[mapserver-commits] [mapserver/mapserver] bf63d3: Reduce log clutter from non-errors
Even Rouault
noreply at github.com
Fri Jun 21 13:16:52 PDT 2019
Branch: refs/heads/cherry-pick-backport-5827-to-branch-7-4-3858d7ba-13ba-4ad9-b7bc-ae3ec4cc06f9
Home: https://github.com/mapserver/mapserver
Commit: bf63d3dbaf8c90f79139f2a6731b71a52bc5e76f
https://github.com/mapserver/mapserver/commit/bf63d3dbaf8c90f79139f2a6731b71a52bc5e76f
Author: Dave Pearson <36192584+computerchemist at users.noreply.github.com>
Date: 2018-11-21 (Wed, 21 Nov 2018)
Changed paths:
M mapquery.c
Log Message:
Prevent "No matching records" from filling up logfile in terse mode.
https://github.com/mapserver/mapserver/issues/5706
Commit: 978b0d6a87e699d8709b758819fe687e2e3ef5c5
https://github.com/mapserver/mapserver/commit/978b0d6a87e699d8709b758819fe687e2e3ef5c5
Changed paths:
M mapquery.c
Log Message:
Update mapquery.c
Added extra braces to prettify
Commit: 56a9c7d5b0562376d1b874e7b89834fb465cb382
https://github.com/mapserver/mapserver/commit/56a9c7d5b0562376d1b874e7b89834fb465cb382
Author: Steve Lime <steve.lime at state.mn.us>
Date: 2019-03-29 (Fri, 29 Mar 2019)
Changed paths:
M CMakeLists.txt
Log Message:
Updated master to reflect this is now version 7.5 with a 7.6 release target.
Commit: d904b1c5d305cba64407d471f7ccdea38815d75a
https://github.com/mapserver/mapserver/commit/d904b1c5d305cba64407d471f7ccdea38815d75a
Author: sethg <sethg at geographika.co.uk>
Date: 2019-03-30 (Sat, 30 Mar 2019)
Changed paths:
M HISTORY.TXT
M mapkmlrenderer.cpp
M mapscript/php/CMakeLists.txt
M mapscript/phpng/CMakeLists.txt
M mapscript/python/examples/project_csv.py
M mapscript/python/examples/shpdump.py
M mapscript/python/examples/shpinfo.py
M mapscript/python/examples/wxs.py
Log Message:
Merge 7.4 beta fixes back to master
Commit: 88f90355045b492e432996caee4493ee45c6457a
https://github.com/mapserver/mapserver/commit/88f90355045b492e432996caee4493ee45c6457a
Author: Tamas Szekeres <szekerest at gmail.com>
Date: 2019-04-12 (Fri, 12 Apr 2019)
Changed paths:
M .travis.yml
M mapmssql2008.c
Log Message:
Merge branch 'branch-7-4'
Commit: 28c8dae9d324a3ab9b5001bd86d82f4d89b3320b
https://github.com/mapserver/mapserver/commit/28c8dae9d324a3ab9b5001bd86d82f4d89b3320b
Date: 2019-04-17 (Wed, 17 Apr 2019)
Changed paths:
M maptemplate.c
Log Message:
Fix potential XSS issue with [layers] tag.
Commit: 72b305294aa6a783fbfab472d56f791903fa18cb
https://github.com/mapserver/mapserver/commit/72b305294aa6a783fbfab472d56f791903fa18cb
Author: Dan Baston <dbaston at isciences.com>
Date: 2019-05-01 (Wed, 01 May 2019)
Changed paths:
M mapogcsld.c
Log Message:
Fix reference to TEMPPATH in SLD error message
Commit: 359fb45316db31f382cb5a273ba6e8c27dd100c0
https://github.com/mapserver/mapserver/commit/359fb45316db31f382cb5a273ba6e8c27dd100c0
Author: Jeff McKenna <jeffmckenna at gmail.com>
Changed paths:
M mapogcsld.c
Log Message:
Merge pull request #5799 from dbaston/fix-sld-error-message
Commit: 85e294e8c8ce3c9c455fea0137d4af1ee2feced0
https://github.com/mapserver/mapserver/commit/85e294e8c8ce3c9c455fea0137d4af1ee2feced0
Date: 2019-05-16 (Thu, 16 May 2019)
Changed paths:
M .travis.yml
M HISTORY.TXT
M Makefile
M mapgml.c
M mapogcfilter.c
M mapogcfiltercommon.c
M mapproject.c
M mapscript/perl/CMakeLists.txt
M mapscript/perl/examples/RFC24.pl
M mapscript/perl/examples/shp_in_shp.pl
M mapscript/perl/examples/thin.pl
A mapscript/perl/tests/0-load.t
A mapscript/perl/tests/maps.t
R mapscript/php/php_proj.c
M mapscript/swiginc/image.i
M mapscript/swiginc/msio.i
M msautotest/wxs/expected/wms_get_map_ext_sld_404.xml
M msautotest/wxs/expected/wms_get_map_ext_sld_fileproto.xml
M msautotest/wxs/expected/wms_get_map_ext_sld_proto.xml
M msautotest/wxs/expected/wms_get_map_ext_sld_too_large.xml
A msautotest/wxs/expected/wms_getfeatureinfo_encoding.xml
A msautotest/wxs/wms_getfeatureinfo_encoding.map
M scripts/vagrant/packages.sh
Log Message:
Merge recent 'branch-7-4' commits...
Commit: 9f7a7098237a8b1ac3ea68eae4b2f99c77e62f35
https://github.com/mapserver/mapserver/commit/9f7a7098237a8b1ac3ea68eae4b2f99c77e62f35
Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Date: 2019-05-17 (Fri, 17 May 2019)
Changed paths:
M renderers/mvt/vector_tile.proto
Log Message:
set required syntax statement for protobuf 3 (#5376)
Commit: 213792222aceb86f1d9823882d004e98674e162d
https://github.com/mapserver/mapserver/commit/213792222aceb86f1d9823882d004e98674e162d
Changed paths:
Log Message:
Commit: fa09c060db91f54765d436ee5a3e8b1ddd94a4a9
https://github.com/mapserver/mapserver/commit/fa09c060db91f54765d436ee5a3e8b1ddd94a4a9
Changed paths:
Log Message:
Merge pull request #5810 from jmckenna/openlayers5-template
Commit: 30dd51713fafa0a7e752591733dd5cefcd8c3bea
https://github.com/mapserver/mapserver/commit/30dd51713fafa0a7e752591733dd5cefcd8c3bea
Date: 2019-06-04 (Tue, 04 Jun 2019)
Changed paths:
M mapscript/python/README.rst
Log Message:
Update Python README.rst with latest version
Commit: cde432c3f73ce43479d7b3271b789b19a9b77048
https://github.com/mapserver/mapserver/commit/cde432c3f73ce43479d7b3271b789b19a9b77048
Date: 2019-06-05 (Wed, 05 Jun 2019)
Changed paths:
M mapscript/python/tests/cases/map_test.py
Log Message:
Exclude failing projection test
Commit: 356a1e1425482bf8c3a62e685a119a964273bd2d
https://github.com/mapserver/mapserver/commit/356a1e1425482bf8c3a62e685a119a964273bd2d
Author: Seth G <sethg at geographika.co.uk>
Changed paths:
Log Message:
Merge pull request #5816 from geographika/python-mapscript-7-4
Commit: 63eadf33ef5996f84f84de49bce4305bf605192f
https://github.com/mapserver/mapserver/commit/63eadf33ef5996f84f84de49bce4305bf605192f
Changed paths:
Log Message:
Update projection WKT string
Commit: ace397019368a84629440d81ee18e78ff44af50e
https://github.com/mapserver/mapserver/commit/ace397019368a84629440d81ee18e78ff44af50e
Date: 2019-06-06 (Thu, 06 Jun 2019)
Changed paths:
Log Message:
Add UNIT param and check datum
Commit: 04a9711f1e50a17352e8db0eb8b7887c92a332ca
https://github.com/mapserver/mapserver/commit/04a9711f1e50a17352e8db0eb8b7887c92a332ca
Changed paths:
Log Message:
Shorten line and cleanup assert
Commit: 36175e0f3f35d8a5ff68ee719ba409860fadfc73
https://github.com/mapserver/mapserver/commit/36175e0f3f35d8a5ff68ee719ba409860fadfc73
Changed paths:
Log Message:
Merge pull request #5818 from mapserver/geographika-patch-1
Update Projection WKT string
Commit: 51f0ce00125f01fa7abe3d313fd67b0fa96ec2bd
https://github.com/mapserver/mapserver/commit/51f0ce00125f01fa7abe3d313fd67b0fa96ec2bd
Date: 2019-06-10 (Mon, 10 Jun 2019)
Changed paths:
M mapquery.c
Log Message:
Merge pull request #5707 from computerchemist/patch-1
Commit: aea4479dd16aa07c4cc819a6d4d801756e9be12a
https://github.com/mapserver/mapserver/commit/aea4479dd16aa07c4cc819a6d4d801756e9be12a
Date: 2019-06-12 (Wed, 12 Jun 2019)
Changed paths:
M cmake/FindOracle.cmake
Log Message:
Merge remote-tracking branch 'origin/branch-7-4'
Commit: 9f9680e23f9e345e6c7d6c4bbd3e4944a0e49e14
https://github.com/mapserver/mapserver/commit/9f9680e23f9e345e6c7d6c4bbd3e4944a0e49e14
Date: 2019-06-14 (Fri, 14 Jun 2019)
Changed paths:
M mapquery.c
Log Message:
Revert "Reduce log clutter from non-errors"
Commit: 66fe6bfa66c79c495070f09b2452f3349783aaba
https://github.com/mapserver/mapserver/commit/66fe6bfa66c79c495070f09b2452f3349783aaba
Changed paths:
M mapquery.c
Log Message:
Merge pull request #5822 from mapserver/revert-5707-patch-1
Commit: daa08bb3c8c583f0197863a4ab1d608832f5a161
https://github.com/mapserver/mapserver/commit/daa08bb3c8c583f0197863a4ab1d608832f5a161
Author: jbo-ads <jbo-ads at laposte.net>
Changed paths:
M msautotest/misc/ogr_empty_geojson.map
M msautotest/wxs/wfs_200.map
M msautotest/wxs/wfs_200_allgeoms.map
M msautotest/wxs/wfs_200_cite.map
M msautotest/wxs/wfs_200_cite_postgis.map
M msautotest/wxs/wfs_200_low_wfsmaxfeatures_no_compute_number_matched.map
M msautotest/wxs/wfs_filter.map
M msautotest/wxs/wfs_filter_ogr.map
M msautotest/wxs/wfs_filter_postgis.map
M msautotest/wxs/wfs_filter_projmeter.map
M msautotest/wxs/wfs_ogr_native_sql.map
M msautotest/wxs/wfs_ogr_no_native_sql.map
M msautotest/wxs/wfs_time.map
M msautotest/wxs/wfs_time_ogr.map
M msautotest/wxs/wfs_time_postgis.map
M msautotest/wxs/wms_inspire.map
M msautotest/wxs/wms_raster.map
Log Message:
Add 'DEBUG 3' on failing msautotests
Commit: aa19af75d493e43e68dcacebf970fcb9ab432610
https://github.com/mapserver/mapserver/commit/aa19af75d493e43e68dcacebf970fcb9ab432610
Changed paths:
Log Message:
Merge pull request #5823 from jbo-ads/update-msautotest-wrt-5707
Commit: bc2fc29d9f931eeb22483d5e93834026b4cc8aa3
https://github.com/mapserver/mapserver/commit/bc2fc29d9f931eeb22483d5e93834026b4cc8aa3
Date: 2019-06-17 (Mon, 17 Jun 2019)
Changed paths:
M mapquery.c
Log Message:
Revert "Revert "Reduce log clutter from non-errors""
Commit: 139ed5a40c8957c2c34695f50eec2cd5cf4894e8
https://github.com/mapserver/mapserver/commit/139ed5a40c8957c2c34695f50eec2cd5cf4894e8
Date: 2019-06-18 (Tue, 18 Jun 2019)
Changed paths:
M mapquery.c
Log Message:
Merge pull request #5824 from mapserver/revert-5822-revert-5707-patch-1
Re-apply "Reduce log clutter from non-errors""
Commit: d523255aef27999dcc3296d4e9b02269e419e878
https://github.com/mapserver/mapserver/commit/d523255aef27999dcc3296d4e9b02269e419e878
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2019-06-21 (Fri, 21 Jun 2019)
Changed paths:
M CMakeLists.txt
M mapquery.c
Log Message:
Sibling of efce4a3d029eac7f760ddc7bc9d5e39cf2fe266b [skip ci]
skip-checks: true
Compare: https://github.com/mapserver/mapserver/compare/6f879de60fd1...d523255aef27
More information about the mapserver-commits
