerDrawShape(mapObj *map, imageObj *image, layerObj *layer, shapeObj *shape) {
+ int bClipShape;
int c = shape->classindex;
rectObj cliprect;
+ labelObj *label;
double minfeaturesize;
labelPathObj **annopaths = NULL; /* Curved label path. Bug #1620 implementation */
pointObj **annopoints = NULL;
@@ -1587,7 +1589,7 @@
layer->project = MS_FALSE;
#endif
- int bClipShape = MS_FALSE;
+ bClipShape = MS_FALSE;
/* check if we need to clip the shape */
if(!msLayerGetProcessingKey(layer, "LABEL_NO_CLIP") &&
@@ -1607,7 +1609,7 @@
msComputeBounds(shape);
/* annotation layers can only have one layer, don't treat the multi layer case */
- labelObj *label = layer->class[c]->labels[0]; /* for brevity */
+ label = layer->class[c]->labels[0]; /* for brevity */
minfeaturesize = label->minfeaturesize * image->resolutionfactor;
@@ -2422,12 +2424,12 @@
int msDrawOffsettedLabels(imageObj *image, mapObj *map, int priority) {
- assert(MS_RENDERER_PLUGIN(image->format));
int retval = MS_SUCCESS;
int l;
labelCacheObj *labelcache = &(map->labelcache);
labelCacheSlotObj *cacheslot;
labelCacheMemberObj *cachePtr;
+ assert(MS_RENDERER_PLUGIN(image->format));
cacheslot = &(labelcache->slots[priority]);
for(l=cacheslot->numlabels-1; l>=0; l--) {
cachePtr = &(cacheslot->labels[l]); /* point to right spot in the label cache */
@@ -2436,6 +2438,8 @@
classObj *classPtr = (GET_CLASS(map,cachePtr->layerindex,cachePtr->classindex));
layerObj *layerPtr = (GET_LAYER(map,cachePtr->layerindex));
if(classPtr->leader.maxdistance) { /* only test labels that can be offsetted */
+ shapeObj origPoly;
+ int steps,i;
if(cachePtr->point.x < labelcache->gutter ||
cachePtr->point.y < labelcache->gutter ||
cachePtr->point.x >= image->width - labelcache->gutter ||
@@ -2448,7 +2452,6 @@
/* TODO: if the entry has a single label and it has position != CC,
* recompute the cachePtr->poly and labelPtr->annopoint using POSITION CC */
- shapeObj origPoly;
msInitShape(&origPoly);
msCopyShape(cachePtr->poly,&origPoly);
@@ -2458,8 +2461,7 @@
cachePtr->leaderline->point[0] = cachePtr->point;
cachePtr->leaderbbox = msSmallMalloc(sizeof(rectObj));
- int steps = classPtr->leader.maxdistance / classPtr->leader.gridstep;
- int i;
+ steps = classPtr->leader.maxdistance / classPtr->leader.gridstep;
#define x0 (cachePtr->leaderline->point[0].x)
#define y0 (cachePtr->leaderline->point[0].y)
@@ -2571,11 +2573,11 @@
otest(0,i*gridstepsc);
if(cachePtr->status) {
+ int ll;
shapeObj labelLeader; /* label polygon (bounding box, possibly rotated) */
labelLeader.line = cachePtr->leaderline; /* setup the label polygon structure */
labelLeader.numlines = 1;
- int ll;
for(ll=0;ll<classPtr->leader.numstyles;ll++) {
msDrawLineSymbol(&map->symbolset, image,&labelLeader , classPtr->leader.styles[ll], layerPtr->scalefactor);
@@ -2687,10 +2689,13 @@
if(style->_geomtransform.type == MS_GEOMTRANSFORM_LABELPOINT &&
style->symbol < map->symbolset.numsymbols && style->symbol > 0) {
double sx,sy;
+ pointObj *point;
+ int p;
+ double aox,aoy;
symbolObj *symbol = map->symbolset.symbol[style->symbol];
if(msGetMarkerSize(&map->symbolset, style, &sx, &sy, layerPtr->scalefactor) != MS_SUCCESS)
return MS_FAILURE;
- pointObj *point = markerPoly->line[0].point;
+ point = markerPoly->line[0].point;
point[0].x = sx / 2.0;
point[0].y = sy / 2.0;
point[1].x = point[0].x;
@@ -2701,8 +2706,6 @@
point[3].y = point[0].y;
point[4].x = point[0].x;
point[4].y = point[0].y;
- int p;
- double aox,aoy;
if(symbol->anchorpoint_x != 0.5 || symbol->anchorpoint_y != 0.5) {
aox = (0.5 - symbol->anchorpoint_x) * sx;
aoy = (0.5 - symbol->anchorpoint_y) * sy;
@@ -2743,7 +2746,20 @@
if(MS_RENDERER_PLUGIN(image->format)) {
int i, l, ll, priority;
rectObj r;
+ shapeObj marker_poly;
+ lineObj marker_line;
+ pointObj marker_points[5];
+ shapeObj label_marker_poly;
+ lineObj label_marker_line;
+ pointObj label_marker_points[5];
+ shapeObj metrics_poly;
+ lineObj metrics_line;
+ pointObj metrics_points[5];
+ double marker_offset_x, marker_offset_y;
+ int label_offset_x, label_offset_y;
+ int label_mindistance=-1, label_buffer=0;
+ const char *value;
labelCacheMemberObj *cachePtr=NULL;
layerObj *layerPtr=NULL;
@@ -2751,9 +2767,6 @@
labelObj *labelPtr=NULL;
/* holds the contour of the label styles that correspond to markers */
- shapeObj marker_poly;
- lineObj marker_line;
- pointObj marker_points[5];
marker_line.point = marker_points;
marker_line.numpoints = 5;
msInitShape(&marker_poly);
@@ -2761,9 +2774,6 @@
marker_poly.numlines = 0;
marker_poly.type = MS_SHAPE_POLYGON;
- shapeObj label_marker_poly;
- lineObj label_marker_line;
- pointObj label_marker_points[5];
label_marker_line.point = label_marker_points;
label_marker_line.numpoints = 5;
msInitShape(&label_marker_poly);
@@ -2771,9 +2781,6 @@
label_marker_poly.numlines = 0;
label_marker_poly.type = MS_SHAPE_POLYGON;
- shapeObj metrics_poly;
- lineObj metrics_line;
- pointObj metrics_points[5];
metrics_line.point = metrics_points;
metrics_line.numpoints = 5;
msInitShape(&metrics_poly);
@@ -2781,15 +2788,6 @@
metrics_poly.numlines = 1;
metrics_poly.type = MS_SHAPE_POLYGON;
- double marker_offset_x, marker_offset_y;
- int label_offset_x, label_offset_y;
- int label_mindistance=-1, label_buffer=0;
- const char *value;
/* Look for labelcache_map_edge_buffer map metadata
* If set then the value defines a buffer (in pixels) along the edge of the
* map image where labels can't fall
@@ -2898,9 +2896,9 @@
cachePtr->status = MS_OFF; /* assume this cache element *can't* be placed */
for(ll=0; ll<cachePtr->numlabels; ll++) { /* RFC 77 TODO: Still may want to step through backwards... */
+ int label_marker_status = MS_ON;
labelPtr = &(cachePtr->labels[ll]);
labelPtr->status = MS_OFF;
- int label_marker_status = MS_ON;
/* first check if there's anything to do with this label */
if(!labelPtr->annotext) {
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2012-03-09 17:27:31 UTC (rev 13227)
+++ trunk/mapserver/maplabel.c 2012-03-10 13:05:55 UTC (rev 13228)
@@ -338,10 +338,11 @@
layerObj *maskLayer = GET_LAYER(map,maskLayerIdx);
if(maskLayer->maskimage && MS_IMAGE_RENDERER(maskLayer->maskimage)->supports_pixel_buffer) {
rasterBufferObj rb;
+ int x,y;
memset(&rb,0,sizeof(rasterBufferObj));
MS_IMAGE_RENDERER(maskLayer->maskimage)->getRasterBufferHandle(maskLayer->maskimage,&rb);
- int x = MS_NINT(point->x);
- int y = MS_NINT(point->y);
+ x = MS_NINT(point->x);
+ y = MS_NINT(point->y);
if(rb.type == MS_BUFFER_BYTE_RGBA) {
unsigned char *alphapixptr = rb.data.rgba.a+rb.data.rgba.row_step*y + rb.data.rgba.pixel_step*x;
if(!*alphapixptr) {
More information about the mapserver-commits
