[mapserver-commits] [mapserver/mapserver] a471b4: OGR GPKG: fix potential SELECT ambiguity for 'id' ...
Even Rouault
noreply at github.com
Mon Sep 9 09:00:53 PDT 2019
Branch: refs/heads/cherry-pick-backport-5860-to-branch-7-4-9fce3484-c635-4818-aa7b-5629e9bdb0d1
Home: https://github.com/mapserver/mapserver
Commit: a471b4518beacc55879ac7ce970cadecb7e34d5c
https://github.com/mapserver/mapserver/commit/a471b4518beacc55879ac7ce970cadecb7e34d5c
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2019-09-09 (Mon, 09 Sep 2019)
Changed paths:
M mapogr.cpp
A msautotest/wxs/data/test.gpkg
A msautotest/wxs/expected/wfs_ogr_gpkg_issue_5858.xml
A msautotest/wxs/wfs_ogr_gpkg.map
Log Message:
OGR GPKG: fix potential SELECT ambiguity for 'id' column (fixes #5858)
When using a GeoPackage table that has a 'id' column, in some circumstances,
MapServer composes internally a SELECT statement, but fails to prefix the
id column with the table name, which causes an ambiguity when joining with
the spatial index RTree table that has also a id column.
More information about the mapserver-commits
