[mapserver-commits] [mapserver/mapserver] 3d3f8a: Fix spelling in README.rst and CONTRIBUTING.md
GitHub
noreply at github.com
Mon Oct 22 13:47:14 PDT 2018
Branch: refs/heads/master
Home: https://github.com/mapserver/mapserver
Commit: 3d3f8a52955f21f278132d066c47cf7d376f6911
https://github.com/mapserver/mapserver/commit/3d3f8a52955f21f278132d066c47cf7d376f6911
Author: Frederic Junod <frederic.junod at camptocamp.com>
Date: 2018-09-24 (Mon, 24 Sep 2018)
Changed paths:
M CONTRIBUTING.md
M README.rst
Log Message:
Commit: 1b0ec46fe4a6f559c6feac6ae48c152ec82e7aac
https://github.com/mapserver/mapserver/commit/1b0ec46fe4a6f559c6feac6ae48c152ec82e7aac
Author: Seth G <geographika at gmail.com>
Changed paths:
M CONTRIBUTING.md
M README.rst
Log Message:
Merge pull request #5664 from fredj/spelling
Commit: d5c22cd3113ba85f5b1f1c406fe4055f75d04ce3
https://github.com/mapserver/mapserver/commit/d5c22cd3113ba85f5b1f1c406fe4055f75d04ce3
Author: Steve Lime <steve.lime at state.mn.us>
Date: 2018-10-01 (Mon, 01 Oct 2018)
Changed paths:
M CMakeLists.txt
M HISTORY.TXT
Log Message:
update for 7.2.1 release
Commit: a2d9b0f0a9416bd2d1bd6e38445388e3d9adff32
https://github.com/mapserver/mapserver/commit/a2d9b0f0a9416bd2d1bd6e38445388e3d9adff32
Date: 2018-10-05 (Fri, 05 Oct 2018)
Changed paths:
M mapscript/perl/CMakeLists.txt
Log Message:
Use generator expressions in CMake
See #5646
Also standardise commands in lower-case
Commit: e7449f4ee6a86a6a3d4f9fe91164bda5c193bc1c
https://github.com/mapserver/mapserver/commit/e7449f4ee6a86a6a3d4f9fe91164bda5c193bc1c
Changed paths:
Log Message:
Use swig_add_library
Commit: b91cfd76a29286e96b0663652ecf0bc4ce4e952b
https://github.com/mapserver/mapserver/commit/b91cfd76a29286e96b0663652ecf0bc4ce4e952b
Changed paths:
M mapscript/java/CMakeLists.txt
Log Message:
Update Java CMakeLists
Use generator expression and swig_add_library for newer versions of CMake
Commit: 05cb8ef40e53e37407cee39b351cb9df37445700
https://github.com/mapserver/mapserver/commit/05cb8ef40e53e37407cee39b351cb9df37445700
Changed paths:
M mapscript/ruby/CMakeLists.txt
Log Message:
Update Ruby CMakeLists to use generator expression
Also standardise casing
Commit: 10d9d259d7334616d4e4315b83a197cff7adcc60
https://github.com/mapserver/mapserver/commit/10d9d259d7334616d4e4315b83a197cff7adcc60
Changed paths:
Log Message:
Use mapscript_files for output
Commit: 33138ca89c1838a35308d7d0c1ea76b5e20afa86
https://github.com/mapserver/mapserver/commit/33138ca89c1838a35308d7d0c1ea76b5e20afa86
Changed paths:
Log Message:
Use mapscript_files for install command
Commit: 52ce27e93d67f7335a6d90e1d59b76fe39ccf32b
https://github.com/mapserver/mapserver/commit/52ce27e93d67f7335a6d90e1d59b76fe39ccf32b
Changed paths:
Log Message:
Commit: 612cc46dc4424dbe09636577fdec6f2502cfc5e9
https://github.com/mapserver/mapserver/commit/612cc46dc4424dbe09636577fdec6f2502cfc5e9
Author: geographika <geographika at gmail.com>
Date: 2018-10-06 (Sat, 06 Oct 2018)
Changed paths:
Log Message:
Correct files to install
Commit: 84d3e0e5f0ec0232d1455790cb6bfc821eeaf671
https://github.com/mapserver/mapserver/commit/84d3e0e5f0ec0232d1455790cb6bfc821eeaf671
Changed paths:
M mapscript/csharp/CMakeLists.txt
Log Message:
Remove redundant csharp installer commands
Commit: 7a4280c7d97cdd97ed9bedf49ae6f58b647be1ee
https://github.com/mapserver/mapserver/commit/7a4280c7d97cdd97ed9bedf49ae6f58b647be1ee
Author: Erik Ravhed <er at t-kartor.se>
Date: 2018-10-11 (Thu, 11 Oct 2018)
Changed paths:
M mapwms.c
Log Message:
Silently ignore WMS filter if it is empty
Commit: e0d8f0b89ba2c742f102e191480f86457a07b62f
https://github.com/mapserver/mapserver/commit/e0d8f0b89ba2c742f102e191480f86457a07b62f
Changed paths:
M mapwms.c
Log Message:
Changed function name for error in msWMSApplyFilter
Commit: f49fa32641e8d95b048e4fd19fbef800013a6f4f
https://github.com/mapserver/mapserver/commit/f49fa32641e8d95b048e4fd19fbef800013a6f4f
Date: 2018-10-12 (Fri, 12 Oct 2018)
Changed paths:
Log Message:
Merge pull request #5674 from mapserver/cmake-generator-expressions
Use generator expressions in MapScript CMakeLists
Commit: 6ee72ff937739d2a221a5c39c9408369bef883f5
https://github.com/mapserver/mapserver/commit/6ee72ff937739d2a221a5c39c9408369bef883f5
Changed paths:
M mapwms.c
Log Message:
Merge pull request #5676 from ravhed/emptyfilter
Silently ignore WMS filter if the provided value is empty
Commit: 04459d1424810a36f6aa86f54f2165f62a14f981
https://github.com/mapserver/mapserver/commit/04459d1424810a36f6aa86f54f2165f62a14f981
Author: Tom Kralidis <tomkralidis at gmail.com>
Date: 2018-10-19 (Fri, 19 Oct 2018)
Changed paths:
M mapmetadata.c
M msautotest/misc/expected/runtime_sub_test_caps.xml
M msautotest/wxs/expected/ows_all_wms_capabilities.xml
M msautotest/wxs/expected/ows_all_wms_capabilities_post.xml
M msautotest/wxs/expected/ows_metadata_wcs_capabilities100.xml
M msautotest/wxs/expected/ows_metadata_wfs_capabilities100.xml
M msautotest/wxs/expected/ows_metadata_wfs_capabilities110.xml
M msautotest/wxs/expected/ows_metadata_wms_capabilities111.xml
M msautotest/wxs/expected/ows_metadata_wms_capabilities130.xml
M msautotest/wxs/expected/ows_wms_capabilities.xml
M msautotest/wxs/expected/ows_wms_rootlayer_name_capabilities.xml
M msautotest/wxs/expected/ows_wms_rootlayer_name_empty_capabilities.xml
M msautotest/wxs/expected/wcs_describe_coverage_tileindexmixedsrs_26711.xml
M msautotest/wxs/expected/wcs_get_capabilities_tileindexmixedsrs_26711.xml
M msautotest/wxs/expected/wcs_get_caps.xml
M msautotest/wxs/expected/wfs11_cap_ogr.xml
M msautotest/wxs/expected/wfs11_caps_updatesequence_ogr.xml
M msautotest/wxs/expected/wfs_cap_ogr.xml
M msautotest/wxs/expected/wfs_caps_updatesequence_ogr.xml
M msautotest/wxs/expected/wfsogr10_caps.xml
M msautotest/wxs/expected/wfsogr11_caps.xml
M msautotest/wxs/expected/wms111_test_xml_escaping.xml
M msautotest/wxs/expected/wms130_test_xml_escaping.xml
M msautotest/wxs/expected/wms_cap.xml
M msautotest/wxs/expected/wms_cap130.xml
M msautotest/wxs/expected/wms_cap130_postgis.xml
M msautotest/wxs/expected/wms_cap_latestversion.xml
M msautotest/wxs/expected/wms_cap_latestversion_postgis.xml
M msautotest/wxs/expected/wms_cap_postgis.xml
M msautotest/wxs/expected/wms_caps_updatesequence.xml
M msautotest/wxs/expected/wms_caps_updatesequence_postgis.xml
M msautotest/wxs/expected/wms_dimension_cap.xml
M msautotest/wxs/expected/wms_dimension_cap130.xml
M msautotest/wxs/expected/wms_get_capabilities_tileindexmixedsrs.xml
M msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
M msautotest/wxs/expected/wms_inspire_scenario1_cap130_eng.xml
M msautotest/wxs/expected/wms_inspire_scenario1_cap130_ger.xml
M msautotest/wxs/expected/wms_inspire_scenario2_cap111.xml
M msautotest/wxs/expected/wms_inspire_scenario2_cap111_eng.xml
M msautotest/wxs/expected/wms_inspire_scenario2_cap111_ger.xml
M msautotest/wxs/expected/wms_inspire_scenario2_cap130.xml
M msautotest/wxs/expected/wms_inspire_scenario2_cap130_eng.xml
M msautotest/wxs/expected/wms_inspire_scenario2_cap130_ger.xml
M msautotest/wxs/expected/wms_layer_groups_caps111.xml
M msautotest/wxs/expected/wms_north_polar_stereo_extent.xml
M msautotest/wxs/expected/wms_nosld_cap.xml
M msautotest/wxs/expected/wms_nosld_cap_postgis.xml
M msautotest/wxs/expected/wms_rast_cap.xml
M msautotest/wxs/expected/wms_time_cap.xml
M msautotest/wxs/expected/wms_time_cap130.xml
M msautotest/wxs/expected/wms_time_cap130_postgis_postgis.xml
M msautotest/wxs/expected/wms_time_cap_postgis_postgis.xml
Log Message:
fix MetadataURL type for Capabilities responses (#5680)
Commit: 8267fa6fee38fecd8cee7b0a48163d19de1a58f4
https://github.com/mapserver/mapserver/commit/8267fa6fee38fecd8cee7b0a48163d19de1a58f4
Author: Jeff McKenna <jeffmckenna at gmail.com>
Changed paths:
M mapmetadata.c
Log Message:
Merge pull request #5684 from tomkralidis/issue-5680
Commit: c6f77b1faddcede08d2be8d3a1c3f05a2fca8c9b
https://github.com/mapserver/mapserver/commit/c6f77b1faddcede08d2be8d3a1c3f05a2fca8c9b
Date: 2018-10-20 (Sat, 20 Oct 2018)
Changed paths:
M mapmetadata.c
M msautotest/wxs/expected/ows_metadata_layer_raster.xml
M msautotest/wxs/expected/ows_metadata_layer_vector.xml
Log Message:
emit only required formats for WMS links in ISO metadata (#5667)
Commit: db9dc5a77b46d8eb8be58053d20dc0e96bffafcc
https://github.com/mapserver/mapserver/commit/db9dc5a77b46d8eb8be58053d20dc0e96bffafcc
Changed paths:
M mapmetadata.c
Log Message:
fix ISO metadata link validity (#5668)
Commit: 373baff3c54f56cdd2391c01a38c5fddffc3b143
https://github.com/mapserver/mapserver/commit/373baff3c54f56cdd2391c01a38c5fddffc3b143
Date: 2018-10-22 (Mon, 22 Oct 2018)
Changed paths:
M mapmetadata.c
Log Message:
Merge pull request #5685 from tomkralidis/issue-5667
Commit: 5cd3b9029d0ea7f9c6bdb0646bb4c1e89d5719ab
https://github.com/mapserver/mapserver/commit/5cd3b9029d0ea7f9c6bdb0646bb4c1e89d5719ab
Changed paths:
M mapmetadata.c
Log Message:
Merge pull request #5686 from tomkralidis/issue-5668
Commit: fa056b1024ee6879fb0b484e47c3f00798b230f7
https://github.com/mapserver/mapserver/commit/fa056b1024ee6879fb0b484e47c3f00798b230f7
Author: Even Rouault <even.rouault at spatialys.com>
Changed paths:
M CONTRIBUTING.md
M HISTORY.TXT
M README.rst
M mapmetadata.c
M mapwms.c
Log Message:
Merge branch 'branch-7-2'
Compare: https://github.com/mapserver/mapserver/compare/913d68e3804a...fa056b1024ee
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the mapserver-commits
