[mapserver-commits] r13306 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Mon Mar 26 02:56:27 EDT 2012
Author: havatv
Date: 2012-03-25 23:56:27 -0700 (Sun, 25 Mar 2012)
New Revision: 13306
trunk/docs/en/mapfile/symbol.txt
Added documentation of the SVG symbol type to the symbol document (#3671)
Modified: trunk/docs/en/mapfile/symbol.txt
--- trunk/docs/en/mapfile/symbol.txt 2012-03-25 22:12:36 UTC (rev 13305)
+++ trunk/docs/en/mapfile/symbol.txt 2012-03-26 06:56:27 UTC (rev 13306)
@@ -50,9 +50,9 @@
specifies the center of the symbol (in the y direction).
`ANCHORPOINT` can be used with `SYMBOL`\s of `TYPE` `ellipse`,
- `pixmap`, `truetype` and `vector`. To ensure proper behaviour for
- vector symbols, the left and top edges of the bounding box of the
- symbol should be at 0.
+ `pixmap`, `svg`, `truetype` and `vector`. To ensure proper
+ behaviour for vector symbols, the left and top edges of the
+ bounding box of the symbol should be at 0.
.. versionadded:: 6.2
@@ -200,17 +200,22 @@
triple: SYMBOL; TYPE; simple
.. index::
+ triple: SYMBOL; TYPE; svg
+.. index::
triple: SYMBOL; TYPE; truetype
.. index::
triple: SYMBOL; TYPE; vector
-TYPE [ellipse|hatch|pixmap|simple|truetype|vector]
+TYPE [ellipse|hatch|pixmap|simple|svg|truetype|vector]
- `ellipse`: radius values in the x and y directions define an ellipse.
- `hatch`: produces hatched lines throughout the (polygon) shape.
- `pixmap`: a user supplied image will be used as the symbol.
- `simple`: default symbol type (1 pixel point, 1 pixel line, solid
fill).
+ - `svg`: scalable vector graphics (SVG) symbol. Requires the
+ libsvg-cairo library.
- `truetype`: TrueType font to use as defined in the :ref:`MAP`
:ref:`FONTSET`\.
- `vector`: a vector drawing is used to define the shape of the symbol.
More information about the mapserver-commits
