[mapserver-commits] [mapserver/mapserver] d33d0e: Fix AssertionError syntax
GitHub
noreply at github.com
Fri Mar 23 03:00:15 PDT 2018
Branch: refs/heads/master
Home: https://github.com/mapserver/mapserver
Commit: d33d0ed123418e9c0cfb5a0c7fb1f68343a7a0d6
https://github.com/mapserver/mapserver/commit/d33d0ed123418e9c0cfb5a0c7fb1f68343a7a0d6
Author: geographika <geographika at gmail.com>
Date: 2018-03-20 (Tue, 20 Mar 2018)
Changed paths:
M mapscript/python/tests/cases/testing.py
Log Message:
Commit: 175902b4023b3a59a2fed8c120559b92f6b607e3
https://github.com/mapserver/mapserver/commit/175902b4023b3a59a2fed8c120559b92f6b607e3
Changed paths:
M mapscript/python/tests/cases/colortest.py
Log Message:
Remove references to pen (no longer a colorObj property) and replace with alpha tests
Commit: 2b32adaa9b6ffe08d1224f517191f9682e03092f
https://github.com/mapserver/mapserver/commit/2b32adaa9b6ffe08d1224f517191f9682e03092f
Changed paths:
M mapscript/python/tests/cases/fonttest.py
Log Message:
A CLASS can now have multiple labels so update syntax to reflect this
Commit: c564418580c14918b0f3ece8f3190bc7c1565cea
https://github.com/mapserver/mapserver/commit/c564418580c14918b0f3ece8f3190bc7c1565cea
Changed paths:
M mapscript/python/tests/cases/hashtest.py
Log Message:
Add new "ows_enable_request" key and value present in the WEB METADATA
Commit: 1b2093b3013f442302e0a2fa6fe2975868bc4015
https://github.com/mapserver/mapserver/commit/1b2093b3013f442302e0a2fa6fe2975868bc4015
Changed paths:
M mapscript/python/tests/cases/imagetest.py
Log Message:
Replace GD renderer with AGG. Stop running imageObj constructor tests as marked as "severely broken"
Commit: 028c87c7b8e03afc1fd5e0a11137796c75a43b2f
https://github.com/mapserver/mapserver/commit/028c87c7b8e03afc1fd5e0a11137796c75a43b2f
Changed paths:
M mapscript/python/tests/cases/labeltest.py
Log Message:
TOREVIEW - getLabel functionality appears to no longer be available
Commit: 0bde55b042b8b7793d8119f7a7699d596c7e70dd
https://github.com/mapserver/mapserver/commit/0bde55b042b8b7793d8119f7a7699d596c7e70dd
Changed paths:
M mapscript/python/tests/cases/layertest.py
Log Message:
Multiple LABEL fix. TOREVIEW new layer does not equal last LAYER in MAP
Commit: 4411fcbdfc9d7ee2965ed09dc997d4285997f10b
https://github.com/mapserver/mapserver/commit/4411fcbdfc9d7ee2965ed09dc997d4285997f10b
Changed paths:
M mapscript/python/tests/cases/linetest.py
Log Message:
TOREVIEW. numpoints is immutable but does not raise an error.
Commit: 0c04a2b02917ccd894bdc57647b376e6e0cadd06
https://github.com/mapserver/mapserver/commit/0c04a2b02917ccd894bdc57647b376e6e0cadd06
Changed paths:
M mapscript/python/tests/cases/maptest.py
Log Message:
WGS84 projection definition change, and WEB METADATA addition
Commit: 4ccc7a795a9226b850d20edf77763a1b3dbacbd1
https://github.com/mapserver/mapserver/commit/4ccc7a795a9226b850d20edf77763a1b3dbacbd1
Changed paths:
M mapscript/python/tests/cases/resultcachetest.py
Log Message:
Change query file extension. Comment out test with getFeature.
Commit: 8499edce3406a4e60b324d59b2fbdadba526259d
https://github.com/mapserver/mapserver/commit/8499edce3406a4e60b324d59b2fbdadba526259d
Changed paths:
M mapscript/python/tests/cases/shapefiletest.py
Log Message:
Use tests paths to find polygon.shp
Commit: fd93b53e57a8aa09f68f7ea1de76f0f72659c6cc
https://github.com/mapserver/mapserver/commit/fd93b53e57a8aa09f68f7ea1de76f0f72659c6cc
Changed paths:
M mapscript/python/tests/cases/shapetest.py
Log Message:
Layer no longer has a getFeature method
Commit: 3a50925ff2d391792d86c7326a1b01c8630e4ed7
https://github.com/mapserver/mapserver/commit/3a50925ff2d391792d86c7326a1b01c8630e4ed7
Changed paths:
M mapscript/python/tests/cases/styletest.py
Log Message:
Commit: f0762b45922cf262322df863aa4091fe6db42f07
https://github.com/mapserver/mapserver/commit/f0762b45922cf262322df863aa4091fe6db42f07
Changed paths:
M mapscript/python/tests/cases/symboltest.py
Log Message:
Use test path. IOError no longer raised.
Commit: 79315090b4cd3a02932c19d54cb450054ea0d817
https://github.com/mapserver/mapserver/commit/79315090b4cd3a02932c19d54cb450054ea0d817
Changed paths:
M mapscript/python/tests/cases/symbolsettest.py
Log Message:
IOError no longer raised. Use TESTS_PATH path for data
Commit: 8ca27c2edddaa43eac952dbdea96184bea4c69f2
https://github.com/mapserver/mapserver/commit/8ca27c2edddaa43eac952dbdea96184bea4c69f2
Changed paths:
Log Message:
Revert "Use test path. IOError no longer raised."
This reverts commit d8a34e1f5cfd04aa2fd15312797b1cdd37a646cb.
Commit: 37d73d794bcde4d7e166bf3ec4cbba38f02b5a2a
https://github.com/mapserver/mapserver/commit/37d73d794bcde4d7e166bf3ec4cbba38f02b5a2a
Changed paths:
M mapscript/python/tests/cases/zoomtest.py
Log Message:
Comment out the failing zoom scale test
Commit: be82c95768f8bd4ac3e9a051d130f4a7cffbb207
https://github.com/mapserver/mapserver/commit/be82c95768f8bd4ac3e9a051d130f4a7cffbb207
Changed paths:
M mapscript/python/tests/cases/outputformattest.py
Log Message:
Refcounts are incorrect - comment out. Update output format name
Commit: f051fb0e4138fd3dd442fe78ac0820024e1ec7a0
https://github.com/mapserver/mapserver/commit/f051fb0e4138fd3dd442fe78ac0820024e1ec7a0
Changed paths:
Log Message:
Comment out any tests that construct image objects
Commit: 7b4be34cd345da274bb887180f5dd17e54a7c916
https://github.com/mapserver/mapserver/commit/7b4be34cd345da274bb887180f5dd17e54a7c916
Changed paths:
A mapscript/python/requirements-dev.txt
A mapscript/python/tests/cases/pytest.ini
A mapscript/python/tox.ini
Log Message:
Add Python testing related files
Commit: c7e597564419a98cd7eb9ba10a2859964d0e74ef
https://github.com/mapserver/mapserver/commit/c7e597564419a98cd7eb9ba10a2859964d0e74ef
Changed paths:
M appveyor.yml
M mapscript/python/tox.ini
Log Message:
Attempt to run mapscript tests from AppVeyor
Commit: 9a445260678340184327a922c1268c43b09b21d8
https://github.com/mapserver/mapserver/commit/9a445260678340184327a922c1268c43b09b21d8
Changed paths:
M appveyor.yml
Log Message:
Update PYTHONPATH settings and install tox
Commit: c2c3f37f3b144a61aad3d509b46fdba0157c4a95
https://github.com/mapserver/mapserver/commit/c2c3f37f3b144a61aad3d509b46fdba0157c4a95
Changed paths:
M appveyor.yml
Log Message:
Correct path to Python
Commit: f64f4887e797f318f6babbde51be96d51746780c
https://github.com/mapserver/mapserver/commit/f64f4887e797f318f6babbde51be96d51746780c
Changed paths:
Log Message:
Stop tox building mapscript
Commit: 78d91baf383a94988a22dd40fb9901224a83e641
https://github.com/mapserver/mapserver/commit/78d91baf383a94988a22dd40fb9901224a83e641
Date: 2018-03-21 (Wed, 21 Mar 2018)
Changed paths:
M appveyor.yml
Log Message:
Fixes to PYTHONPATH and pytest command
Commit: c35885750bef8a7f3ab981a4c159855fc3c734cd
https://github.com/mapserver/mapserver/commit/c35885750bef8a7f3ab981a4c159855fc3c734cd
Changed paths:
Log Message:
Update path to tests folder
Commit: ecfc86e3b2d0c8e6911ab811900037531527278f
https://github.com/mapserver/mapserver/commit/ecfc86e3b2d0c8e6911ab811900037531527278f
Changed paths:
M appveyor.yml
Log Message:
Set paths to Python executables
Commit: 3146f86d9774c147ca693860057f6d0468febbd2
https://github.com/mapserver/mapserver/commit/3146f86d9774c147ca693860057f6d0468febbd2
Changed paths:
M appveyor.yml
Log Message:
Update pip command
Commit: 7b811b4ee917bbdb0182d0fd20d668c9a6512029
https://github.com/mapserver/mapserver/commit/7b811b4ee917bbdb0182d0fd20d668c9a6512029
Changed paths:
M appveyor.yml
Log Message:
Change tox install command
Commit: 15fd526c32425fadda58655d155e8cdff5ab8604
https://github.com/mapserver/mapserver/commit/15fd526c32425fadda58655d155e8cdff5ab8604
Changed paths:
M appveyor.yml
Log Message:
tox command syntax
Commit: c4bc647a214c1550b72d3bf0baf49c14eec6c5f3
https://github.com/mapserver/mapserver/commit/c4bc647a214c1550b72d3bf0baf49c14eec6c5f3
Changed paths:
M appveyor.yml
Log Message:
tox syntax change
Commit: cdf2c0bc613c36accea9526f2c88407f09eb06fc
https://github.com/mapserver/mapserver/commit/cdf2c0bc613c36accea9526f2c88407f09eb06fc
Changed paths:
M appveyor.yml
Log Message:
YAML fix
Commit: 8f448c1f2f3c8682337c0279970ef5346f611b22
https://github.com/mapserver/mapserver/commit/8f448c1f2f3c8682337c0279970ef5346f611b22
Changed paths:
M appveyor.yml
Log Message:
Add Scripts to PATH to find tox
Commit: 8a37187a8b1ebc8e8ff82017a1f51b9d697e7e0b
https://github.com/mapserver/mapserver/commit/8a37187a8b1ebc8e8ff82017a1f51b9d697e7e0b
Changed paths:
M appveyor.yml
Log Message:
Give up on tox
Commit: bbdb670e62a7ade734beca8296bf49d74ced4885
https://github.com/mapserver/mapserver/commit/bbdb670e62a7ade734beca8296bf49d74ced4885
Changed paths:
M appveyor.yml
Log Message:
Update pip
Commit: 7b4d8c7b0c04d2817c73720e810b62baecdc66c6
https://github.com/mapserver/mapserver/commit/7b4d8c7b0c04d2817c73720e810b62baecdc66c6
Changed paths:
M appveyor.yml
Log Message:
Update pip using -m
Commit: 58f5773f0557237327655d03d2ac23307212db3e
https://github.com/mapserver/mapserver/commit/58f5773f0557237327655d03d2ac23307212db3e
Changed paths:
M appveyor.yml
Log Message:
cd to requirements directory
Commit: 901161f45eb48c86ce6488abccbc8bb16fa07378
https://github.com/mapserver/mapserver/commit/901161f45eb48c86ce6488abccbc8bb16fa07378
Changed paths:
M appveyor.yml
Log Message:
syntax cleanup
Commit: 7005b333dc38ade6bbf0144b07b22095a30712ca
https://github.com/mapserver/mapserver/commit/7005b333dc38ade6bbf0144b07b22095a30712ca
Changed paths:
M appveyor.yml
Log Message:
Update to VS 2017
Commit: 641cf98085547c35a7a87ce391acbbb551aee0af
https://github.com/mapserver/mapserver/commit/641cf98085547c35a7a87ce391acbbb551aee0af
Changed paths:
M appveyor.yml
Log Message:
VS 2017
Commit: 1b93bec2c876e66b4c4434a63ba287c4d4395f8f
https://github.com/mapserver/mapserver/commit/1b93bec2c876e66b4c4434a63ba287c4d4395f8f
Changed paths:
M appveyor.yml
Log Message:
Change VS version
Commit: 5f3872e32dafcdf333f62f40665fb0ece86f5d89
https://github.com/mapserver/mapserver/commit/5f3872e32dafcdf333f62f40665fb0ece86f5d89
Changed paths:
M appveyor.yml
Log Message:
Attempt VS 2017 again
Commit: 0c518d894ed8667c4667a095077a08dda716229e
https://github.com/mapserver/mapserver/commit/0c518d894ed8667c4667a095077a08dda716229e
Changed paths:
M appveyor.yml
Log Message:
Back to VS 2013
Commit: e01c2ba331d5dae31f59ca0e1723d2d0360563a4
https://github.com/mapserver/mapserver/commit/e01c2ba331d5dae31f59ca0e1723d2d0360563a4
Changed paths:
M appveyor.yml
Log Message:
Change to newer version of SWIG
Commit: e6ff435d964636633c0baffeb31d157e21483176
https://github.com/mapserver/mapserver/commit/e6ff435d964636633c0baffeb31d157e21483176
Changed paths:
M appveyor.yml
Log Message:
Update SWIG version
Commit: 930fe6d1f733930a078f9a9669490c89b60f9a0f
https://github.com/mapserver/mapserver/commit/930fe6d1f733930a078f9a9669490c89b60f9a0f
Changed paths:
M appveyor.yml
Log Message:
Temporarily disable C# mapscript
Commit: a773f150009cc7e64541706d3aa3b2499950b013
https://github.com/mapserver/mapserver/commit/a773f150009cc7e64541706d3aa3b2499950b013
Date: 2018-03-22 (Thu, 22 Mar 2018)
Changed paths:
M appveyor.yml
Log Message:
Remove remaining failing tests (hash table related)
Commit: c39ef313084a2e7f5c32b35d3a44ab16b5424a72
https://github.com/mapserver/mapserver/commit/c39ef313084a2e7f5c32b35d3a44ab16b5424a72
Date: 2018-03-23 (Fri, 23 Mar 2018)
Changed paths:
R mapscript/python/tox.ini
Log Message:
Remove tox file
Commit: 380d1906c5ea16cbd3fab94cd5d0a33ea9b15786
https://github.com/mapserver/mapserver/commit/380d1906c5ea16cbd3fab94cd5d0a33ea9b15786
Author: Stephan Meißl <stephan at meissl.name>
Changed paths:
M appveyor.yml
Log Message:
Merge pull request #5569 from geographika/py2-fixes
Fixing MapScript unit tests for Python2
Compare: https://github.com/mapserver/mapserver/compare/19dcddee847b...380d1906c5ea
More information about the mapserver-commits
