[mapserver-commits] [mapserver/mapserver] 572bd7: Added the option to set a default value for variab...
GitHub
noreply at github.com
Mon Nov 13 13:04:47 PST 2017
Branch: refs/heads/branch-7-0
Home: https://github.com/mapserver/mapserver
Commit: 572bd765e7a0f55b8826a9bdbd2b661e07ff44b9
https://github.com/mapserver/mapserver/commit/572bd765e7a0f55b8826a9bdbd2b661e07ff44b9
Author: Martin.Icking <martin.icking at bentley.com>
Date: 2017-11-10 (Fri, 10 Nov 2017)
Changed paths:
M mapfile.c
Log Message:
Added the option to set a default value for variable substitution in the map's WEB section. To do that there is a new method applyHashTableDefaultSubstitutions that is being called in msApplyDefaultSubstitutions with the map's WEB section as the hash table to work on
Commit: 41100a91af55f2a11e516ee8d8dc49b8a194ade5
https://github.com/mapserver/mapserver/commit/41100a91af55f2a11e516ee8d8dc49b8a194ade5
Author: Jeff McKenna <jeffmckenna at gmail.com>
Date: 2017-11-13 (Mon, 13 Nov 2017)
Changed paths:
M mapfile.c
Log Message:
Merge pull request #5516 from BentleySystems/fix-allow-web-substitution-defaults
enable default value for variable substitution in map's WEB section
Compare: https://github.com/mapserver/mapserver/compare/fd04328a89e7...41100a91af55
More information about the mapserver-commits
