[mapserver-commits] [mapserver/mapserver] 5be9bc: Sibling of 2ceadc980241b38a4316731646bdf7c6a8b85a5...
backporting[bot]
noreply at github.com
Sun Nov 3 04:02:20 PST 2019
Branch: refs/heads/cherry-pick-backport-5911-to-branch-7-4-e4fe41fe-1aeb-402f-88da-442ae6a249d7
Home: https://github.com/mapserver/mapserver
Commit: 5be9bc12211d38c494aef695d61d7fb87d0479d7
https://github.com/mapserver/mapserver/commit/5be9bc12211d38c494aef695d61d7fb87d0479d7
Author: Rutjes, Dennis <dennis.rutjes at kadaster.nl>
Date: 2019-10-30 (Wed, 30 Oct 2019)
Changed paths:
M .travis.yml
M CMakeLists.txt
M HISTORY.TXT
M Makefile
M Vagrantfile
M appveyor.yml
M ci/travis/before_install.sh
M ci/travis/script.sh
M cmake/FindProj.cmake
M create_mapaxisorder_csv.py
M fontcache.c
M kerneldensity.c
M mapaxisorder.csv
M mapaxisorder.h
M mapcairo.c
M mapchart.c
M mapcluster.c
M mapcontext.c
M mapcopy.c
M mapdraw.c
M mapfile.c
M mapfile.h
M mapgdal.c
M mapgeos.c
M mapgml.c
M mapgraticule.c
M mapimageio.c
M mapkmlrenderer.cpp
M maplayer.c
M maplexer.c
M maplexer.l
M mapmetadata.c
M mapmvt.c
M mapobject.c
M mapogcfilter.c
M mapogcfilter.h
M mapogcfiltercommon.c
M mapogcsld.c
M mapogcsld.h
M mapogcsos.c
M mapogr.cpp
M mapogroutput.c
M mapoutput.c
M mapows.c
M mapows.h
M mappostgis.c
M mapproject.c
M mapproject.h
A mapprojhack.c
M mapquery.c
M mapraster.c
M maprasterquery.c
M mapresample.c
M mapscale.c
M mapscript/mapscript.i
M mapscript/php/mapscript_i.c
M mapscript/php/php_mapscript.c
M mapscript/php/php_mapscript.h
M mapscript/python/pyextend.i
M mapscript/python/pymodule.i
M mapscript/python/tests/cases/map_test.py
M mapscript/swiginc/layer.i
M mapscript/swiginc/map.i
M mapserver.h
M mapservutil.c
M mapshape.c
M mapshape.h
M mapstring.c
M maptemplate.c
M mapthread.c
M mapunion.c
M maputil.c
M mapuvraster.c
M mapwcs.c
M mapwcs11.c
M mapwcs20.c
M mapwfs.c
M mapwms.c
M msautotest/.gitignore
R msautotest/gdal/connectionoptions.map
R msautotest/gdal/data/red_square.tif.ovr
R msautotest/gdal/expected/connectionoptions.png
M msautotest/gdal/expected/nonsquare_multiraw.png
M msautotest/gdal/expected/tileindexmixedsrs.png
M msautotest/gdal/expected/tileindexmixedsrs2.png
M msautotest/gdal/expected/tileindexmixedsrs3.png
M msautotest/gdal/expected/tileindexmixedsrs4.png
M msautotest/gdal/tileindexmixedsrs.map
M msautotest/gdal/tileindexmixedsrs2.map
M msautotest/gdal/tileindexmixedsrs3.map
M msautotest/gdal/tileindexmixedsrs4.map
M msautotest/misc/expected/grid_without_label.png
M msautotest/pymod/testlib.py
R msautotest/query/expected/expressions_test001.txt
R msautotest/query/expected/expressions_test002.txt
R msautotest/query/expected/expressions_test003.txt
R msautotest/query/expected/expressions_test004.txt
R msautotest/query/expected/expressions_test005.txt
R msautotest/query/expected/expressions_test006.txt
R msautotest/query/expected/expressions_test007.txt
R msautotest/query/expected/expressions_test008.txt
R msautotest/query/expected/expressions_test009.txt
R msautotest/query/expected/query_test013.txt
R msautotest/query/expressions.map
M msautotest/query/query.map
R msautotest/query/template/query_formatted.tmpl
M msautotest/renderers/expected/labelrot.png
R msautotest/sld/arithmetic_line.map
R msautotest/sld/arithmetic_point.map
R msautotest/sld/arithmetic_polygon.map
R msautotest/sld/arithmetic_text.map
R msautotest/sld/base.map
R msautotest/sld/data/fonts.lst
R msautotest/sld/data/hexagon.dbf
R msautotest/sld/data/hexagon.json
R msautotest/sld/data/hexagon.prj
R msautotest/sld/data/hexagon.shp
R msautotest/sld/data/hexagon.shx
R msautotest/sld/data/inner.dbf
R msautotest/sld/data/inner.json
R msautotest/sld/data/inner.prj
R msautotest/sld/data/inner.shp
R msautotest/sld/data/inner.shx
R msautotest/sld/data/plot.dbf
R msautotest/sld/data/plot.json
R msautotest/sld/data/plot.prj
R msautotest/sld/data/plot.shp
R msautotest/sld/data/plot.shx
R msautotest/sld/data/set.json
R msautotest/sld/expected/base_mapfile.png
R msautotest/sld/expected/base_sldbody.png
R msautotest/sld/expected/map_reference.png
R msautotest/sld/expected/size_mapfile.png
R msautotest/sld/expected/size_sldbody.png
R msautotest/sld/expected/sld_line_expression_strokeopacity.png
R msautotest/sld/expected/sld_line_expression_strokewidth.png
R msautotest/sld/expected/sld_line_literal_stroke.png
R msautotest/sld/expected/sld_line_literal_strokeopacity.png
R msautotest/sld/expected/sld_line_literal_strokewidth.png
R msautotest/sld/expected/sld_line_propertyname_stroke.png
R msautotest/sld/expected/sld_line_propertyname_strokeopacity.png
R msautotest/sld/expected/sld_line_propertyname_strokewidth.png
R msautotest/sld/expected/sld_named_userstyle_1.png
R msautotest/sld/expected/sld_named_userstyle_2.png
R msautotest/sld/expected/sld_named_userstyle_3.png
R msautotest/sld/expected/sld_named_userstyle_get_styles.xml
R msautotest/sld/expected/sld_point_expression_displacementx.png
R msautotest/sld/expected/sld_point_expression_displacementy.png
R msautotest/sld/expected/sld_point_expression_opacity.png
R msautotest/sld/expected/sld_point_expression_rotation.png
R msautotest/sld/expected/sld_point_expression_size.png
R msautotest/sld/expected/sld_point_expression_strokewidth.png
R msautotest/sld/expected/sld_point_literal_displacementx.png
R msautotest/sld/expected/sld_point_literal_displacementy.png
R msautotest/sld/expected/sld_point_literal_fill.png
R msautotest/sld/expected/sld_point_literal_opacity.png
R msautotest/sld/expected/sld_point_literal_rotation.png
R msautotest/sld/expected/sld_point_literal_size.png
R msautotest/sld/expected/sld_point_literal_stroke.png
R msautotest/sld/expected/sld_point_literal_strokewidth.png
R msautotest/sld/expected/sld_point_propertyname_displacementx.png
R msautotest/sld/expected/sld_point_propertyname_displacementy.png
R msautotest/sld/expected/sld_point_propertyname_fill.png
R msautotest/sld/expected/sld_point_propertyname_opacity.png
R msautotest/sld/expected/sld_point_propertyname_rotation.png
R msautotest/sld/expected/sld_point_propertyname_size.png
R msautotest/sld/expected/sld_point_propertyname_stroke.png
R msautotest/sld/expected/sld_point_propertyname_strokewidth.png
R msautotest/sld/expected/sld_polygon_expression_fillopacity.png
R msautotest/sld/expected/sld_polygon_expression_strokeopacity.png
R msautotest/sld/expected/sld_polygon_expression_strokewidth.png
R msautotest/sld/expected/sld_polygon_literal_fill.png
R msautotest/sld/expected/sld_polygon_literal_fillopacity.png
R msautotest/sld/expected/sld_polygon_literal_stroke.png
R msautotest/sld/expected/sld_polygon_literal_strokeopacity.png
R msautotest/sld/expected/sld_polygon_literal_strokewidth.png
R msautotest/sld/expected/sld_polygon_propertyname_fill.png
R msautotest/sld/expected/sld_polygon_propertyname_fillopacity.png
R msautotest/sld/expected/sld_polygon_propertyname_stroke.png
R msautotest/sld/expected/sld_polygon_propertyname_strokeopacity.png
R msautotest/sld/expected/sld_polygon_propertyname_strokewidth.png
R msautotest/sld/expected/sld_reference.png
R msautotest/sld/expected/sld_text_expression_fontsize.png
R msautotest/sld/expected/sld_text_expression_rotation.png
R msautotest/sld/expected/sld_text_literal_fill.png
R msautotest/sld/expected/sld_text_literal_fontsize.png
R msautotest/sld/expected/sld_text_literal_halofill.png
R msautotest/sld/expected/sld_text_literal_rotation.png
R msautotest/sld/expected/sld_text_propertyname_fill.png
R msautotest/sld/expected/sld_text_propertyname_fontsize.png
R msautotest/sld/expected/sld_text_propertyname_halofill.png
R msautotest/sld/expected/sld_text_propertyname_rotation.png
R msautotest/sld/reference.map
R msautotest/sld/run_test.py
R msautotest/sld/size.map
R msautotest/sld/sld_named_userstyle.map
R msautotest/sld/sld_named_userstyle_get_styles.map
M msautotest/valgrind-suppressions.txt
R msautotest/wxs/data/nested_attrs.geojson
M msautotest/wxs/data/polar_stereo.tif
R msautotest/wxs/expected/ogr_connectionoptions.xml
M msautotest/wxs/expected/ows_metadata_wcs_capabilities100.xml
M msautotest/wxs/expected/ows_metadata_wcs_capabilities110.xml
M msautotest/wxs/expected/ows_wcs_capabilities.xml
M msautotest/wxs/expected/ows_wcs_describecoverage.xml
M msautotest/wxs/expected/wcs11_cap.txt
M msautotest/wxs/expected/wcs11_cap.xml
M msautotest/wxs/expected/wcs11_caps_section1.xml
M msautotest/wxs/expected/wcs11_caps_section3.xml
M msautotest/wxs/expected/wcs11_caps_updatesequence.xml
M msautotest/wxs/expected/wcs11_describe.xml
M msautotest/wxs/expected/wcs11_post_cap.xml
M msautotest/wxs/expected/wcs11_post_caps_section1.xml
M msautotest/wxs/expected/wcs11_post_caps_section3.xml
M msautotest/wxs/expected/wcs11_post_caps_updatesequence.xml
M msautotest/wxs/expected/wcs11_post_describe.xml
R msautotest/wxs/expected/wcs_20_getcov_bands_name_new_reproject.dat.alternative
M msautotest/wxs/expected/wcs_20_getcov_outputcrs.tif
M msautotest/wxs/expected/wcs_20_getcov_reproj.dat
M msautotest/wxs/expected/wcs_20_post_getcov_subsettingcrs_outputcrs.tif
M msautotest/wxs/expected/wcs_cap.txt
M msautotest/wxs/expected/wcs_cap.xml
M msautotest/wxs/expected/wcs_caps_updatesequence.xml
M msautotest/wxs/expected/wcs_describe.xml
M msautotest/wxs/expected/wcs_describe_coverage_tileindexmixedsrs_26711.xml
M msautotest/wxs/expected/wcs_get_capabilities_tileindexmixedsrs_26711.xml
M msautotest/wxs/expected/wcs_get_caps.xml
M msautotest/wxs/expected/wcs_getcov_exception_bbox.xml
M msautotest/wxs/expected/wcs_mask_20_getcov_reproj.dat
M msautotest/wxs/expected/wfs_filter_projmeter_disjoint.xml
M msautotest/wxs/expected/wfsogr11_caps.xml
R msautotest/wxs/expected/wfsogr20_geojson.json
R msautotest/wxs/expected/wfsogr20_geojson_with_predefine_native_data.json
M msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_all_layers.png
M msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_all_layers_postgis.png
M msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_one_layer.png
M msautotest/wxs/expected/wms_get_map_multi_layers_one_sld_on_one_layer_postgis.png
M msautotest/wxs/expected/wms_inspire_cap.xml
M msautotest/wxs/expected/wms_inspire_cap_111.xml
M msautotest/wxs/expected/wms_inspire_cap_111_eng.xml
M msautotest/wxs/expected/wms_inspire_cap_111_ger.xml
M msautotest/wxs/expected/wms_inspire_cap_eng.xml
M msautotest/wxs/expected/wms_inspire_cap_ger.xml
M msautotest/wxs/expected/wms_inspire_scenario1_styles130_airlink.xml
M msautotest/wxs/expected/wms_inspire_scenario1_styles130_roadarea.xml
M msautotest/wxs/expected/wms_inspire_scenario1_styles130_roadlink.xml
M msautotest/wxs/expected/wms_inspire_scenario1_styles130_transportlink.xml
M msautotest/wxs/expected/wms_inspire_scenario2_styles130_airlink.xml
M msautotest/wxs/expected/wms_inspire_scenario2_styles130_roadarea.xml
M msautotest/wxs/expected/wms_inspire_scenario2_styles130_roadlink.xml
M msautotest/wxs/expected/wms_inspire_scenario2_styles130_transportlink.xml
M msautotest/wxs/expected/wms_inspire_styles_all.xml
M msautotest/wxs/expected/wms_inspire_styles_commontransportelements.xml
M msautotest/wxs/expected/wms_inspire_styles_railtransportnetwork.xml
M msautotest/wxs/expected/wms_inspire_styles_roadtransportnetwork.xml
M msautotest/wxs/expected/wms_inspire_styles_transportnode.xml
R msautotest/wxs/ogr_connectionoptions.map
M msautotest/wxs/wfs_200.map
M msautotest/wxs/wfs_200_allgeoms.map
M msautotest/wxs/wfs_200_cite.map
M msautotest/wxs/wfs_200_cite_postgis.map
M msautotest/wxs/wfs_200_low_wfsmaxfeatures_no_compute_number_matched.map
M msautotest/wxs/wfs_filter.map
M msautotest/wxs/wfs_filter_ogr.map
M msautotest/wxs/wfs_filter_postgis.map
M msautotest/wxs/wfs_filter_projmeter.map
M msautotest/wxs/wfs_ogr_geojson.map
M msautotest/wxs/wfs_ogr_native_sql.map
M msautotest/wxs/wfs_ogr_no_native_sql.map
M msautotest/wxs/wfs_time.map
M msautotest/wxs/wfs_time_ogr.map
M msautotest/wxs/wfs_time_postgis.map
M msautotest/wxs/wms_inspire.map
M msautotest/wxs/wms_north_polar_stereo_extent.map
M msautotest/wxs/wms_raster.map
M msautotest/wxs/wms_uvraster_map_reprojection.map
M renderers/agg/include/agg_conv_curve.h
M renderers/agg/include/agg_path_storage.h
M scripts/vagrant/mapserver.sh
M scripts/vagrant/packages.sh
R scripts/vagrant/proj6.sh
Log Message:
Sibling of 2ceadc980241b38a4316731646bdf7c6a8b85a56 [skip ci]
skip-checks: true
More information about the mapserver-commits
