[mapserver-commits] r13262 - trunk/msautotest/renderers
svn at osgeo.org
svn at osgeo.org
Wed Mar 14 12:56:47 EDT 2012
Author: tbonfort
Date: 2012-03-14 09:56:47 -0700 (Wed, 14 Mar 2012)
New Revision: 13262
trunk/msautotest/renderers/labelpnt.map
trunk/msautotest/renderers/marker_anchorpoint.map
trunk/msautotest/renderers/marker_pixmap.map
trunk/msautotest/renderers/mask.map
trunk/msautotest/renderers/point_ellipse.map
trunk/msautotest/renderers/point_pixmap.map
trunk/msautotest/renderers/point_pixmap_gif.map
trunk/msautotest/renderers/point_svg.map
trunk/msautotest/renderers/polygon-as-line.map
trunk/msautotest/renderers/polygon-hatch-dashed.map
trunk/msautotest/renderers/polygon-hatch.map
trunk/msautotest/renderers/polygon-pixmap.map
trunk/msautotest/renderers/polygon-simple.map
trunk/msautotest/renderers/polygon-ttf.map
trunk/msautotest/renderers/polygon-vector.map
trunk/msautotest/renderers/transparent_layer.map
trunk/msautotest/renderers/wmsclient.map
remove debug level
Modified: trunk/msautotest/renderers/labelpnt.map
--- trunk/msautotest/renderers/labelpnt.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/labelpnt.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -23,7 +23,6 @@
end
LAYER
- DEBUG 5
NAME Test
TYPE annotation
STATUS DEFAULT
@@ -65,7 +64,6 @@
LAYER
- DEBUG 5
NAME Test
TYPE point
STATUS DEFAULT
Modified: trunk/msautotest/renderers/marker_anchorpoint.map
--- trunk/msautotest/renderers/marker_anchorpoint.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/marker_anchorpoint.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -15,7 +15,6 @@
shapepath "../misc/data"
CONFIG MS_ERRORFILE "stderr"
-DEBUG ON
SYMBOL
NAME "1"
Modified: trunk/msautotest/renderers/marker_pixmap.map
--- trunk/msautotest/renderers/marker_pixmap.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/marker_pixmap.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -14,7 +14,6 @@
symbolset "symbolset"
-DEBUG ON
LAYER
NAME "symbol"
Modified: trunk/msautotest/renderers/mask.map
--- trunk/msautotest/renderers/mask.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/mask.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -17,7 +17,6 @@
-DEBUG ON
LAYER
NAME "mask"
Modified: trunk/msautotest/renderers/point_ellipse.map
--- trunk/msautotest/renderers/point_ellipse.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/point_ellipse.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -14,7 +14,6 @@
-DEBUG ON
LAYER
NAME "symbol"
Modified: trunk/msautotest/renderers/point_pixmap.map
--- trunk/msautotest/renderers/point_pixmap.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/point_pixmap.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -14,7 +14,6 @@
-DEBUG ON
LAYER
NAME "symbol"
Modified: trunk/msautotest/renderers/point_pixmap_gif.map
--- trunk/msautotest/renderers/point_pixmap_gif.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/point_pixmap_gif.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -14,7 +14,6 @@
imagecolor 255 200 0
-DEBUG ON
LAYER
NAME "symbol"
Modified: trunk/msautotest/renderers/point_svg.map
--- trunk/msautotest/renderers/point_svg.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/point_svg.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -14,7 +14,6 @@
-DEBUG ON
LAYER
NAME "symbol"
Modified: trunk/msautotest/renderers/polygon-as-line.map
--- trunk/msautotest/renderers/polygon-as-line.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/polygon-as-line.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -17,7 +17,6 @@
-DEBUG ON
SYMBOL
name "hatch"
Modified: trunk/msautotest/renderers/polygon-hatch-dashed.map
--- trunk/msautotest/renderers/polygon-hatch-dashed.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/polygon-hatch-dashed.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -17,7 +17,6 @@
-DEBUG ON
SYMBOL
name "hatch"
Modified: trunk/msautotest/renderers/polygon-hatch.map
--- trunk/msautotest/renderers/polygon-hatch.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/polygon-hatch.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -17,7 +17,6 @@
-DEBUG ON
SYMBOL
name "hatch"
Modified: trunk/msautotest/renderers/polygon-pixmap.map
--- trunk/msautotest/renderers/polygon-pixmap.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/polygon-pixmap.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -15,7 +15,6 @@
-DEBUG ON
LAYER
NAME "world"
Modified: trunk/msautotest/renderers/polygon-simple.map
--- trunk/msautotest/renderers/polygon-simple.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/polygon-simple.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -15,7 +15,6 @@
-DEBUG ON
LAYER
NAME "world"
Modified: trunk/msautotest/renderers/polygon-ttf.map
--- trunk/msautotest/renderers/polygon-ttf.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/polygon-ttf.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -15,7 +15,6 @@
-DEBUG ON
LAYER
NAME "world"
Modified: trunk/msautotest/renderers/polygon-vector.map
--- trunk/msautotest/renderers/polygon-vector.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/polygon-vector.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -15,7 +15,6 @@
-DEBUG ON
LAYER
NAME "world"
Modified: trunk/msautotest/renderers/transparent_layer.map
--- trunk/msautotest/renderers/transparent_layer.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/transparent_layer.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -17,7 +17,6 @@
-DEBUG ON
SYMBOL
name "hatch"
Modified: trunk/msautotest/renderers/wmsclient.map
--- trunk/msautotest/renderers/wmsclient.map 2012-03-14 16:50:56 UTC (rev 13261)
+++ trunk/msautotest/renderers/wmsclient.map 2012-03-14 16:56:47 UTC (rev 13262)
@@ -21,7 +21,6 @@
NAME "pop"
TYPE RASTER
STATUS DEFAULT
- DEBUG 1
CONNECTION "http://sedac.ciesin.columbia.edu/mapserver/map/GPWv3?"
CONNECTIONTYPE WMS
METADATA
More information about the mapserver-commits
