[mapserver-commits] [mapserver/mapserver] 5ef69c: Fix travis builds, remove 5.6 until build fix is w...
GitHub
noreply at github.com
Mon Aug 29 11:45:04 PDT 2016
Branch: refs/heads/master
Home: https://github.com/mapserver/mapserver
Commit: 5ef69c9da6f96a37f367210310914dfb3199ac36
https://github.com/mapserver/mapserver/commit/5ef69c9da6f96a37f367210310914dfb3199ac36
Author: Thomas Bonfort <thomas.bonfort at gmail.com>
Date: 2016-08-29 (Mon, 29 Aug 2016)
Changed paths:
M .travis.yml
Log Message:
Fix travis builds, remove 5.6 until build fix is worked on
Commit: 2a6ad64361b22f01e338d8379f010640a63a153a
https://github.com/mapserver/mapserver/commit/2a6ad64361b22f01e338d8379f010640a63a153a
Author: Even Rouault <even.rouault at spatialys.com>
Changed paths:
M mapogr.cpp
Log Message:
[OGR] Move all logic to detect if we can use Spatialite dialect to msOGRFileOpen(). No functional change
Commit: 8ae17b3fd59b822f23b9276f7d53e418b8caf63b
https://github.com/mapserver/mapserver/commit/8ae17b3fd59b822f23b9276f7d53e418b8caf63b
Changed paths:
M mapogr.cpp
A msautotest/wxs/expected/wfs_ogr_native_sql_37.xml
M msautotest/wxs/wfs_ogr_native_sql.map
Log Message:
[OGR] Enable translation for maxfeatures/startindex to SQL LIMIT/OFFSET in Spatialite case
Commit: 892deaf5a84e9a619ffc1f6ca2d6ec37dceaab7b
https://github.com/mapserver/mapserver/commit/892deaf5a84e9a619ffc1f6ca2d6ec37dceaab7b
Changed paths:
M mapogr.cpp
Log Message:
[OGR] Fix build when USE_OGR is not defined
Commit: e6b66a66e74351e39ddc7d0628df5340aa1ab7b1
https://github.com/mapserver/mapserver/commit/e6b66a66e74351e39ddc7d0628df5340aa1ab7b1
Changed paths:
M mapogr.cpp
Log Message:
[OGR] Fix msOGRGetPaging()
Commit: 3af35fff8939303fe17102b93b13de9ce7e178de
https://github.com/mapserver/mapserver/commit/3af35fff8939303fe17102b93b13de9ce7e178de
Changed paths:
M .travis.yml
M mapogr.cpp
Log Message:
Merge branch 'branch-7-0'
Compare: https://github.com/mapserver/mapserver/compare/2374bb019e83...3af35fff8939
More information about the mapserver-commits
