[mapserver-commits] [mapserver/mapserver] a2d9b0: Use generator expressions in CMake
GitHub noreply at github.com
Fri Oct 12 00:04:15 PDT 2018
  Branch: refs/heads/branch-7-2
  Home:   https://github.com/mapserver/mapserver
  Commit: a2d9b0f0a9416bd2d1bd6e38445388e3d9adff32
      https://github.com/mapserver/mapserver/commit/a2d9b0f0a9416bd2d1bd6e38445388e3d9adff32
  Author: Seth G <geographika at gmail.com>
  Date:   2018-10-05 (Fri, 05 Oct 2018)
  Changed paths:
    M mapscript/perl/CMakeLists.txt
  Log Message:
See #5646
Also standardise commands in lower-case
  Commit: e7449f4ee6a86a6a3d4f9fe91164bda5c193bc1c
      https://github.com/mapserver/mapserver/commit/e7449f4ee6a86a6a3d4f9fe91164bda5c193bc1c
  Changed paths:
  Log Message:
  Use swig_add_library
  Commit: b91cfd76a29286e96b0663652ecf0bc4ce4e952b
      https://github.com/mapserver/mapserver/commit/b91cfd76a29286e96b0663652ecf0bc4ce4e952b
  Changed paths:
    M mapscript/java/CMakeLists.txt
  Log Message:
  Update Java CMakeLists
Use generator expression and swig_add_library for newer versions of CMake
  Commit: 05cb8ef40e53e37407cee39b351cb9df37445700
      https://github.com/mapserver/mapserver/commit/05cb8ef40e53e37407cee39b351cb9df37445700
  Changed paths:
    M mapscript/ruby/CMakeLists.txt
  Log Message:
  Update Ruby CMakeLists to use generator expression
Also standardise casing
  Commit: 10d9d259d7334616d4e4315b83a197cff7adcc60
      https://github.com/mapserver/mapserver/commit/10d9d259d7334616d4e4315b83a197cff7adcc60
  Changed paths:
  Log Message:
  Use mapscript_files for output
  Commit: 33138ca89c1838a35308d7d0c1ea76b5e20afa86
      https://github.com/mapserver/mapserver/commit/33138ca89c1838a35308d7d0c1ea76b5e20afa86
  Changed paths:
  Log Message:
  Use mapscript_files for install command
  Commit: 52ce27e93d67f7335a6d90e1d59b76fe39ccf32b
      https://github.com/mapserver/mapserver/commit/52ce27e93d67f7335a6d90e1d59b76fe39ccf32b
  Changed paths:
  Log Message:
  Commit: 612cc46dc4424dbe09636577fdec6f2502cfc5e9
      https://github.com/mapserver/mapserver/commit/612cc46dc4424dbe09636577fdec6f2502cfc5e9
  Author: geographika <geographika at gmail.com>
  Date:   2018-10-06 (Sat, 06 Oct 2018)
  Changed paths:
  Log Message:
  Correct files to install
  Commit: 84d3e0e5f0ec0232d1455790cb6bfc821eeaf671
      https://github.com/mapserver/mapserver/commit/84d3e0e5f0ec0232d1455790cb6bfc821eeaf671
  Changed paths:
    M mapscript/csharp/CMakeLists.txt
  Log Message:
  Remove redundant csharp installer commands
  Commit: f49fa32641e8d95b048e4fd19fbef800013a6f4f
      https://github.com/mapserver/mapserver/commit/f49fa32641e8d95b048e4fd19fbef800013a6f4f
  Date:   2018-10-12 (Fri, 12 Oct 2018)
  Changed paths:
  Log Message:
  Merge pull request #5674 from mapserver/cmake-generator-expressions
Use generator expressions in MapScript CMakeLists
Compare: https://github.com/mapserver/mapserver/compare/d5c22cd3113b...f49fa32641e8
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
