[mapserver-commits] [mapserver/mapserver] 640a22: Add MapScript support for Python 3.x
GitHub noreply at github.com
Fri Mar 23 04:23:38 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: 640a22871debb55d0fdbea7be19ff82d07a4d81a
      https://github.com/mapserver/mapserver/commit/640a22871debb55d0fdbea7be19ff82d07a4d81a
  Author: Jim Klassen <klassen.js at gmail.com>
  Date:   2018-03-15 (Thu, 15 Mar 2018)
  Changed paths:
    M mapscript/python/CMakeLists.txt
    M mapscript/python/pyextend.i
    M mapscript/python/pymodule.i
    M mapscript/python/setup.py
  Log Message:
Allows MapScript to build and run against Python 3.4.
The changes appear to continue to work with Python 2.7.
If there are multiple Python versions installed on your machine,
the Python version that is selected is whatever CMake finds first
or the path set with -DPYTHON_EXECUTABLE=
Changes include:
* print ""                     ---> print("")
* raise E, "text"              ---> raise E("text")
* PyString_FromStringAndSize() ---> PyBytes_FromStringAndSize()
* Remove references to PyFile*
  Commit: 04755090c48d95625302e5b2fee4cdc81d2da392
      https://github.com/mapserver/mapserver/commit/04755090c48d95625302e5b2fee4cdc81d2da392
  Author: Stephan Meißl <stephan at meissl.name>
  Date:   2018-03-23 (Fri, 23 Mar 2018)
  Changed paths:
  Log Message:
  Merge pull request #5561 from claudep/py3
Compare: https://github.com/mapserver/mapserver/compare/8c337d0b50a2...04755090c48d
