[mapserver-commits] [mapserver/mapserver] 025ffe: MapScript colorObj SWIG/PHP alignment and methods ...
GitHub
noreply at github.com
Mon Jul 20 07:05:43 PDT 2015
Branch: refs/heads/branch-7-0
Home: https://github.com/mapserver/mapserver
Commit: 025ffe147a977041e5d5c6960c3a48645bbb24e3
https://github.com/mapserver/mapserver/commit/025ffe147a977041e5d5c6960c3a48645bbb24e3
Author: ejn <edward.nash at gmx.de>
Date: 2015-07-20 (Mon, 20 Jul 2015)
Changed paths:
M mapscript/php/color.c
M mapscript/swiginc/color.i
Log Message:
MapScript colorObj SWIG/PHP alignment and methods with alpha
Changes in the SWIG bindings:
- add the methods setRGBA() and toHexWithAlpha()
- extend the method setHex() to accept #rrggbbaa hex values
Changes in the PHP bindings:
- adds the methods toHex() and setHex() which were already in the SWIG bindings
Commit: d7c26bcd686bf251a046e3ef4f61b8f623eca663
https://github.com/mapserver/mapserver/commit/d7c26bcd686bf251a046e3ef4f61b8f623eca663
Changed paths:
Log Message:
Refactor changes in Mapscript colorObj to optional arguments
Instead of introducing separate setRGBA and toHexWithAlpha we alter the
existing method setRGB to take an optional fourth argument and toHex such
that it outputs a 4-byte hex string if the alpha value is other than 255
and a 3-byte hex string as previously if the alpha is the default 255.
Commit: 8fdcb3921c9c6bc87461f93bbe582651877814f0
https://github.com/mapserver/mapserver/commit/8fdcb3921c9c6bc87461f93bbe582651877814f0
Author: Thomas Bonfort <thomas.bonfort at gmail.com>
Changed paths:
Log Message:
Merge pull request #5078 from faegi/mapscriptColorAlpha70
MapScript colorObj SWIG/PHP alignment and methods with alpha (#5078)
Compare: https://github.com/mapserver/mapserver/compare/a504deb37be7...8fdcb3921c9c
More information about the mapserver-commits
