[mapserver-commits] [mapserver/mapserver] 249328: WCS 2.0: special processing for wcs_rangeset_axes=...
GitHub
noreply at github.com
Thu Nov 30 08:35:03 PST 2017
Branch: refs/heads/branch-7-0
Home: https://github.com/mapserver/mapserver
Commit: 2493287b0e35f54c671d6dae33ebabfc7869bb60
https://github.com/mapserver/mapserver/commit/2493287b0e35f54c671d6dae33ebabfc7869bb60
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2017-11-21 (Tue, 21 Nov 2017)
Changed paths:
M mapwcs20.c
M msautotest/wxs/expected/wcs_10_getcov_bands_name_new.dat
M msautotest/wxs/expected/wcs_20_desc.txt
M msautotest/wxs/expected/wcs_20_desc.xml
M msautotest/wxs/expected/wcs_20_getcov_full.dat
M msautotest/wxs/expected/wcs_20_getcov_grd_mp.dat
M msautotest/wxs/expected/wcs_20_getcov_reproj.dat
M msautotest/wxs/expected/wcs_20_post_desc.xml
M msautotest/wxs/expected/wcs_20_post_getcov_full_multipart.dat
M msautotest/wxs/expected/wcs_mask_20_getcov_full.dat
M msautotest/wxs/expected/wcs_mask_20_getcov_grd_mp.dat
M msautotest/wxs/expected/wcs_mask_20_getcov_reproj.dat
M msautotest/wxs/wcs_multi.map
Log Message:
WCS 2.0: special processing for wcs_rangeset_axes=bands
WCS 2.0 has a special compatibility mode where it can use WCS 1.1 metadata
items. Unfortunately, it does a wrong assumption on how wcs_rangeset_axes works
in WCS 1.0/1.1. The implementation of it is probably not completely right in
WCS 1.0/1.1, but at least a special case that works is when 'bands' is assigned
to wcs_rangeset_axes. So make WCS 2.0 code handle wcs_rangeset_axes=bands
as the special case handled by msWCSSetDefaultBandsRangeSetInfo()
in https://github.com/mapserver/mapserver/blob/branch-7-0/mapwcs.c#L281
Modify wcs_multi.map to use wcs_rangeset_axes=bands. This will also make the
wcs_10_getcov_bands_name_new request to properly return 3 bands. So band
subsetting works in both in WCS 1.0 and 2.0 with the same mapfile.
The "New band related metadata entries" paragraph of
http://mapserver.org/ogc/wcs_server.html
should probably be revised to remove reference to the WCS 1.1 compatibility
mode.
Commit: 6a09273f4da7486b7f05846c3acb0630f54664dd
https://github.com/mapserver/mapserver/commit/6a09273f4da7486b7f05846c3acb0630f54664dd
Date: 2017-11-30 (Thu, 30 Nov 2017)
Changed paths:
M mapwcs20.c
M msautotest/wxs/expected/wcs_20_desc_bands.xml
M msautotest/wxs/expected/wcs_20_getcov_bands_name_new.dat
M msautotest/wxs/expected/wcs_20_getcov_bands_name_new_reproject.dat
M msautotest/wxs/expected/wcs_20_post_bands_name_new.dat
Log Message:
Add comments to previous commit, and make sure that in msWCSGetCoverage20_GetBands() the WCS 2.0 wcs_band_names get priority over the WCS 1.x wcs_rangeset_axes (to be consistent with msWCSGetCoverageMetadata20())
Commit: fc06d45fd7c5ecd06562bd4f3edf42436468576a
https://github.com/mapserver/mapserver/commit/fc06d45fd7c5ecd06562bd4f3edf42436468576a
Author: Even Rouault <even.rouault at mines-paris.org>
Changed paths:
M mapwcs20.c
Log Message:
Merge pull request #5523 from rouault/wcs20_special_case_for_wcs_rangeset_axes_equal_bands
Compare: https://github.com/mapserver/mapserver/compare/8a949f744eb4...fc06d45fd7c5
More information about the mapserver-commits
