[mapserver-commits] [mapserver/mapserver] f1a579: [mapscript/php] Fix build problems for PHP 7.3
Seth G
noreply at github.com
Wed Mar 13 04:04:49 PDT 2019
Branch: refs/heads/master
Home: https://github.com/mapserver/mapserver
Commit: f1a579a7ce06289c7783a4c770b78262ab409635
https://github.com/mapserver/mapserver/commit/f1a579a7ce06289c7783a4c770b78262ab409635
Author: ejn <edward.nash at gmx.de>
Date: 2019-03-04 (Mon, 04 Mar 2019)
Changed paths:
M mapscript/php/php_mapscript.c
M mapscript/php/php_mapscript_util.h
M mapscript/php/php_proj.c
Log Message:
* array_init is no longer function-like
* generally was probably never worth checking the return type, so all
checks for failure removed
* Changes in API for reference counting for GC
Commit: 189dbe93036398b1a488db91ed8c7eb1e90cee3d
https://github.com/mapserver/mapserver/commit/189dbe93036398b1a488db91ed8c7eb1e90cee3d
Changed paths:
M .travis.yml
Log Message:
Run Travis CI for PHP 7.3
Commit: a892e425efbdd7b41f14ab12c6884ba6fb773134
https://github.com/mapserver/mapserver/commit/a892e425efbdd7b41f14ab12c6884ba6fb773134
Author: Seth G <geographika at gmail.com>
Date: 2019-03-13 (Wed, 13 Mar 2019)
Changed paths:
M .travis.yml
Log Message:
Merge pull request #5757 from ejn/php7-build-problems-fix
Fix PHP7 build problems with 7.3
Compare: https://github.com/mapserver/mapserver/compare/a822469ea6a7...a892e425efbd
More information about the mapserver-commits
