[mapserver-commits] [mapserver/mapserver] 38f3ca: Fix kerneldensity layer not to loose connection ty...
GitHub noreply at github.com
Fri Nov 3 07:31:07 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: 38f3cae73d6ad55a3d16786441a065275f3335b4
      https://github.com/mapserver/mapserver/commit/38f3cae73d6ad55a3d16786441a065275f3335b4
  Author: Tamas Szekeres <szekerest at gmail.com>
  Date:   2017-10-23 (Mon, 23 Oct 2017)
  Changed paths:
    M maplayer.c
    M maprasterquery.c
  Log Message:
  Fix kerneldensity layer not to loose connection type on reopen (#5497)
  Commit: e79be807883ea765a8b252492956c0cd4dc7695d
      https://github.com/mapserver/mapserver/commit/e79be807883ea765a8b252492956c0cd4dc7695d
  Changed paths:
    M maplayer.c
    M maprasterquery.c
  Log Message:
  Merge pull request #5498 from szekerest/kerneldensfix
  Commit: 91fafe426c00c348c068be7deb35cd45d1fe262d
      https://github.com/mapserver/mapserver/commit/91fafe426c00c348c068be7deb35cd45d1fe262d
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2017-10-31 (Tue, 31 Oct 2017)
  Changed paths:
    M mapogcsld.c
  Log Message:
  msSLDApplySLD(): fix wrong index use (patch by wdc-rsat, fixes #5505)
  Commit: 4f7520631f03d1347dadf529db6da55c2ea57186
      https://github.com/mapserver/mapserver/commit/4f7520631f03d1347dadf529db6da55c2ea57186
  Changed paths:
    M mapwcs11.c
  Log Message:
  WCS 1.1 GetCoverage response: honour EPSG axis order for GridOrigin and GridOffsets (#5504)
F.3.4 2D simple grid (urn:ogc:def:method:WCS:1.1:2dSimpleGrid) of
https://portal.opengeospatial.org/files/07-067r2 makes it clear that EPSG axis
order should be followed, in the note of EXAMPLE 1 at page 88
'''(in this case, degrees of latitude and longitude, in that order).'''
  Commit: c7a1e517d5dd2dd80901008e9860cd589f1685a1
      https://github.com/mapserver/mapserver/commit/c7a1e517d5dd2dd80901008e9860cd589f1685a1
  Changed paths:
    M mapogcsos.c
  Log Message:
  msSOSGetCapabilities(): use proper layer when generating the gml:name from sos_offering_name metadata (patch by wdc-rsat, fixes #5506)
  Commit: f9f59dc3384c74a1ca607af9a2fa84a95d9b5e9e
      https://github.com/mapserver/mapserver/commit/f9f59dc3384c74a1ca607af9a2fa84a95d9b5e9e
  Date:   2017-11-01 (Wed, 01 Nov 2017)
  Changed paths:
    M mapwcs11.c
  Log Message:
  Correcting commit message of 4f7520631f03d1347dadf529db6da55c2ea57186: 'WCS 1.1 DescribeCoverage response: honour EPSG axis order for GridOrigin and GridOffsets (#5504)'
  Commit: 8f85f8db46e65a3a4e8d3ec245ea90a56b6d794c
      https://github.com/mapserver/mapserver/commit/8f85f8db46e65a3a4e8d3ec245ea90a56b6d794c
  Date:   2017-11-02 (Thu, 02 Nov 2017)
  Changed paths:
    M mapproject.c
    M mapproject.h
    M mapresample.c
    M mapuvraster.c
    A msautotest/wxs/data/uvraster_lonwrap180.tif
    A msautotest/wxs/expected/wms_uvraster_lonwrap180_accross_hemisphere.png
    A msautotest/wxs/expected/wms_uvraster_lonwrap180_east_hemisphere.png
    A msautotest/wxs/expected/wms_uvraster_lonwrap180_west_hemisphere.png
    A msautotest/wxs/expected/wms_uvraster_lonwrap180_whole_world.png
    A msautotest/wxs/wms_uvraster_lonwrap180.map
  Log Message:
  UVRaster: support layers with lon_wrap=180 projection (#5502)
  Commit: 1ee7e0e87125fb1f94ec382a8bd71d2c09c56ea4
      https://github.com/mapserver/mapserver/commit/1ee7e0e87125fb1f94ec382a8bd71d2c09c56ea4
  Date:   2017-11-03 (Fri, 03 Nov 2017)
  Changed paths:
    M mapproject.c
  Log Message:
  Fix regression introduced by latest commit 8f85f8db46e65a3a4e8d3ec245ea90a56b6d794c (#5502)
  Commit: 2a990dc46f13ed8b965f0d83cde7df7da17b831f
      https://github.com/mapserver/mapserver/commit/2a990dc46f13ed8b965f0d83cde7df7da17b831f
  Changed paths:
    M mapdraw.c
    M mapproject.c
    M mapuvraster.c
    A msautotest/wxs/data/wms_uvraster_map_reprojection.tif
    A msautotest/wxs/expected/wms_uvraster_map_reprojection_extent_intersecting_layer.png
    A msautotest/wxs/expected/wms_uvraster_map_reprojection_extent_larger_than_layer.png
    A msautotest/wxs/expected/wms_uvraster_map_reprojection_extent_smaller_than_layer.png
    A msautotest/wxs/wms_uvraster_map_reprojection.map
  Log Message:
  UVRaster: fix reprojection issue of map extent to layer projection (fixes #5501)
  Commit: c08cc8b415afaf1c5cd6b2c118cc7730d5e4b2aa
      https://github.com/mapserver/mapserver/commit/c08cc8b415afaf1c5cd6b2c118cc7730d5e4b2aa
  Changed paths:
    M mapdraw.c
    M maplayer.c
    M mapogcsld.c
    M mapogcsos.c
    M mapproject.c
    M mapproject.h
    M maprasterquery.c
    M mapresample.c
    M mapuvraster.c
    M mapwcs11.c
  Log Message:
  Merge branch 'branch-7-0'
Compare: https://github.com/mapserver/mapserver/compare/693e7d7f03f7...c08cc8b415af
